Home » Eclipse Projects » Remote Application Platform (RAP) » How to implement ToolTips on Table-Cells ?
How to implement ToolTips on Table-Cells ? [message #110030] Tue, 21 October 2008 12:16 Go to next message
We want to provide tooltips on table-cells.
As the corresponding JFace-API is not available yet (will it be in RAP 1.2
?), we did a workaround, which we now want to improve to come as close to
real tooltips as possible.
Currently we have written a small yellow tooltip-window, which will open
when a table cell is clicked. This window is closed automatically, when
the user clicks somewhere else.
Of course we'd rather want it to open, when the mouse stays above the
table-cell for a while without having the user to click ?
Do you have any suggestions, how this can be achieved ? We'd be happy
about any idea, don't mind if it is crazy and involves hacking some
RAP-classes :D ...
Could we send a custom JS-Script which informes RAP when the user stopped
moving his mouse ? Could RAP calculate the widget given the
mouse-coordinates from the client window ?
Are there any events, that already do this kind of stuff ?
Any help appreciated !
Stefan
Re: How to implement ToolTips on Table-Cells ? [message #110163 is a reply to message #110030] Wed, 22 October 2008 03:08 Go to previous messageGo to next message
Originally posted by: erdal.karaca.airbus.com
This is what I need, too.
IMHO, qooxdoo already supports mouse-events and tooltips.
I was told that this (related to cell editors) will be fixed when rap,
too, will support mouse-events.
> RAP-classes :D ...
> Regards,
> Stefan
Re: How to implement ToolTips on Table-Cells ? [message #110251 is a reply to message #110030] Thu, 23 October 2008 04:18 Go to previous messageGo to next message
Currently, JFace Tooltips aren't on the 1.2 plan.
> RAP-classes :D ...
This is the approach I would try first.
To send Javascript you need to register the Javascript file as a
resource. See the Custom Widget Tutorial [1] on how to do this.
On the client-side, it should be sufficient to add one mouse
listener to the document (or its qx-wrapper
qx.ui.core.ClientDocument.getInstance()). This listener would then
send a request when the mouse stopped or whatever you activation
strategy is.
To process the request server-side you could use a PhaseListener. In
the before-read-data event you could read the request parameters
open a tooltip if it was requested.
It should be possible to determine a widget from some absolute
coordinates. There is a class WidgetTreeVisitor to iterate over the
widget hierarchy.
A example for coordinate mapping can be found in
ControlLCAUtil#readXYParams().
> Regards,
> Stefan
[1]
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.rap.help/help/html/advanced/custom-widget.html
Re: How to implement ToolTips on Table-Cells ? [message #110277 is a reply to message #110163] Thu, 23 October 2008 04:25 Go to previous message
Right. The qx mouse events are used for RAP mouse events. Qx
tooltips are used for Control#setToolTipText(). JFace tooltips are
composed of Shells, thus qx tooltips aren't helpful here.
The most difficult thing with JFace tooltips is probably when to
show and hide them.
To clarify: RAP already supports mouse events (mouseUp, mouseDown,
mouseDoubleClick). Mouse-move events aren't supported and probably
will never be.
Cell editors are in the works but tooltips aren't part of this.
JFace tooltips are currently not planned for 1.2
>> 1.2 ?), we did a workaround, which we now want to improve to come as
>> close to real tooltips as possible.
>> open when a table cell is clicked. This window is closed
>> automatically, when the user clicks somewhere else.
>> RAP-classes :D ...
>> stopped moving his mouse ? Could RAP calculate the widget given the
>> Regards, Stefan
Previous Topic:Action AS_DROP_DOWN_MENU does`nt work properly.
Next Topic:can Table cells wrap lines?
Current Time: Sun Jul 20 02:51:02 EDT 2025
Powered by FUDForum. Page generated in 0.04223 seconds
