Home » Eclipse Projects » Remote Application Platform (RAP) » Graphical Problem with DateTime widget
Graphical Problem with DateTime widget [message #108959] Mon, 13 October 2008 09:27 Go to next message
I have a problem using the DateTime widget.
When using the SWT.TIME style the numbers in the widget are cut on their
right side so that only one part of them is displayed. I tried resizing
the widget but that doesn't help.
Any advice what I can do regarding this problem?
Thanks in advance,
Gunnar
Re: Graphical Problem with DateTime widget [message #108975 is a reply to message #108959] Mon, 13 October 2008 09:39 Go to previous messageGo to next message
Originally posted by: ifurnadjiev.innoopract.com
Hi Gunnar,
what browser/OS do you use? What is the browser locale? Try to reload
the page - is this fix the problem?
Best,
Ivan
Gunnar Wurl wrote:
> their right side so that only one part of them is displayed. I tried
> resizing the widget but that doesn't help.
> Thanks in advance,
> Gunnar
Re: Graphical Problem with DateTime widget [message #108987 is a reply to message #108975] Mon, 13 October 2008 09:52 Go to previous messageGo to next message
Thanks for the quick answer Ivan,
I am using firefox 3.0.3 and Internet Explorer 7.
Both have the problem.
What do you mean with browser locale?
Refreshing solved the problem, but how can it be done from the start?
Thanks again,
Gunnar
Re: Graphical Problem with DateTime widget [message #109000 is a reply to message #108987] Mon, 13 October 2008 10:23 Go to previous messageGo to next message
Hi Gunnar,
the problem occurs only the first time, since the textsize determination
does an educated guess the first time.
Best,
Ivan
> Thanks again,
> Gunnar
Re: Graphical Problem with DateTime widget [message #109012 is a reply to message #109000] Mon, 13 October 2008 11:06 Go to previous messageGo to next message
Well is there a workaround, so that the size is showed correct at first
time?
Ivan Furnadjiev wrote:
> Hi Gunnar,
> Best,
> Ivan
Re: Graphical Problem with DateTime widget [message #109038 is a reply to message #109012] Mon, 13 October 2008 12:00 Go to previous messageGo to next message
Hi Gunnar,
can you provide a snippet that reproduce it? It will be very helpful,
because in the Control Demo the DateTime text size is calculated correct.
Best,
Ivan
> first time?
>> Hi Gunnar,
>> Best,
>> Ivan
Re: Graphical Problem with DateTime widget [message #109078 is a reply to message #109038] Tue, 14 October 2008 04:27 Go to previous messageGo to next message
Yes sure,
it is just a simple shell containing the DateTime widget.
public class Application implements IEntryPoint {
public int createUI() {
Display display = new Display();
display.getThread().setPriority(Thread.MAX_PRIORITY);
Shell shell = new Shell( display, SWT.SHELL_TRIM );
shell.setLayout( new FillLayout() );
shell.setText( "DATE-TIME TEST" );
new DateTime( shell, SWT.TIME | SWT.BORDER );
shell.setSize( 300, 300 );
shell.open();
while( !shell.isDisposed() )
if( !display.readAndDispatch() )
display.sleep();
return 0;
Thanks in advance,
Gunnar
> Hi Gunnar,
> Best,
> Ivan
Re: Graphical Problem with DateTime widget [message #109114 is a reply to message #109078] Tue, 14 October 2008 06:42 Go to previous message
Hi Gunnar,
It seems that there is a problem with DateTime widget in FillLayout.
Please file a bug for easy status tracking.
Best,
Ivan
Previous Topic:embedding HTML and convert normal link as SWT Link
Next Topic:shortcut and/or bookmark of app
Current Time: Sun Jul 20 01:51:25 EDT 2025
Powered by FUDForum. Page generated in 0.05827 seconds
