Home » Modeling » OCL » Custom Validation Message & Severity(UML constraint)
Custom Validation Message & Severity [message #1090652] Tue, 20 August 2013 08:59 Go to next message
Hi there,
I tried to add custom validation message and custom severity for constraints in UML2.
After reading this topic and the tutorial, I'm confused. If I well understood, it is not possible to customize validation message and severity for a UML constraint. Am I right ? Here is I have done:
  1. I desgigned a UML metamodel using the documentation available here.
  2. I added somes OCL contraints thanks to the UML element Constraint and OpaqueExpression
  3. I generated genmodel and ecore model from this point.
  4. I generated the model, edit, editor and test code. Constraints are well validated without customization.
Then, I tried several things :
  1. In my ecore generated file, I add for each Detail Entry of "OCL" EAnnotation whose key is "body" a second Detail Entry whose key is "body$message" and the provided message. Didn't do anything when the code is generated.
  2. I try to suffix the invariant name with the message between brackets, when opening the ecore model with OCLinEcore Editor. When I saved, close and re-open the OCLinEcore Editor, the suffix is disappeared.
  3. I tried to use the DSML Validation Profile from Papyrus. Didn't do anything.
If I well undestood, I can customize validation message from either OCLinEcore or CompleteOCL only for native Ecore model, but not for generated Ecore model from UML Metamodel. Is that true ?
Does anybody have a hook to use this ?
Thanks in advance,
yours,
Nicolas
Re: Custom Validation Message & Severity [message #1090674 is a reply to message #1090652] Tue, 20 August 2013 09:37 Go to previous messageGo to next message
Unfortunately the Bugzilla patch to enable EMF to support custom
validation messages remains uncommitted so you must use an
OCLinEcoreEObjectValidator as described in the documentation.
If you are losing Ecore content please submit a Bugzilla with a repro.
The OCLinEcore approach is inflexible and not extensible so I proposed
an approach based on a Tuple return, however that won't be in OCL 2.4
since it is an extension rather than a clarification. We will probably
pursue it for Eclipse OCL so that it works for UML too.
Ed Willink
On 20/08/2013 13:59, nicolas h wrote:
> Hi there,
> After reading
> http://www.eclipse.org/forums/index.php/m/30076/?srch=custom+validation+message#msg_30076
> and the
> http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.ocl.doc%2Fhelp%2FIntegration.html&cp=42_1_7_1&anchor=Integration-Messages.,
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=77413.
> OpaqueExpression
> code is generated.
> anything.
> Thanks in advance,
> yours,
Re: Custom Validation Message & Severity [message #1090703 is a reply to message #1090674] Tue, 20 August 2013 10:21 Go to previous messageGo to next message
Hi ed,
Thanks for your fast reply,
Ed Willink wrote on Tue, 20 August 2013 09:37
I did not notice this part of the documentation. I'll try to understand how it's work.
Why do you mean about "losing Ecore content" ? Did you refer to the non-persistence of the invariant name when I open my Ecore model with OCLInEcore Editor ?
Yeah, I found your post (I no longer manage to lay hands on this post) about it but I did not understand how to implement this. I naively thought that I could replace inside my UML metamodel my opaque expression body, containing the OCL constraint, by the tuple, and get during the validation the different part of the constraint, but it seems not so easy Smile
Nicolas
Re: Custom Validation Message & Severity [message #1090708 is a reply to message #1090703] Tue, 20 August 2013 10:29 Go to previous messageGo to next message
> OCLInEcore Editor ?
If you had something in your model and an editor discarded it without
your permission then we need to fix a bug.
>> proposed an approach based on a Tuple return, however that won't be
>> in OCL 2.4 since it is an extension rather than a clarification. We
>> will probably pursue it for Eclipse OCL so that it works for UML too.
> seems not so easy :)
There is no point you using it until the underlying implementation is
there, which will probably happen in the next month in time for M2 and
an Eclipse OCL 4.2.0 release.
Ed Willink
Re: Custom Validation Message & Severity [message #1091394 is a reply to message #1090708] Wed, 21 August 2013 08:48 Go to previous message
Ed Willink wrote on Tue, 20 August 2013 10:29
> OCLInEcore Editor ?
Done. I raised a bug in the Bugzilla here.
Thanks for your answer. I'll wait for the OCL 4.2.0 release Wink
Nicolas
Previous Topic:[Announce] Eclipse OCL 4.1.1 RC1 and OCL 4.2.0 M1 are available.
Next Topic:Eclipse OCL
Current Time: Sat Jul 19 12:28:32 EDT 2025
Powered by FUDForum. Page generated in 0.03989 seconds
