Home » Eclipse Projects » JFace » TableViewer Sorting and MultiSelectionBinding(Faulty multi selection binding after sorting a column )
TableViewer Sorting and MultiSelectionBinding [message #1067751] |
Wed, 10 July 2013 08:50  |
i am using the databinding framework to bind TableViewers to ObservableLists. The bidirectional binding from viewer to model works fine but the bidirectional binding from multi-selection to model fails after sorting a column. I can reproduce this failure everytime with the following test case.
model.setSource(Arrays.asList("3", "4", "5"));
assertEquals(source, selection);
final Table table = viewer.getTable();
comparator.setColumn(0);
table.setSortDirection(comparator.getDirection());
table.setSortColumn(table.getColumn(0));
table.showSelection();
viewer.refresh();
assertEquals(source.size(), selection.size());
model.setSource(Arrays.asList("1", "2", "3", "4", "5"));
viewer.setSelection(new StructuredSelection(Arrays.asList("1", "2")));
assertEquals(source.size(), selection.size()); // failure
The list of the viewer is always "1", "2", "3", "4", "5" (form ContentProvider) but the multi-selection stored in "selection" and bind to "source" is different at the end.
source=[1, 2, 3, 4, 5]
selection=[3, 2, 1]
If i comment out the sort block the result is
selection=[1, 2, 3, 4, 5]
The whole implementation is based on a tutorial of vogella (http://www.vogella.com/articles/EclipseJFaceTableAdvanced/article.html#sortcolumns).
Has anyone an idea to fix this? Any suggestion? Thank you!
Builds: org.eclipse.jface_3.7.0.I20110522-1430.jar, org.eclipse.core.databinding.observable_1.4.0.I20110222-0800.jar
Re: TableViewer Sorting and MultiSelectionBinding [message #1075456 is a reply to message #1067751] |
Mon, 29 July 2013 09:05   |
Hi Ralf,
I'm confused here. You mentioned binding but there is no code in your
post that does any kind of bidirectional binding. Furthermore the
tutorial to which you link is on JFace viewer, not databinding. The
full test case would help.
Note also that it is unusual for a selection to be bound to the
persisted model. You may like to consider using check boxes instead of
the selection if this subset is to be persisted in the datastore.
Nigel Westbury
On 10/07/2013 13:50, Ralf Heilek wrote:
> Hello,
> viewer.refresh();
> selection=[3, 2, 1]
Re: TableViewer Sorting and MultiSelectionBinding [message #1086599 is a reply to message #1075456] |
Wed, 14 August 2013 08:06  |
Hi Nigel,
you can download the whole test case from the first post (http://www.eclipse.org/forums/index.php/fa/15553/). The binding code in this file looks like...
Realm realm = new DefaultRealm();
source = BeansObservables.observeList(realm, model, "source", String.class);
selection = ViewersObservables.observeMultiSelection(viewer);
DataBindingContext ctx = new DataBindingContext(realm);
ctx.bindList(selection, source);
...and the model should only fulfil the model-view-controller paradigm to display details from the selected values outside of the master table (e.g. detail block).
Ralf Heilek
Current Time: Sun Jul 20 11:58:28 EDT 2025
Powered by FUDForum. Page generated in 0.07097 seconds
