Home » Archived » Test and Performance Tools Platform (TPTP) » [AGR] java.lang.NullPointerException, AbstractTestExecutionService
[AGR] java.lang.NullPointerException, AbstractTestExecutionService [message #110099] Mon, 27 August 2007 03:10 Go to next message
Hello all !
I'm trying to run a test with the AutomationClientAdapter, but when I run
the test I have an error:
at
org.eclipse.hyades.test.core.services.AbstractTestExecutionS ervice.execute(AbstractTestExecutionService.java:507)
at
org.eclipse.hyades.automation.server.AbstractService.execute (AbstractService.java:43)
at
org.eclipse.hyades.automation.server.ServiceProxy$1.run(Serv iceProxy.java:141)
at
org.eclipse.hyades.automation.core.utils.ReusableThread.run( ReusableThread.java:131)
My code is:
package test;
import java.util.Properties;
import
org.eclipse.hyades.automation.client.adapters.java.Automatio nClientAdapter;
public class Lanc {
static String eclipsePath = new String("C:\\Program Files\\tptp\\eclipse");
static String ModemPath = new String("C:\\ProgramFiles\\Modem\\Modem");
* @param args
// Create the Java adapter associated with the specified Eclipse home
AutomationClientAdapter automation = new
AutomationClientAdapter(eclipsePath.toString());
// Create and configure a properties object
Properties properties = new Properties();
properties.setProperty("workspace", ModemPath.toString());
properties.setProperty("project", "Modem");
properties.setProperty("suite", "mod.testsuite");
// Execute the service named below using the configured properties
automation.execute("org.eclipse.hyades.test.tools.core.execute ",
properties);
Thanks for your help !
Pierre
Re: [AGR] java.lang.NullPointerException, AbstractTestExecutionService [message #110472 is a reply to message #110099] Tue, 28 August 2007 04:07 Go to previous messageGo to next message
I do not know why, but it runs now !
Re: [AGR] java.lang.NullPointerException, AbstractTestExecutionService [message #110752 is a reply to message #110472] Thu, 30 August 2007 07:30 Go to previous message
Hi Pierre,
If you are able to consistency reproduce this problem, please provide
the steps so we can investigate further.
Paul
"Pierre" <pns57@hotmail.com> wrote in message
news:ca93291614daeac120451c4f8eace72b$1@www.eclipse.org...
Previous Topic:How to add third-party jars to TPTP/JUnit test?
Next Topic:Missing Constraint: Require-Bundle... for org.eclipse.tptp.platform.profile.server.wst
Current Time: Sun Jul 20 10:27:15 EDT 2025
Powered by FUDForum. Page generated in 0.03301 seconds
