Home » Modeling » OCL » Eclipse OCL
Eclipse OCL [message #1089863] Mon, 19 August 2013 06:54 Go to next message
I Need help in evaluating ocl constraints on uml model using eclipse OCL ,I could not find OCLHelper methods for uml model...
Re: Eclipse OCL [message #1090137 is a reply to message #1089863] Mon, 19 August 2013 15:00 Go to previous messageGo to next message
Try reading the documentation and following the tutorials.
Ed Willink
Re: Eclipse OCL [message #1090539 is a reply to message #1090137] Tue, 20 August 2013 05:33 Go to previous messageGo to next message
i tried following tutorials and documentation but i am stuck because i am trying to validate uml model through eclipse ocl whereas the setContext method of OCLHelper requires a EClassifier. here is my code:
URI model = URI.createURI(ur);
String transDir = "EMF_lib\\";
URIConverter.URI_MAP.put(URI.createURI("platform:/plugin/org.eclipse.uml2.uml/"),
URI.createURI("jar:file:" + transDir + "org.eclipse.uml2.uml_3.1.2.v201010261927.jar!/"));
registerPackages(RESOURCE_SET);
registerResourceFactories();
URI uri = URI.createURI("jar:file:"+ transDir+"/org.eclipse.uml2.uml.resources-3.1.0.v201005031530.jar!/");
registerResources(uri, RESOURCE_SET);
Resource resource = null;
try {
resource = RESOURCE_SET.getResource(model, true);
catch (Exception e) {
e.printStackTrace();
Model _model = (Model)EcoreUtil.getObjectByType(resource.getContents(),
UMLPackage.Literals.PACKAGE);
EList<PackageableElement> sourcePackagedElements = _model.getPackagedElements();
for (PackageableElement sourceElement : sourcePackagedElements)
// create an OCL instance for Ecore
if (sourceElement.eClass() == UMLPackage.Literals.CLASS)
if(sourceElement.getName().contentEquals("Meeting"))
try
org.eclipse.ocl.OCL ocl = OCL.newInstance(new UMLEnvironmentFactory(RESOURCE_SET));
org.eclipse.ocl.helper.OCLHelper helper1 = ocl.createOCLHelper();
helper1.setContext(org.eclipse.ocl.uml.util.OCLUMLUtil.getMetaclass(_model));
OCLExpression query=(OCLExpression) helper1.createQuery("Meeting.allInstances()->select(m|m.start>5 )->size() > 3 ");
//OCLExpression query = (OCLExpression) helper1.createQuery("self.books->collect(b : Book | b.category)->asSet()");
System.out.println(sourceElement.getName());
// create a Query to evaluate our query expression
// Query queryEval = (Query) ocl.createQuery(query);
} catch (ParserException e) {
catch(Exception e)
It gives me the following exception:
Re: Eclipse OCL [message #1090592 is a reply to message #1090539] Tue, 20 August 2013 07:14 Go to previous messageGo to next message
It clearly isn't your code since I see no import statements or main program.
At a quick glance I see
which makes me extremely ill. Qualified plugin names should never appear
in code.
I suggest you try following the basic UML2 Java tutorials.
Ed Willink
> try {
> Model _model =
> try
> )->size() > 3 ");
> catch(Exception e)
Re: Eclipse OCL [message #1091152 is a reply to message #1090592] Wed, 21 August 2013 01:26 Go to previous messageGo to next message
I m trying to run a simple OCL example for uml model with hard coded paths for now and there is no problem with UML2 java implementation as the model is loaded correctly.I get exception with setcontext() method of helper class. here is my detailed code :
import java.io.File;
import java.util.Map;
import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EcorePackage;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.URIConverter;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.emf.mapping.ecore2xml.Ecore2XMLPackage;
import org.eclipse.emf.mapping.ecore2xml.util.Ecore2XMLResource;
import org.eclipse.ocl.ParserException;
import org.eclipse.ocl.helper.OCLHelper;
import org.eclipse.ocl.uml.UMLEnvironmentFactory;
import org.eclipse.uml2.uml.Model;
import org.eclipse.uml2.uml.PackageableElement;
import org.eclipse.uml2.uml.UMLPackage;
import org.eclipse.uml2.uml.resource.UML22UMLResource;
import org.eclipse.uml2.uml.resource.UMLResource;
public class test {
protected final ResourceSet RESOURCE_SET = new ResourceSetImpl();
public static void registerPackages(ResourceSet resourceSet) {
Map packageRegistry = resourceSet.getPackageRegistry();
packageRegistry.put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE);
packageRegistry.put(Ecore2XMLPackage.eNS_URI, Ecore2XMLPackage.eINSTANCE);
packageRegistry.put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
packageRegistry .put("http://www.eclipse.org/uml2/2.1.0/UML",UMLPackage.eINSTANCE);
packageRegistry .put("http://www.eclipse.org/uml2/3.0.0/UML",UMLPackage.eINSTANCE);
public static void registerPathmaps(URI uri, ResourceSet resourceSet) {
