Home » Modeling » M2T (model-to-text transformation) » JET2 Tag Escape Character(What is the escape character for JET2 tags?)
JET2 Tag Escape Character [message #1076276] Wed, 31 July 2013 00:44 Go to next message
I need to use JET2 templates to write JET2 template which means I need to escape JET2 tags.
What does JET2 use for an escape character? Presumably something along the lines of
<\c:setVariable .../> where the first backslash means that <c:setVariable .../> is printed to the result, not evaluated by the initial transformation.
Re: JET2 Tag Escape Character [message #1076465 is a reply to message #1076276] Wed, 31 July 2013 08:40 Go to previous message
Phillip:
There is no backslash escaping for custom tags, in spite of what it says in the JET FAQ (which I'll modify shortly).
Your choices are the following alternatives:
If you are working with JET 1.0 or later, you can escape the leading < character with the compact XPath expression ${'<'} :
${'<'}c:iterate>...${'<'}/c:iterate>
See Compact alternative to c:get, for more details.
Alternatively, you can use the taglib directive to change the namespace of your tags.
You can change the namespace of the tags you emit:
<%-- Your template uses c:, but emits cc: for control tags --%>
<%-- emit tag so that the output tags are bound to cc. This needs to be escaped --%>
<\%@taglib prefix="cc" id="org.eclipse.jet.controlTags" %>
<c:if test="someCondition">
   <cc:iterate select="...">...</cc:iterate>
</c:if>
Or, you can change the namespace of your template's tags:
<%-- Your template uses cc:, but emits c: for control tags --%>
<%-- Indicate that this templates uses cc prefix for control tags --%>
<%@taglib prefix="cc" id="org.eclipse.jet.controlTags" %>
<cc:if test="someCondition">
   <c:iterate select="...">...</c:iterate>
</cc:if>
JET you used the later technique since inception to generate new JET projects.
Paul
Previous Topic:[acceleo] Training in NE US
Next Topic:[Acceleo] Access to siblings of resource roots
Current Time: Sun Jul 20 04:14:28 EDT 2025
Powered by FUDForum. Page generated in 0.04157 seconds
