Home » Eclipse Projects » EclipseLink » EclipseLink MOXy exception due to package structure
EclipseLink MOXy exception due to package structure [message #1067854] Wed, 10 July 2013 17:49 Go to next message
I have this bindings file
<?xml version="1.0"?>
<xml-bindings
    xmlns="http://www.eclipse.org/eclipselink/xsds/persistence/oxm"
    package-name="com">
    <java-types>
        <java-type name="com.test.Root">
            <xml-root-element name="root"/>
            <java-attributes>
                <xml-element java-attribute="element" xml-path="element" type="com.Element"/>
			</java-attributes>
        </java-type>
        <java-type name="com.Element"></java-type>
    </java-types>
</xml-bindings>
The package structure and the class location are as can be read off this bindings file.
When I unmarshall I get the following exception. Can somebody tell me why and how I can solve the problem? I don't want to change my package structure.
    JAXBException: The java-type with package [com.test] is not allowed in the bindings file keyed on package [com].
Re: EclipseLink MOXy exception due to package structure [message #1076520 is a reply to message #1067854] Wed, 31 July 2013 10:15 Go to previous message
You need to have one binding file per package. BTW when you specify the package name in the `xml-bindings` element you don't need to fully qualify the name on the `java-type` element.
When creating the JAXBContext on multiple binding files you can do the following:
List<String> mappingFiles = new ArrayList<String>(2);
mappingFiles.add("test/fooBindings.xml");
mappingFiles.add("test/barBindings.xml");
Map<String, Object> properties = new HashMap<String, Object>(1);
properties.put(JAXBContextProperties.OXM_METADATA_SOURCE, mappingFiles);
JAXBContext jaxbContext = JAXBContextFactory.createContext(new Class[] {Root.class}, properties);
Previous Topic:MOXy: Binding working and not working with 'same' XmlPath
Next Topic:EclipseLink MOXy: Logical operators in XmlPath annotation
Current Time: Sun Jul 20 17:30:31 EDT 2025
Powered by FUDForum. Page generated in 0.03826 seconds