Map<URI, URI> uriMap = resourceSet.getURIConverter().getURIMap();
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uri.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uri.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri.appendSegment("profiles").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.UML_PRIMITIVE_TYPES_LIBRARY_URI), uri.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI("pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml"),
uri.appendSegment("libraries").appendSegment("UMLPrimitiveTypes.library.uml"));
public static void registerResources(URI uri, ResourceSet resourceSet)
registerPathmaps(uri, resourceSet);
registerPackages(resourceSet);
public static void registerResourceFactories() {
Map<String, Object> extensionFactoryMap = Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap();
extensionFactoryMap.put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
extensionFactoryMap.put(Ecore2XMLResource.FILE_EXTENSION, Ecore2XMLResource.Factory.INSTANCE);
extensionFactoryMap.put(UML22UMLResource.FILE_EXTENSION, UML22UMLResource.Factory.INSTANCE);
extensionFactoryMap.put(UMLResource.FILE_EXTENSION, UML22UMLResource.Factory.INSTANCE);
void process(String ur)
try {
UMLPackage.Literals.MODEL);
try
org.eclipse.ocl.uml.OCL ocl = org.eclipse.ocl.uml.OCL.newInstance(new UMLEnvironmentFactory(RESOURCE_SET));
org.eclipse.ocl.uml.OCLExpression query = (org.eclipse.ocl.uml.OCLExpression) helper1.createQuery("Meeting.allInstances()->select(m|m.start>5 )->size() > 3");
System.out.println(ocl.evaluate(_model, query));
catch(Exception e)
public static void main(String[] args) throws Exception
File f=new File("C:/Users/Maham/workspace/OCLSolver/examples/example1/uml file/testclass.uml");
String uri = f.toURI().toString();
test obj=new test();
obj.process(uri);
I get the following Exception trace starting from line ' helper1.setContext(org.eclipse.ocl.uml.util.OCLUMLUtil.getMetaclass(_model))':
Exception in thread "main" java.lang.ExceptionInInitializerError
at org.eclipse.ocl.uml.UMLPackage$Literals.<clinit>(UMLPackage.java:14517)
at org.eclipse.ocl.uml.impl.VariableImpl.eStaticClass(VariableImpl.java:184)
at org.eclipse.emf.ecore.impl.MinimalEObjectImpl.eClass(MinimalEObjectImpl.java:688)
at org.eclipse.emf.ecore.impl.ENotificationImpl.getFeature(ENotificationImpl.java:394)
at org.eclipse.emf.ecore.util.ECrossReferenceAdapter.selfAdapt(ECrossReferenceAdapter.java:436)
at org.eclipse.uml2.common.util.CacheAdapter.selfAdapt(CacheAdapter.java:534)
at org.eclipse.emf.ecore.util.ECrossReferenceAdapter.notifyChanged(ECrossReferenceAdapter.java:424)
at org.eclipse.uml2.common.util.CacheAdapter.notifyChanged(CacheAdapter.java:342)
at org.eclipse.uml2.uml.internal.impl.ElementImpl.eNotify(ElementImpl.java:970)
at org.eclipse.uml2.uml.internal.impl.NamedElementImpl.setName(NamedElementImpl.java:268)
at org.eclipse.ocl.uml.internal.UMLReflectionImpl.setName(UMLReflectionImpl.java:754)
at org.eclipse.ocl.AbstractEnvironmentFactory.createClassifierContext(AbstractEnvironmentFactory.java:138)
at org.eclipse.ocl.internal.helper.OCLHelperImpl.setContext(OCLHelperImpl.java:119)
at org.eclipse.ocl.uml.OCLHelperImpl.setContext(OCLHelperImpl.java:125)
at org.eclipse.ocl.uml.OCLHelperImpl.setContext(OCLHelperImpl.java:1)
at test.process(test.java:102)
at test.main(test.java:125)
at org.eclipse.ocl.uml.impl.UMLPackageImpl.initializePackageContentsGen(UMLPackageImpl.java:1237)
at org.eclipse.ocl.uml.impl.UMLPackageImpl.initializePackageContents(UMLPackageImpl.java:1199)
at org.eclipse.ocl.uml.impl.UMLPackageImpl.init(UMLPackageImpl.java:506)
at org.eclipse.ocl.uml.UMLPackage.<clinit>(UMLPackage.java:81)
... 17 more
Hope u will get my problem now..
Re: Eclipse OCL [message #1091181 is a reply to message #1091152] Wed, 21 August 2013 02:25 Go to previous messageGo to next message
On 21/08/2013 06:26, maham khalid wrote:
No.
You are asking for free help and just creating work for me.
I have to turn your email text into a working project, possibly failing
to reproduce your way of working.
It saves a lot of everyone's time if you you attach a zipped project.
Ed Willink
Re: Eclipse OCL [message #1092685 is a reply to message #1089863] Fri, 23 August 2013 01:01 Go to previous message
You can download complete eclipse ocl from github org.eclipse.ocl.uml.tests.
that can help you in understanding ocl functions, like Helper class etc. Smile
Umair
Previous Topic:Custom Validation Message & Severity
Next Topic:Content Assist in Xtext OCL Console
Current Time: Sun Jul 20 10:18:17 EDT 2025
Powered by FUDForum. Page generated in 0.08775 seconds
