Home » Modeling » OCL » ocl strange behavior!
ocl strange behavior! [message #1088318] |
Fri, 16 August 2013 19:01  |
I want to perform an OCL check on a java model programmatically. I am using
IQueryResult to execute my query statement. Everything was working fine but
now I am facing umpredictable behavior and what was working before isn't
working anymore.
For example, the evaluation of the following query statement does not give
the correct result:
self.oclAsType(class).members->select(ocl expression)............
the same when I use "for loop statement":
Sequence{1..n}->any(ocl expression)
or
Sequence{1..n}->select(ocl expression)
this is weird because in my ocl query statements, the part before
operations on collections such as (select() and any()) is evaluated and
gives exactlly
what I am expecting. Before the "x event", the evaluation was performed as
expected, but now I don't know what happened!Does anyone know what is the
problem and why collection's ocl opertions aren't working!?. Thanks in
advance.
Chadi
Re: ocl strange behavior! [message #1089379 is a reply to message #1088318] |
Sun, 18 August 2013 12:53   |
Since it was working and is no longer, you have probably done something
stupid, which is very unlikely to be diagnoseable from the minute hints
that you have given. You need to examine what changed, perhaps going
back to what was working, then progressing forward in smaller steps.
Ed Willink
On 17/08/2013 00:01, Sohaib wrote:
> using IQueryResult to execute my query statement. Everything was
> working fine but now I am facing umpredictable behavior and what was
> working before isn't working anymore.
> give the correct result:
> or
> and gives exactlly
> performed as expected, but now I don't know what happened!Does anyone
> know what is the problem and why collection's ocl opertions aren't
> working!?. Thanks in advance.
> Regards,
> Chadi
Re: ocl strange behavior! [message #1090911 is a reply to message #1089379] |
Tue, 20 August 2013 16:37   |
I examined my query statement and, as I said before, some parts that used to
work before ain't working although I haven't changed anything. this is a
part from my query (returns substring. example: List[] gives List):
I tried:
"_string.substring(1,4) " works
"_string.substring(1,(Sequence{1..6}->select(c|c=5)->first())-1) " fails
"_string.substring(1,(Sequence{1..6}->any(c|c=5))-1) " fails
"_string.substring(1,(Sequence{1..6}->size())-2) " works
Chadi
Ed Willink
> using IQueryResult to execute my query statement. Everything was working
> fine but now I am facing umpredictable behavior and what was working
> the correct result:
> or
> gives exactlly
> as expected, but now I don't know what happened!Does anyone know what is
> the problem and why collection's ocl opertions aren't working!?. Thanks
> in advance.
> Regards,
> Chadi
[Updated on: Tue, 20 August 2013 20:30] by Moderator
Re: ocl strange behavior! [message #1090920 is a reply to message #1090911] |
Tue, 20 August 2013 16:50   |
What help do you want?
Try reading your email and you might realise why I cannot help.
Ed Willink
On 20/08/2013 21:37, Sohaib wrote:
> Hi
> used to
> I tried:
> Regards
> Chadi
> "Ed Willink" a écrit dans le message de groupe de discussion :
> kuqu79$ltt$1@xxxxxxxxe.org...
> Hi
> Regards
> Ed Willink
>> Hi,
>> or
>> and gives exactlly
>> Regards,
>> Chadi
Re: ocl strange behavior! [message #1091390 is a reply to message #1090911] |
Wed, 21 August 2013 08:41   |
Hi, Chadi,
I think the syntax for integer ranges is simply
1..6
not
Sequence{1..6}
The latter creates a singleton sequence containing a sequence. i.e.,
it is equivalent to
Sequence{ Sequence{1, 2, 3, 4, 5, 6} }
HTH,
Christian
On 2013-08-20 20:37:59 +0000, Sohaib said:
> Hi
> I tried:
> Regards
> Chadi
> Hi
> Regards
> Ed Willink
>> Hi,
>> or
>> gives exactlly
>> Regards,
>> Chadi
Re: ocl strange behavior! [message #1091408 is a reply to message #1091390] |
Wed, 21 August 2013 09:10   |
Hi Christian
You had me worried for a moment.
No. 1..6 is the syntax for a CollectionRangeCS which is a
CollectionLiteralPartCS that may contribute to a CollectionLiteralExpCS.
So any of Set{1..6}, Sequence{1..6} or OrderedSet{1..6} are viable
Sequence{1..6} is just a shorthand for Sequence{1, 2, 3, 4, 5, 6}.
So this is unlikely to be the problem.
Ed
On 21/08/2013 13:41, Christian W. Damus wrote:
> Hi, Chadi,
> 1..6
> not
> Sequence{1..6}
> it is equivalent to
> HTH,
> Christian
>> Hi
>> used to
>> I tried:
>> Regards
>> Chadi
>> Hi
>> Regards
>> Ed Willink
>>> Hi,
>>> am using IQueryResult to execute my query statement. Everything was
>>> not give the correct result:
>>> or
>>> and gives exactlly
>>> anyone know what is the problem and why collection's ocl opertions
>>> aren't working!?. Thanks in advance.
