Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Problem with update site
Re: [Teneo] Problem with update site [message #107128 is a reply to message #107084] |
Wed, 16 January 2008 13:33   |
Hi David,
I will look into this, in the mean time you can also download directly by following this link:
http://www.eclipse.org/modeling/emft/downloads/?project=tene o
gr. Martin
david wrote:
> I was putting Teneo and prequisites on a new machine, having forgotten
> how I did it first time round on a different machine.
> Using update site
> -http://download.eclipse.org/modeling/emft/updates/site-inte rim.xml.
> First thing that strikes me is that it marks the latest plugins as being
> the correct ones, and looking at the EMFT site it looks like these
> require 3.4M3, whereas I have Europa ( 3.3 from the 25th September
> 2007). But then it is hard to choose a correct version because they all
> show being dependent on versions either side of Europas. Not sure how
> you are supposed to resolve this.
> Anyway went ahead assume the whole Update thing knows which version are
> correct, get most of the way through and then this error
> Update operation has failed
> Error retrieving
> "plugins/org.apache.commons.lang_2.1.0.v200711021015.jar". [Server
> returned HTTP response code: "404 Not Found" for URL:
> http://ftp.heanet.ie/pub/eclipse//modeling/emft/updates/plug ins/org.apache.commons.lang_2.1.0.v200711021015.jar.]
> Server returned HTTP response code: "404 Not Found" for URL:
> Thx.
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Problem with update site [message #107515 is a reply to message #107128] |
Thu, 17 January 2008 11:09   |
I used the version dated 6th September, it being closest to the release
date of Europa. Wondering why there is not a version of Teneo that is
specifically matched to Europa release version? I thought the whole
Update Site thing was meant to check this compatible versioning thing.
David
Martin Taal wrote:
> Hi David,
> gr. Martin
> david wrote:
>> Hi,
>> Using update site
>> being the correct ones, and looking at the EMFT site it looks like
>> these require 3.4M3, whereas I have Europa ( 3.3 from the 25th
>> September 2007). But then it is hard to choose a correct version
>> because they all show being dependent on versions either side of
>> Europas. Not sure how you are supposed to resolve this.
>> are correct, get most of the way through and then this error
>> Error retrieving
>> Thx.
>> David
Re: [Teneo] Problem with update site [message #107528 is a reply to message #107515] |
Thu, 17 January 2008 11:17   |
Hi David,
The active version of Teneo is 0.8.0 which is for 3.3. I would use the last build (28th of
december), since the 6th of december about 20 issues have been solved.
I just tried the update manager and with me it worked fine (I updated to the 28th dec version).
In which screen did you see the warning about eclipse version 3.4?
gr. Martin
david wrote:
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> forgotten how I did it first time round on a different machine.
>>> Using update site
>>> Error retrieving
>>> Thx.
>>> David
The Netherlands
Re: [Teneo] Problem with update site [message #107675 is a reply to message #107528] |
Fri, 18 January 2008 06:04   |
I did not get a warning about 3.4M I got this, again just now when I retried
Error retrieving
http://eclipse.mirror.kangaroot.net/modeling/emft/updates/pl ugins/org.apache.commons.lang_2.1.0.v200711021015.jar.]
I assume it is using a different update site to when you try.
One thing I noticed was that it was attempting to download Version 0.8.0
from the 3rd January 2008, not the 28-12-2007 version just prior to this
error above. To compound things I cannot work at all. Because I thought
maybe a full "Search for updates of the currently installed features"
would help, now I get a NPE whenever I try to open any xml document.
Seems the Update Site idea is not working in all cases, I thought it was
supposed to be version aware? The only install I have done outside
Update Site was the manual installation of the teneo project with the
version from 28-12-2007.
David
Martin Taal wrote:
> Hi David,
> last build (28th of december), since the 6th of december about 20 issues
> have been solved.
> gr. Martin
> david wrote:
>> Hi,
>> release date of Europa. Wondering why there is not a version of Teneo
>> that is specifically matched to Europa release version? I thought the
>> whole Update Site thing was meant to check this compatible versioning
>> thing.
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> Using update site
>>>> Error retrieving
>>>> Thx.
>>>> David
Re: [Teneo] Problem with update site [message #107714 is a reply to message #107675] |
Fri, 18 January 2008 06:44  |
Hi David,
To me it seems more an issue of the update manager in general than of Teneo specifically...
I think I remember that I also have had these type of issues with the update manager (an npe) a
while back. You can check the error view and the eclipse log file to see if you can get more
information. You can also try a different mirror.
I do not know if the update manager is version aware.
Teneo does not have a dependency on the apache commons plugin so I do not know why in your case the
system tries to download it.
gr. Martin
david wrote:
> retried
> Error retrieving
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> thing.
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> gr. Martin
>>>> david wrote:
>>>>> Hi,
>>>>> Using update site
>>>>> Error retrieving
>>>>> Thx.
>>>>> David
The Netherlands
Re: [Teneo] Problem with update site [message #614007 is a reply to message #107084] |
Hi David,
gr. Martin
david wrote:
> Using update site
> Error retrieving
> http://ftp.heanet.ie/pub/eclipse//modeling/emft/updates/plug ins/org.apache.commons.lang_2.1.0.v200711021015.jar]
> Thx.
> David
The Netherlands
Re: [Teneo] Problem with update site [message #614035 is a reply to message #107128] |
David
Martin Taal wrote:
> Hi David,
> gr. Martin
> david wrote:
>> Hi,
>> Using update site
>> Error retrieving
>> Thx.
>> David
Re: [Teneo] Problem with update site [message #614036 is a reply to message #107515] |
Hi David,
gr. Martin
david wrote:
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> Using update site
>>> Error retrieving
>>> Thx.
>>> David
The Netherlands
Re: [Teneo] Problem with update site [message #614047 is a reply to message #107528] |
Error retrieving
http://eclipse.mirror.kangaroot.net/modeling/emft/updates/pl ugins/org.apache.commons.lang_2.1.0.v200711021015.jar]
David
Martin Taal wrote:
> Hi David,
> have been solved.
> gr. Martin
> david wrote:
>> Hi,
>> thing.
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> Using update site
>>>> Error retrieving
>>>> Thx.
>>>> David
Re: [Teneo] Problem with update site [message #614050 is a reply to message #107675] |
Hi David,
gr. Martin
david wrote:
> retried
> Error retrieving
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> thing.
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> gr. Martin
>>>> david wrote:
>>>>> Hi,
>>>>> Using update site
>>>>> Error retrieving
>>>>> Thx.
>>>>> David
The Netherlands
Current Time: Sat Jul 19 13:02:28 EDT 2025
Powered by FUDForum. Page generated in 0.05348 seconds
