Home » Archived » BIRT » help with "Chart Builder Example"
help with "Chart Builder Example" [message #526340] Fri, 09 April 2010 13:38 Go to next message
I have been looking into this example posted on the BirtExchange devShare: http:// www.birt-exchange.org/devshare/designing-birt-reports/1184-c hart-builder-example/#description
But I am having some trouble. I am not super familiar with java, and am stretching far outside my comfort zone and got kind of lost. I managed to create the project and fix the class paths, but I am not sure what to do next. I tried running "ChartWizardLauncher.java" as an eclipse application but get a null pointer exception.
Any help is much appreciated.
RB
ps. Here is the stack trace:
java.lang.NullPointerException at:
org.eclipse.birt.chart.ui.swt.wizard.TaskSelectType.doPreview(TaskSelectType.java:1926)
org.eclipse.birt.chart.ui.swt.wizard.TaskSelectType.createControl(TaskSelectType.java:247)
org.eclipse.birt.core.ui.frameworks.taskwizard.WizardBaseDialog.switchTask(WizardBaseDialog.java:317)
org.eclipse.birt.core.ui.frameworks.taskwizard.WizardBase.switchTo(WizardBase.java:229)
org.eclipse.birt.chart.ui.swt.wizard.ChartWizard.switchTo(ChartWizard.java:280)
org.eclipse.birt.core.ui.frameworks.taskwizard.WizardBaseDialog.initializeBounds(WizardBaseDialog.java:175)
org.eclipse.jface.window.Window.create(Window.java:435)
org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
org.eclipse.birt.core.ui.frameworks.taskwizard.WizardBaseDialog.create(WizardBaseDialog.java:185)
org.eclipse.jface.window.Window.open(Window.java:790)
org.eclipse.birt.core.ui.frameworks.taskwizard.WizardBase.open(WizardBase.java:87)
org.eclipse.birt.chart.ui.swt.wizard.ChartWizard.open(ChartWizard.java:234)
org.eclipse.birt.core.ui.frameworks.taskwizard.WizardBase.open(WizardBase.java:100)
ChartWizardLauncher.launch(ChartWizardLauncher.java:113)
ChartWizardLauncher.main(ChartWizardLauncher.java:187)
Caused By:null
[Updated on: Fri, 09 April 2010 13:38] by Moderator
Re: help with "Chart Builder Example" [message #526357 is a reply to message #526340] Fri, 09 April 2010 15:23 Go to previous messageGo to next message
Try the same project in
http://www.birt-exchange.org/devshare/deploying-birt-reports /1187-eclipsecon-2010-birt-metal-ppt/#description
examples. It is the ChartBuilder project.
Jason
> devShare: [url=http://www.birt-exchange.org/devshare/designing-birt-re
> ports/1184-chart-builder-example/#description][ /url]
> RB
> org.eclipse.birt.chart.ui.swt.wizard.TaskSelectType.doPrevie w(TaskSelectType.java:1926)
> org.eclipse.birt.chart.ui.swt.wizard.TaskSelectType.createCo ntrol(TaskSelectType.java:247)
> org.eclipse.birt.core.ui.frameworks.taskwizard.WizardBaseDia log.switchTask(WizardBaseDialog.java:317)
> org.eclipse.birt.core.ui.frameworks.taskwizard.WizardBase.sw itchTo(WizardBase.java:229)
> org.eclipse.birt.chart.ui.swt.wizard.ChartWizard.switchTo(Ch artWizard.java:280)
> org.eclipse.birt.core.ui.frameworks.taskwizard.WizardBaseDia log.initializeBounds(WizardBaseDialog.java:175)
> org.eclipse.birt.core.ui.frameworks.taskwizard.WizardBaseDia log.create(WizardBaseDialog.java:185)
> org.eclipse.birt.core.ui.frameworks.taskwizard.WizardBase.op en(WizardBase.java:87)
> org.eclipse.birt.chart.ui.swt.wizard.ChartWizard.open(ChartW izard.java:234)
> org.eclipse.birt.core.ui.frameworks.taskwizard.WizardBase.op en(WizardBase.java:100)
> Caused By:null
Re: help with "Chart Builder Example" [message #526612 is a reply to message #526357] Mon, 12 April 2010 08:19 Go to previous messageGo to next message
Thanks, I have it running now.
