Home » Eclipse Projects » NatTable » Multiple Selection is not enforced after setting flag in the selection model.
Multiple Selection is not enforced after setting flag in the selection model. [message #1085032] Mon, 12 August 2013 07:10 Go to next message
Hi!
i have set the multiple selection in nattable as false, through selection model like,
selectionlayer.getSelectionModel().setMultipleSelectionAllowed(false);
when i try to select multiple rows using "ctrl" key, it is not allowed and previous selection gets unselected and it restrain multiple selection but
when i select rows consecutively using mouse or using "shift" key then multiple selection is not enforced.
So, my question, is it a bug or work as designed?, if it is work as designed and no built in support is provided then it means i should listen to selection event and perform this mechanism manually to enforce multiple selection as not allowed?,
SD Khan
[Updated on: Mon, 12 August 2013 07:12] by Moderator
Re: Multiple Selection is not enforced after setting flag in the selection model. [message #1085049 is a reply to message #1085032] Mon, 12 August 2013 07:32 Go to previous messageGo to next message
Sounds like a bug which is related to inspecting the multipleSelectionAllowed flag. Haven't investigated it much but it is only inspected in addSelectionIntoList() which is getting a Rectangle to select. I guess selecting holding the mouse key or the shift key pressed will call this method susequently using a greater Rectangle, but using the original starting points.
I guess the solution could be to inspect that flag in the commands that perform the selection and respectively transform the Rectangle according to it.
Could you please open a ticket and link to this thread?
Re: Multiple Selection is not enforced after setting flag in the selection model. [message #1085061 is a reply to message #1085049] Mon, 12 August 2013 07:52 Go to previous message
I have opened the ticket.
Bug ID = 414862
URL = https://bugs.eclipse.org/bugs/show_bug.cgi?id=414862
Safdar Khan
Previous Topic:activateCell() method doesn't get called
Next Topic:How to work with custom painters in NatTable?
Current Time: Sun Jul 20 16:16:47 EDT 2025
Powered by FUDForum. Page generated in 0.06207 seconds
