Home » Modeling » Graphiti » Custom DirectEditManager
Custom DirectEditManager [message #1097875] Fri, 30 August 2013 05:20 Go to next message
Hi all,
how is it possible to change the GFDirectEditManager with a custom implementation?
Andreas
Re: Custom DirectEditManager [message #1097948 is a reply to message #1097875] Fri, 30 August 2013 07:32 Go to previous messageGo to next message
Without using a locally patched version of graphiti, I'd say it's not possible.
However, the current implementation is customizable via the associated IDirectEditingFeature. What are you trying to achieve?
Re: Custom DirectEditManager [message #1097962 is a reply to message #1097948] Fri, 30 August 2013 07:57 Go to previous messageGo to next message
Hi Felix,
thanks for the quick reply.
I created a Xtext Integration for graphical editors some time ago, see http://muelder.blogspot.de/2011/04/xtext-celleditor-integration.html for an example.
This integration adds code completion, syntax higlighting, validation etc. to the direct editor. Technically, it is implemented as a custom implementation of GEFs DirectEditManager and works well with GEF & GMF. For a new project I am evaluating Graphiti as a replacement of GMF and Xtext integration is a major requirement.
No chance to hook into an editpart factory to replace ShapeEditPart#bringUpDirectEditField without patching graphiti?
Andreas
Re: Custom DirectEditManager [message #1097970 is a reply to message #1097962] Fri, 30 August 2013 08:15 Go to previous messageGo to next message
Le 30/08/13 13:57, Andreas Muelder a écrit :> Hi Felix,
> an example.
> Best regards,
> Andreas
I saw your post a month ago and also wanted to integrate XtexCellEditor
in my Graphiti Editor. It works well with the XtextCellEditor from the
Yakindu Project.
Here is my code for my DirectEditingFeature :
// some imports...
import de.itemis.utils.jface.viewers.StyledTextCellEditor;
import de.itemis.xtext.utils.jface.viewers.XtextStyledTextCellEditor;
// other imports...
public class MyDirectEditFeature extends
		AbstractDirectEditingFeature implements ICellEditorProvider {
Rectangle rectangle = null; // initialized in my canDirectEdit Method
public int getEditingType() {
	return TYPE_CUSTOM;
public CellEditor createCellEditor(Composite parent) {
	StyledTextCellEditor cellEditor;
	Injector myInjector = MyDslActivator.getInstance().getInjector("myDSL")
	cellEditor = new XtextStyledTextCellEditor(SWT.SINGLE, myInjector);
	cellEditor.create(parent);
	StyledText text = (StyledText) cellEditor.getControl();
	text.setBounds(rectangle);
	return cellEditor;
public void relocate(CellEditor cellEditor, IFigure figure) {
	// Nothing
Nicolas H
Re: Custom DirectEditManager [message #1097987 is a reply to message #1097970] Fri, 30 August 2013 08:37 Go to previous message
Hi Nicolas,
thank you very much for the snippet, I will give it a try. You are right, it should be sufficient to replace the CellEditor instead of the DirectEditManager.
Andreas
Previous Topic:Zoom
Next Topic:Restrain features in the Diagram View Example
Current Time: Sun Jul 20 18:24:23 EDT 2025
Powered by FUDForum. Page generated in 0.04445 seconds