How do I provide the input data?
RB
Re: help with "Chart Builder Example" [message #526712 is a reply to message #526612] Mon, 12 April 2010 13:06 Go to previous messageGo to next message
Right now that example does not include data mapping using the gui, but
you should be able to take the model that it generates and map data to
it using the SerializerExample in the same download or by looking at the
bindGroupingData function in the code below. I will try to update the
example to support the data selection in the gui.
Jason
import java.awt.Graphics;
import java.awt.Graphics2D;
import java.awt.image.BufferedImage;
import org.eclipse.birt.chart.api.ChartEngine;
import org.eclipse.birt.chart.device.IDeviceRenderer;
import org.eclipse.birt.chart.device.IDisplayServer;
import org.eclipse.birt.chart.exception.ChartException;
import org.eclipse.birt.chart.factory.GeneratedChartState;
import org.eclipse.birt.chart.factory.Generator;
import org.eclipse.birt.chart.factory.IDataRowExpressionEvaluator;
import org.eclipse.birt.chart.factory.IGenerator;
import org.eclipse.birt.chart.factory.RunTimeContext;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.ChartWithAxes;
import org.eclipse.birt.chart.model.ChartWithoutAxes;
import org.eclipse.birt.chart.model.attribute.Anchor;
import org.eclipse.birt.chart.model.attribute.AxisType;
import org.eclipse.birt.chart.model.attribute.Bounds;
import org.eclipse.birt.chart.model.attribute.ChartDimension;
import org.eclipse.birt.chart.model.attribute.DataType;
import org.eclipse.birt.chart.model.attribute.SortOption;
import org.eclipse.birt.chart.model.attribute.impl.BoundsImpl;
import org.eclipse.birt.chart.model.attribute.impl.ColorDefinitionI mpl;
import org.eclipse.birt.chart.model.attribute.impl.GradientImpl;
import org.eclipse.birt.chart.model.component.Axis;
import org.eclipse.birt.chart.model.component.Series;
import org.eclipse.birt.chart.model.component.impl.SeriesImpl;
import org.eclipse.birt.chart.model.data.BaseSampleData;
import org.eclipse.birt.chart.model.data.DataFactory;
import org.eclipse.birt.chart.model.data.OrthogonalSampleData;
import org.eclipse.birt.chart.model.data.Query;
import org.eclipse.birt.chart.model.data.SampleData;
import org.eclipse.birt.chart.model.data.SeriesDefinition;
import org.eclipse.birt.chart.model.data.impl.QueryImpl;
import org.eclipse.birt.chart.model.data.impl.SeriesDefinitionImpl;
import org.eclipse.birt.chart.model.impl.ChartWithAxesImpl;
import org.eclipse.birt.chart.model.impl.ChartWithoutAxesImpl;
import org.eclipse.birt.chart.model.layout.Legend;
import org.eclipse.birt.chart.model.layout.Plot;
import org.eclipse.birt.chart.model.type.LineSeries;
import org.eclipse.birt.chart.model.type.PieSeries;
import org.eclipse.birt.chart.model.type.impl.LineSeriesImpl;
import org.eclipse.birt.chart.model.type.impl.PieSeriesImpl;
import org.eclipse.birt.core.framework.PlatformConfig;
* Test decription:
* </p>
* Chart script: afterDataSetFilled()
* </p>
public class AfterDatasetFilled
private static String OUTPUT = "output/DataRowEvaluator.png";
* The swing rendering device
private IDeviceRenderer dRenderer = null;
private IDisplayServer dServer = null;
private GeneratedChartState gcs = null;
private IGenerator gr = null;
* A chart model instance
private Chart cm = null;
* execute application
* @param args
public static void main( String[] args )
new AfterDatasetFilled( );
System.out.println("finished");
* Constructor
public AfterDatasetFilled( )
PlatformConfig pf = new PlatformConfig();
pf.setProperty("STANDALONE", true);
//Returns a singleton instance of the Chart Engine
