Home » Eclipse Projects » Equinox » osgi always terminates
osgi always terminates [message #109031] Fri, 02 May 2008 08:36 Go to next message
Originally posted by: ekkehard.gentz-software.de
OSX, Java 1.5, Eclipse 3.3.2
I can launch OSGI outside eclipse using
java -jar plugins/org.eclipse.osgi_3.3.2.R33x_v20080105.jar -console -clean
with no problem.
but if I create a simple osgi launch config,
only bundle org.eclipse.osgi marked
program arguments: -console -clean
vm arguments: -Declipse.ignoreApp=true -Dosgi.noShutdown=true
and let it Run, then it starts,
>OSGI appears on the console
but soon after this the console terminates
any ideas, what could be wrong ?
I know that I made it in the past ;-)
thx
ekke
Re: osgi always terminates [message #109071 is a reply to message #109031] Fri, 02 May 2008 10:15 Go to previous messageGo to next message
This looks good to me. Perhaps try "clearing the configuration before
launching" on the Settings tab
Failing that try debugging through EclipseStarter main and run and you'll
probably be able to figure out the problem pretty quickly.
-Simon
"ekke" <ekkehard@gentz-software.de> wrote in message
news:2c5e36b9204ab65c0d0f667f88330c57$1@www.eclipse.org...
> java -jar
> with no problem.
> thx
> ekke
Re: osgi always terminates [message #109083 is a reply to message #109071] Sat, 03 May 2008 05:53 Go to previous messageGo to next message
Simon,
thanks for your answer - I did some more tests:
* running osgi from Java app using EclipseStarter.startup()
works well
but running the OSGI launch config still doesnt work,
debugged the EclipseStarter and all looks well
then tried running the apple JDK 6.0 on OSX
same result: osgi console terminated
then did exactly the same configuration on windows in my parallels vm -
and there all OSGI launch configs run well
so there must be a difference between OSX and windows
any idea ?
thx for help
ekke
> -Simon
>> java -jar
>> with no problem.
>> thx
>> ekke
Re: osgi always terminates [message #109095 is a reply to message #109083] Sat, 03 May 2008 17:12 Go to previous messageGo to next message
All I can think of is either something funky going on in the console or bad
file permissions.
We're in the final stages of 3.4 now, could you please try to see if you can
reproduce what you're seeing in 3.4M7.
If so log a bug against the framework.
Thanks.
-Simon
news:58137acb9bdc65c30c43d764fc6f1da4$1@www.eclipse.org...
> Simon,
> works well
> any idea ?
> thx for help
> ekke
>> -Simon
>>> java -jar
>>> with no problem.
>>> thx
>>> ekke
Re: osgi always terminates [message #109109 is a reply to message #109095] Sun, 04 May 2008 04:59 Go to previous messageGo to next message
thx simon,
I'll test it again with 3.4M7 and if it still happens,
I'll report a bug
ekke
Re: osgi always terminates [message #109118 is a reply to message #109109] Sun, 04 May 2008 05:25 Go to previous message
hi simon,
just tested against 3.4M7
all works as expected :-)
no problem for me because I'm just in the process switching my dev
environment to 3.4
thx again for help
ekke
Previous Topic:NullPointer exception while installing (possibly incompatible) plugin
Next Topic:Running a servlet under Eclipse 3.2 workbench
Current Time: Sat Jul 19 07:57:58 EDT 2025
Powered by FUDForum. Page generated in 0.06696 seconds
