Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Freeze instead of Exception on Mac(NullPointerException thrown in Tree listener causes freeze)
Freeze instead of Exception on Mac [message #1075334] Mon, 29 July 2013 04:57
following source code (SWT Snippet90 with added lines causing NullPointerExcetion) results in application freeze on Mac. The freeze occurs after click on some item in the tree.
package org.eclipse.swt.snippets;
import org.eclipse.swt.*;
import org.eclipse.swt.graphics.*;
import org.eclipse.swt.widgets.*;
public class Snippet90 {
public static void main (String [] args) {
	Display display = new Display ();
	Shell shell = new Shell (display);
	final Tree tree = new Tree (shell, SWT.BORDER | SWT.MULTI);
	for (int i=0; i<12; i++) {
		TreeItem treeItem = new TreeItem (tree, SWT.NONE);
		treeItem.setText ("Item " + i);
	tree.addListener (SWT.MouseDown, new Listener () {
		public void handleEvent (Event event) {
			Point point = new Point (event.x, event.y);
			TreeItem item = tree.getItem (point);
			if (item != null) {
				System.out.println ("Mouse down: " + item);
			Image image = item.getImage();
			image.getImageData();
	Rectangle clientArea = shell.getClientArea ();
	tree.setBounds (clientArea.x, clientArea.y, 200, 200);
	shell.setSize (300, 300);
	shell.open ();
	while (!shell.isDisposed ()) {
		if (!display.readAndDispatch ()) display.sleep ();
	display.dispose ();
I use Mac Os X Lion 10.7.5 (11G63) and SWT 4.2.2 (swt-4.2.2-cocoa-macosx-x86_64.zip). The application hangs when calling OS.objc_msgSendSuper(objc_super, long, long) method.
Running the same code on Windows causes application crash with NullPointerException in call stack. So similar code in some Eclipse Plug-in/RCP application on Mac causes freeze with no cause in the log.
Is this some known problem on Mac? Should I report a bug about this?
Previous Topic:Supporting Multiple Data type entries in Clipboard
Next Topic:"IBM Notes Browser Plugin" used in SWT Browser crashes
Current Time: Sun Jul 20 16:48:35 EDT 2025
Powered by FUDForum. Page generated in 0.04548 seconds