ChartEngine ce = ChartEngine.instance(pf);
//Returns a singleton instance of the Generator
gr = ce.getGenerator();
try {
//device renderers for dv.SWT, dv.PNG, dv.JPG
//dv.PDF, dv.SVG, dv.SWING, dv.PNG24, div.BMP
dRenderer = ce.getRenderer("dv.PNG");
dServer = dRenderer.getDisplayServer();
} catch (Exception ex) {
ex.printStackTrace();
cm = createPieChart( );
bindGroupingData( cm );
BufferedImage img = new BufferedImage(
600,
600,
BufferedImage.TYPE_INT_ARGB );
Graphics g = img.getGraphics( );
Graphics2D g2d = (Graphics2D) g;
dRenderer.setProperty( IDeviceRenderer.GRAPHICS_CONTEXT, g2d );
dRenderer.setProperty( IDeviceRenderer.FILE_IDENTIFIER, OUTPUT );
//$NON-NLS-1$
Bounds bo = BoundsImpl.create( 0, 0, 600, 600 );
bo.scale( 72d / dRenderer.getDisplayServer( ).getDpiResolution( ) );
try
gcs = gr.build(
dServer,
cm,
bo,
null,
null,
null );
gr.render( dRenderer, gcs );
catch ( ChartException e )
e.printStackTrace( );
public Chart GetChartModel(){
return cm;
private void bindGroupingData( Chart chart )
//IDataRowExpressionEvaluator
// close, evaluate, first, and next
// Data Set
final Object[][] data =
new Object[][]
{{"x1", new Integer( 1 ), "g1"},
{"x1", new Integer( 2 ), "g2"},
{"x1", new Integer( 3 ), "g1"},
{"x1", new Integer( 4 ), "g3"},
{"x1", new Integer( 5 ), "g2"},
{"x2", new Integer( 6 ), "g1"},
{"x2", new Integer( 7 ), "g3"},
{"x2", new Integer( 8 ), "g2"},
{"x2", new Integer( 9 ), "g2"},
{"x0", new Integer( 0 ), "g2"},};
try
//Binds data to chart model
gr.bindData( new IDataRowExpressionEvaluator( ) {
int idx = 0;
public void close( )
public Object evaluate( String expression )
if ( "X".equals( expression ) )
return data[idx][0];
else if ( "Y".equals( expression ) )
return data[idx][1];
else if ( "G".equals( expression ) )
return data[idx][2];
return null;
public Object evaluateGlobal( String expression )
return evaluate( expression );
public boolean first( )
idx = 0;
return true;
public boolean next( )
idx++;
return ( idx < 9 );
}, chart, new RunTimeContext( ) );
private Chart createChart( )
ChartWithAxes cwaBar = ChartWithAxesImpl.create( );
// X-Axis
Axis xAxisPrimary = cwaBar.getPrimaryBaseAxes( )[0];
xAxisPrimary.setType( AxisType.TEXT_LITERAL );
// Y-Axis
Axis yAxisPrimary = cwaBar.getPrimaryOrthogonalAxis( xAxisPrimary );
yAxisPrimary.setType( AxisType.LINEAR_LITERAL );
// X-Series
Series seCategory = SeriesImpl.create( );
Query xQ = QueryImpl.create( "G" );
seCategory.getDataDefinition( ).add( xQ );
SeriesDefinition sdX = SeriesDefinitionImpl.create( );
xAxisPrimary.getSeriesDefinitions( ).add( sdX );
sdX.getSeries( ).add( seCategory );
sdX.setSorting( SortOption.ASCENDING_LITERAL );
sdX.getGrouping( ).setEnabled( true );
sdX.getGrouping( ).setGroupType( DataType.TEXT_LITERAL );
sdX.getGrouping( ).setAggregateExpression( "Sum" );
sdX.getGrouping( ).setGroupingInterval( 0 );
// Y-Series
LineSeries ls = (LineSeries) LineSeriesImpl.create( );
ls.getLabel( ).setVisible( true );
Query yQ = QueryImpl.create( "Y" );
ls.getDataDefinition( ).add( yQ );
SeriesDefinition sdY = SeriesDefinitionImpl.create( );
Query query = QueryImpl.create( "X" );//$NON-NLS-1$
sdY.setQuery( query );
yAxisPrimary.getSeriesDefinitions( ).add( sdY );
sdY.getSeriesPalette( ).shift( 0 );
sdY.getSeries( ).add( ls );
return cwaBar;
public final static Chart createPieChart( )
ChartWithoutAxes cwoaPie = ChartWithoutAxesImpl.create( );
cwoaPie.setDimension(
ChartDimension.TWO_DIMENSIONAL_WITH_DEPTH_LITERAL );
cwoaPie.setType( "Pie Chart" );
cwoaPie.setSubType( "Standard Pie Chart" );
// Plot
cwoaPie.getBlock( ).setBackground(
