Home » Eclipse Projects » BPMN 2.0 Modeler » how to enable customTasks in collaboration palette?
how to enable customTasks in collaboration palette? [message #1087375] Thu, 15 August 2013 10:51 Go to next message
I've several custom Tasks that appear without any problem in the process type diagrams palette. However, i've tried using the same modelEnablement switching the enable properties from:
object: default
feature: Process
to:
object: default
feature: Collaboration
but it didn't work.
I've been searching for a way to this but i didn't find one.
What do i need to add a customTask to the palette in a collaboration diagram?
Marco Roque
Re: how to enable customTasks in collaboration palette? [message #1087436 is a reply to message #1087375] Thu, 15 August 2013 12:31 Go to previous messageGo to next message
Huh...funny thing. I just went through the code in BpmnToolBehaviourFeature and it looks like Custom Tasks are only added to the toolpalette for Process Diagrams - sorry about that!
Please file a bugzilla report for this, so I can get a fix out to you ASAP.
Thanks!
Bob
EDIT: You'll still have to create a <modelEnablement> section in your plugin.xml for Collaboration diagrams, similar to what you've (probably) already got for Process diagrams. Something like this:
      <modelEnablement
            runtimeId="my.runtime.id"
            type="Collaboration" profile="Default Collaboration">
			<disable object="all"/>
			<!-- copy the enablements from "Collaboration" diagram type as defined in the "None" Target Runtime -->
			<enable object="default" feature="Collaboration"/>
			<!-- select the model extension features to be displayed in the Property Tabs -->
			<enable object="Task" feature="taskConfig"/>
			<enable object="TaskConfig"/>
			<enable object="Parameter"/>
			<enable object="BoundaryEvent" feature="isEnabled"/>
			<enable object="MyEventDefinition" feature="value"/>
      </modelEnablement>
[Updated on: Thu, 15 August 2013 12:37] by Moderator
Re: how to enable customTasks in collaboration palette? [message #1087560 is a reply to message #1087436] Thu, 15 August 2013 16:53 Go to previous messageGo to next message
Hi Marco,
This was relatively simple, so I just created a BZ report and committed a fix for this bug.
Re: how to enable customTasks in collaboration palette? [message #1087598 is a reply to message #1087375] Thu, 15 August 2013 18:09 Go to previous messageGo to next message
Hi Bob,
It was really fast! thanks a lot.
Do you know when will this fix be available in a stable release?
Marco Roque
Re: how to enable customTasks in collaboration palette? [message #1087618 is a reply to message #1087598] Thu, 15 August 2013 18:40 Go to previous messageGo to next message
You could try the nightly builds available here:
http://download.eclipse.org/bpmn2-modeler/updates/nightly/kepler/
or here:
http://download.eclipse.org/bpmn2-modeler/updates/nightly/juno/
Bob
Re: how to enable customTasks in collaboration palette? [message #1089369 is a reply to message #1087618] Sun, 18 August 2013 12:31 Go to previous messageGo to next message
Hi Bob,
I installed the nightly build but now i can't open the diagrams.
I'm getting the following exception:
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
	at org.eclipse.swt.SWT.error(SWT.java:4361)
	at org.eclipse.swt.SWT.error(SWT.java:4276)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:173)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:388)
	at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1028)
	at org.eclipse.bpmn2.modeler.ui.wizards.BPMN2DiagramWizard.performFinish(BPMN2DiagramWizard.java:83)
	at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
	at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
	at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
	at org.eclipse.jface.window.Window.open(Window.java:801)
	at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:259)
	at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:279)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
	at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:231)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:212)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
	at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:515)
	at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
	at org.eclipse.bpmn2.modeler.ui.editor.BPMN2EditorMatchingStrategy.matches(BPMN2EditorMatchingStrategy.java:24)
	at org.eclipse.ui.internal.WorkbenchPage.checkEditor(WorkbenchPage.java:2225)
	at org.eclipse.ui.internal.WorkbenchPage.findEditors(WorkbenchPage.java:2194)
	at org.eclipse.ui.internal.WorkbenchPage.findEditor(WorkbenchPage.java:2176)
	at org.eclipse.bpmn2.modeler.ui.wizards.BPMN2DiagramCreator$1.run(BPMN2DiagramCreator.java:74)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
Marco Roque
Re: how to enable customTasks in collaboration palette? [message #1090799 is a reply to message #1089369] Tue, 20 August 2013 12:59 Go to previous message
Yikes! Sorry about that. Am I correct in assuming you are using the Juno version of the editor? I just tried a "smoke test" with that platform and found the problem was caused by a bad code merge. I'm usually pretty good at testing these things before publishing a nightly build, but this one just slipped past me Wink
I'll have a new build by end of today that you can test with.
Thanks for testing!
Bob
Previous Topic:Reloading the bpmn2 diagram
Next Topic:Delete unused MessageFlows ?
Current Time: Sat Jul 19 16:21:41 EDT 2025
Powered by FUDForum. Page generated in 0.05291 seconds
