Home » Modeling » Papyrus » Configure created Element
Configure created Element [message #1080207] Mon, 05 August 2013 12:05 Go to next message
what is the right entry point to configure a created element? In this
case I want to add a Stereotype and the element should show the
Stereotype so I think I should execute the ApplyStereotypeCommand() and
the DefferedAppliedStereotypeToDisplayCommand() but where?
Normally the edit.commands are a good place but Papyrus don´t call them?!
Thanks in advance
Peter
Re: Configure created Element [message #1084895 is a reply to message #1080207] Mon, 12 August 2013 03:32 Go to previous message
Consider the palette customization. There you can create your own tools for model elements with applied stereotypes.
Otherwise you can use the extension point for advices and add your code to the getAfterConfigureCommand.
	<extension point="org.eclipse.gmf.runtime.emf.type.core.elementTypes">
		<metamodel nsURI="http://www.eclipse.org/uml2/4.0.0/UML">
			<adviceBinding id="de.upb.swt.rsdl.editor.ext.advice.ClassEditHelperAdviceDiagram"
				class="de.upb.swt.rsdl.editor.ext.advice.ClassEditHelperAdvice"
				inheritance="all" typeId="org.eclipse.papyrus.uml.diagram.clazz.Class_2008">
			</adviceBinding>
			<adviceBinding id="de.upb.swt.rsdl.editor.ext.advice.ClassEditHelperAdviceTypes"
				inheritance="all" typeId="org.eclipse.papyrus.uml.Class">
			</adviceBinding>
		</metamodel>
	</extension>
<extension point="org.eclipse.gmf.runtime.emf.type.core.elementTypeBindings">
		<binding context="org.eclipse.papyrus.infra.services.edit.TypeContext">
			<advice ref="de.upb.swt.rsdl.editor.ext.advice.ClassEditHelperAdviceTypes" />
		</binding>
		<binding context="org.eclipse.papyrus.uml.diagram.clazz.TypeContext">
			<advice ref="de.upb.swt.rsdl.editor.ext.advice.ClassEditHelperAdviceDiagram" />
</binding>
</extension>
public class ClassEditHelperAdvice extends AbstractEditHelperAdvice {
	 * Context: diagram
	protected ICommand getAfterConfigureCommand(ConfigureRequest request) {
		if(request.getElementToConfigure() instanceof Class){
			return new ClassCreateCommand(request);
		return super.getAfterConfigureCommand(request);
public class ClassCreateCommand extends org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTransactionalCommand{
	protected CommandResult doExecuteWithResult(IProgressMonitor monitor, IAdaptable info) throws ExecutionException {
Class clazz = (Class) configureRequest.getElementToConfigure();
//apply stereotype
[Updated on: Mon, 12 August 2013 03:35] by Moderator
Previous Topic:Connection Handles gone in Papyrus 0.10.0
Next Topic:How in the world do you generate a papyrus model from an existing uml?
Current Time: Sat Jul 19 23:52:46 EDT 2025
Powered by FUDForum. Page generated in 0.03636 seconds
