Home » Modeling » Papyrus » Serious bug in Kepler!
Serious bug in Kepler! [message #1101315] Wed, 04 September 2013 05:44 Go to next message
Hi all,
I just found out that when you manually redirect associations from one class
to another, Papyrus did not move properties that are owned by a classifier.
Detaching an association source from class A and attaching it to class B,
the navigable property that ought to belong now to class B remains in class
A.
This is a serious bug that needs to be fixed ASAP
Can anyone confirm this behavior, so that I can file an issue for this.
Marc-Florian
Re: Serious bug in Kepler! [message #1101411 is a reply to message #1101315] Wed, 04 September 2013 08:26 Go to previous message
Hi, Marc-Florian,
You don't need anyone to confirm the problem here. Just file the bug.
Confirmation is part of the bug investigation and resolution process.
And don't forget to set the severity according to how serious you the
issue is in your use cases.
Christian
On 2013-09-04 09:44:40 +0000, Marc-Florian Wendland said:
> Hi all,
> class to another, Papyrus did not move properties that are owned by a
> classifier. Detaching an association source from class A and attaching
> it to class B, the navigable property that ought to belong now to class
> B remains in class A.
> Marc-Florian
Previous Topic:UTP1.2 How to add Arbiter property to TestContext?
Next Topic:Problem with registered Profile
Current Time: Sat Jul 19 09:00:18 EDT 2025
Powered by FUDForum. Page generated in 0.04332 seconds
