Home » Archived » Jubula » What is the correct parameter value for the dash/minus key?(trying to send a control+dash to the application)
What is the correct parameter value for the dash/minus key? [message #1073409] Wed, 24 July 2013 14:02 Go to next message
I am trying to use ub_app_pressAnyKeyCombination_CTRL to send a control+dash keystroke to the application, but I cannot find the correct parameter value for that key. "MINUS" results in a control+M being sent, and "-", "DASH", and "HYPHEN" all result in an invalid parameter value error. The reference manual does not list it, and Google is coming up empty.
For the record, I am trying to send the - character from the alpha keyboard, not the one on the numpad.
Re: What is the correct parameter value for the dash/minus key? [message #1073752 is a reply to message #1073409] Thu, 25 July 2013 08:28 Go to previous messageGo to next message
I'm afraid I don't know - I'll ask around here, and maybe someone else in the forum has an idea.
Alex
Re: What is the correct parameter value for the dash/minus key? [message #1073911 is a reply to message #1073752] Thu, 25 July 2013 14:35 Go to previous message
The fact that "MINUS" doesn't produce an Invalid Parameter Value error leads me to believe that that's supposed to be the correct option, and that it's just erroneously mapped to the M key instead. If that is the case, then I hope that somebody knows of some other value I can use that will work.
Previous Topic:Can't remove parameters from test case
Next Topic:How can I access the column's header in TreeTable component?
Current Time: Sun Jul 20 17:31:45 EDT 2025
Powered by FUDForum. Page generated in 0.03601 seconds