ColorDefinitionImpl.WHITE( ) );
Plot p = cwoaPie.getPlot( );
p.getClientArea( )
.setBackground( GradientImpl.create(
ColorDefinitionImpl.create( 225,
225,
255 ),
ColorDefinitionImpl.create( 255, 255,
225 ),
-35,
false ) );
p.getOutline( ).setVisible( true );
// Title
// Legend
Legend lg = cwoaPie.getLegend( );
lg.getText( ).getFont( ).setSize( 16 );
lg.getInsets( ).set( 10, 5, 0, 0 );
lg.setAnchor( Anchor.NORTH_LITERAL );
// Title
cwoaPie.getTitle( ).getLabel( ).getCaption( ).setValue(
"Pie Chart" );
SampleData sdata = DataFactory.eINSTANCE.createSampleData( );
BaseSampleData sdBase =
DataFactory.eINSTANCE.createBaseSampleData( );
sdBase.setDataSetRepresentation( "" );
sdata.getBaseSampleData( ).add( sdBase );
OrthogonalSampleData sdOrthogonal =
DataFactory.eINSTANCE.createOrthogonalSampleData( );
sdOrthogonal.setDataSetRepresentation( "" );
sdOrthogonal.setSeriesDefinitionIndex( 0 );
sdata.getOrthogonalSampleData( ).add( sdOrthogonal );
cwoaPie.setSampleData( sdata );
// Base Series
// X-Series
SeriesDefinition sd = SeriesDefinitionImpl.create( );
seCategory.setSeriesIdentifier("cs2");
seCategory.getDataDefinition( ).add( query );
cwoaPie.getSeriesDefinitions( ).add( sd );
sd.getSeriesPalette( ).shift( 0 );
sd.getSeries( ).add( seCategory );
// Orthogonal Series
PieSeries sePie = (PieSeries) PieSeriesImpl.create( );
sePie.setSeriesIdentifier( "Events");
Query query1 = QueryImpl.create("Y");//$NON-NLS-1$
sePie.getDataDefinition().add(query1);
sePie.setExplosion( 5 );
sePie.getLabel().setVisible(true);
SeriesDefinition sd2 = SeriesDefinitionImpl.create( );
sd.getSeriesDefinitions( ).add( sd2 );
sd2.getSeries( ).add( sePie );
return cwoaPie;
> RB
Re: help with "Chart Builder Example" [message #526733 is a reply to message #526712] Mon, 12 April 2010 14:31 Go to previous messageGo to next message
Thanks for the information, I will have to look at it more closely.
I was originally tasked with creating some reports, which was easy enough. However my user wants a great variety of graphs with varying levels of customization so I thought giving them the chart builder would be the way to go. Unfortunately, I am not a developer and understanding the API's and the plugin architecture is proving to be rather difficult (and time consuming). So, I thank you very much for your help.
RB
Re: help with "Chart Builder Example" [message #1097576 is a reply to message #526357] Thu, 29 August 2013 18:59 Go to previous messageGo to next message
I am having the same problem mentioned here. I tried to go to the address mentioned, but looks like the link is broken. Can you please help?
On a side note, this is what I am trying to do, can you please let me know if this makes sense?
Create some chart models (template) using the chart builder.
Use this models in my standalone java application and then build the data set at runtime.
Dynamically update the dataset, and bind it to the chart models.
Build the chart and render it.
Deb
Re: help with "Chart Builder Example" [message #1098437 is a reply to message #1097576] Sat, 31 August 2013 00:08 Go to previous message
Here are updated links for both of the links above.
http://www.birt-exchange.org/devshare/_/designing-birt-reports/1184-chart-builder-example
http://www.birt-exchange.org/devshare/_/designing-birt-reports/1187-eclipsecon-2010-birt-metal-ppt
As for your scenario, are you going to just be using the Chart Engine? Or building report templates?
Previous Topic:Concatenate Show All Values
Next Topic:How to call BIRT report
Current Time: Sat Jul 19 10:59:35 EDT 2025
Powered by FUDForum. Page generated in 0.25223 seconds