>>> Regards,
>>> Chadi
Re: ocl strange behavior! [message #1091432 is a reply to message #1090920] |
Wed, 21 August 2013 08:39   |
my question is: besides writing a wrong query statement, are there any other
reasons that may cause my evaluation to fail? this is the same example (of
what I am stuck with) I gave before:
" 'List[]'.substring(1,4)" output:"List" works
'List[]'.substring(1,(Sequence{1..'List[]'.size()}->select(c|'List[]'.substring(c,c)='[')->first())-1)"
fails
'List[]'.substring(1,Sequence{1..'List[]'.size()}->any(c|'List[]'.substring(c,c)='[')-1)"
fails
I hope my question is clearer now!
chadi
>Hi
> Regards
> Ed Willink
> Hi
> to
> I tried:
> Regards
> Chadi
> Hi
> Regards
> Ed Willink
>> Hi,
>> or
>> gives exactlly
>> in advance.
>> Regards,
>> Chadi
Re: ocl strange behavior! [message #1091436 is a reply to message #1091408] |
Wed, 21 August 2013 09:45   |
Hi, Ed,
Thanks. That serves me right for trusting my rusty OCL knowledge! :-)
cW
On 2013-08-21 13:10:59 +0000, Ed Willink said:
> Hi Christian
> Regards
> Ed
>> Hi, Chadi,
>> 1..6
>> not
>> Sequence{1..6}
>> The latter creates a singleton sequence containing a sequence. i.e., it
>> is equivalent to
>> HTH,
>> Christian
>>> Hi
>>> I tried:
>>> Regards
>>> Chadi
>>> Hi
>>> Regards
>>> Ed Willink
>>>> Hi,
>>>> or
>>>> gives exactlly
>>>> Regards,
>>>> Chadi
Re: ocl strange behavior! [message #1092215 is a reply to message #1091684] |
Thu, 22 August 2013 09:29   |
Hi Ed
My ocl expression is syntactically correct. I show you in a previous example that when I use "'List[]'.substring(1,4)" it works, no problem. but when I replace it by
"'List[]'.substring(1,(Sequence{1..'List[]'.size()}->select(c|'List[]'.substring(c,c)='[')->first())-1)"
or
"'List[]'.substring(1,Sequence{1..'List[]'.size()}->any(c|'List[]'.substring(c,c)='[')-1)"
it does not work. I cannot find a syntax error! I cannot explain this behavior! if you have noticed a syntax error in those two expressions, please guide me, otherwise, what kind of information do you want? What do you need explained more clearly? I am not the expert here! may be you want more details? if so, what exactlly? Should I attach the whole project? Thank you for any help you can provide
regards
chadi
Re: ocl strange behavior! [message #1092270 is a reply to message #1092215] |
Thu, 22 August 2013 10:48   |
When I type any of your three expressions into either Classic or Xtext
OCL Console I get the result 'List'.
But you didn't say what constituted a problem for you so who knows?
Ed Willink
On 22/08/2013 14:29, chadi assem wrote:
> Hi Ed
> or
> regards
> chadi
Re: ocl strange behavior! [message #1092477 is a reply to message #1092270] |
Thu, 22 August 2013 17:22   |
Hi Ed
what constitutes a problem for me is the fact that when I replace my first expression ("'List[]'.substring(1,4)") by one of the two other expressions my query does not work (I use IQueryResult). One last question. Couldn't be that using these two expression (select() and any()) within a if-else statemant or a forall() operation causes this behavior (affect the iteration)?
chadi
Ed Willink wrote on Thu, 22 August 2013 10:48Hi
Ed Willink
> Hi Ed
> or
> regards
> chadi
Re: ocl strange behavior! [message #1092729 is a reply to message #1092477] |
Fri, 23 August 2013 02:19   |
You still don't say what you mean by does not work.
Does your machine catch fire?
Does your Skype connection drop out?
Throw an exception
Give a result different to your unstated expectation
It saves everyone a lot of wasted time if you provide a repro. e.g. a
zipped project with a launch configuration.
Ed Willink
On 22/08/2013 22:22, chadi assem wrote:
> Hi Ed
> Regards
> chadi
>> Hi
>> Xtext OCL Console I get the result 'List'.
>> Regards
>> Ed Willink
>> > Hi Ed
>> previous > example that when I use "'List[]'.substring(1,4)" it
>> works, no > problem. but when I replace it by
>> > or
>> this > behavior! if you have noticed a syntax error in those two
>> expressions, > please guide me, otherwise, what kind of information
>> do you want? What > do you need explained more clearly? I am not the
>> expert here! may be > you want more details? if so, what exactlly?
>> Should I attach the whole > project? Thank you for any help you can
>> provide
>> > regards
>> > chadi
Re: ocl strange behavior! [message #1096856 is a reply to message #1092729] |
Wed, 28 August 2013 20:14  |
Hi Ed
sorry for the late reply, I've just been so Busy Lately. About my problem, I found
that the iterator I've used in both expressions (iterator c) is already used in my
query (in an outer loop ). Thanx anyway for your time
Chadi
> Hi
> Throw an exception
> Regards
> Ed Willink
>> Hi Ed
>> Regards
>> chadi
>>> Hi
>>> > Regards
>>> > Ed Willink
>>>> > Hi Ed
>>>> >[]'.substring
>>>> > or
>>>> >(c,c)='[')-1)"
>>>> > provide
>>>> > regards
>>>> > chadi
Current Time: Sat Jul 19 16:23:28 EDT 2025
Powered by FUDForum. Page generated in 0.48563 seconds
