Second Indigo instance hangs on startup [message #1087617] |
Thu, 15 August 2013 18:37  |
Hi there,
My eclipse on Ubuntu 12.04 had been working fine until a couple days ago when suddenly I was not able to launch the second instance. The first instance works fine, and I'm able to switch workspaces. The second instance, however, is stuck after I click <ok> at the message box saying the current workspace is in use. It makes no progress. Jstack contains the following:
"main" prio=10 tid=0x00007fa05c008000 nid=0x36ed runnable [0x00007fa063d06000]
java.lang.Thread.State: RUNNABLE
at org.eclipse.swt.internal.gtk.OS.Call(Native Method)
at org.eclipse.swt.widgets.Display.sleep(Display.java:4069)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:826)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.prompt(ChooseWorkspaceDialog.java:91)
at org.eclipse.ui.internal.ide.application.IDEApplication.promptForWorkspace(IDEApplication.java:296)
at org.eclipse.ui.internal.ide.application.IDEApplication.checkInstanceLocation(IDEApplication.java:237)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:112)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Your help on overcoming the problem is greatly appreciated.
Xuefu
FUDForum. Page generated in 0.07012 seconds
