Irreproducible output when manually creating test results reports [message #108331] |
Fri, 10 August 2007 09:09  |
Hi.
I an having problems with the creation of test results directly from the
workbench. I select two test suites and click on the "Reports" context
menu item (from the Test perspective) and then select the HTML tabular
report.
The first time I do this I get a beautiful HTML page with the results as
expected (in terms of percentage of successes and failures) and with
hyperlinks to the detailed results for each one of the two suites. When
I run the report a second time, the HTML page does not contain any
hyperlink and the stats only show 0% for everything. I have tried
recreating my starting data by re-running the tests, quitting and then
restarting Eclipse, but to no avail. I do not seem to be able to obtain
the original correct report.
Any help anyone?
TIA,
B.
FUDForum. Page generated in 0.04616 seconds
