Home » Language IDEs » ServerTools (WTP) » Generic Tomcat server
Generic Tomcat server [message #108219] Mon, 30 May 2005 21:23 Go to next message
Originally posted by: michael.rutherford.cba.com.au
Has anyone set up a generic server definition for Tomcat. I realise that
there is a standard implementation for Tomcat already but it doesn't allow
overides to its setup (ie you can change it in Run but if you use the
server tab it resets).
Currently I've been using Tomcat as a Windows service and just using the
server definition for publishing. It works ok but I would prefer to see
start and stop integration before giving it to the rest of my team. I was
thinking that a generic server definition would give me the best of both
worlds with minimum mucking about. If nobody has done it already I'll look
at it myself but I'm thinking it would only need a new plugin containing
the server def, build file and a couple of classes to interface with the
service and it seems reasonable that someone may have done it already.
Michael Rutherfurd
Re: Generic Tomcat server [message #108272 is a reply to message #108219] Tue, 31 May 2005 00:56 Go to previous message
Originally posted by: gercan.removeThis.acm.org
Hi Micheal,
Although I had server definitions in Lomboz for Tomcat, I am not aware
of a Tomcat serverdef plugin for WTP.
Gorkem Ercan
> allow overides to its setup (ie you can change it in Run but if you use
> the server tab it resets).
> was thinking that a generic server definition would give me the best of
> both worlds with minimum mucking about. If nobody has done it already
> I'll look at it myself but I'm thinking it would only need a new plugin
> containing the server def, build file and a couple of classes to
> interface with the service and it seems reasonable that someone may have
> done it already.
> Michael Rutherfurd
Previous Topic:M7 & I Build
Next Topic:WTP and a JAX-RPC Webservice
Current Time: Sun Jul 20 10:25:52 EDT 2025
Powered by FUDForum. Page generated in 0.03621 seconds
