Home » Language IDEs » C / C++ IDE (CDT) » Error in final launch sequence Failed to execute MI command(When trying to flash program on to a particular MCU we are facing this issue.)
Error in final launch sequence Failed to execute MI command [message #1084318] Sun, 11 August 2013 06:04 Go to next message
Hello i am very new to eclipse. Currently using code sourcery as IDE to develop C/C++ applications.We are able to build the application successfully.But when we try to flash the program on to MCU the below error is displayed.
Failed to execute MI command:
detach
Error message from debugger back end:
Can't detach process.
Any one who has faced such kind of issue or are very familiar with eclipse please help me out.
Thanks in advance.
Re: Error in final launch sequence Failed to execute MI command [message #1085153 is a reply to message #1084318] Mon, 12 August 2013 10:25 Go to previous message
I'm guessing you are using the "GDB Hardware debugging" launch?
Did you add this 'detach' command to your launch manually? I'm not exactly sure where it comes from; but it looks like GDB is not liking it.
You can also look at gdb traces as information on what is going on:
http://wiki.eclipse.org/CDT/User/FAQ#I.27ve_been_asked_for_.27gdb_traces.27.2C_where_can_I_find_them.3F
Marc
Previous Topic:Debugger isn't working
Next Topic:building llvm with eclipse
Current Time: Sun Jul 20 16:37:09 EDT 2025
Powered by FUDForum. Page generated in 0.06757 seconds
