Home » Eclipse Projects » BPMN 2.0 Modeler » Initial point of a Sequence Flow
Initial point of a Sequence Flow [message #1095101] Mon, 26 August 2013 12:21 Go to next message
I'm creating a process diagram and I'm facing a small problem.
I would like to change the initial point of a Sequence Flow but I'm not able to do.
As showed in the image below I would like to connect the last node in the first row with the first node of the second row, but everywhere I drop the initial point it always go to the left side of the task node.
https://www.dropbox.com/s/5scjhip7xpp6w7w/Screen%20Shot%202013-08-26%20at%2012.56.17.png
is there a way to do what I want?
thanks,
Cristiano
Re: Initial point of a Sequence Flow [message #1096641 is a reply to message #1095101] Wed, 28 August 2013 13:18 Go to previous message
Bummer Sad
I've create a bug report here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=416076
Previous Topic:Delete unused MessageFlows ?
Next Topic:extend SequenceFlow
Current Time: Sun Jul 20 10:24:44 EDT 2025
Powered by FUDForum. Page generated in 0.77736 seconds
