Home » Eclipse Projects » Eclipse Scout » Colour picker
Colour picker [message #1067517] Tue, 09 July 2013 04:16 Go to next message
In our application we want to let the users define certain colours. For this we need a colour picket control. In the back of my head I thought I'd seen a forum post about this, but have been unable to find anything either in the forum or the wiki.
Is there an existing colour picker control that can be used with scout?
Re: Colour picker [message #1070659 is a reply to message #1067517] Thu, 18 July 2013 08:07 Go to previous messageGo to next message
Hi Urs
So far we did not implement a color picker. To get there implement a custom control and use the
SWT: org.eclipse.swt.widgets.ColorDialog
Swing: javax.swing.JColorChooser
If you are able please create a patch/gerrit change.
Many thanks...
-Andreas
Re: Colour picker [message #1070674 is a reply to message #1070659] Thu, 18 July 2013 08:38 Go to previous messageGo to next message
Thanks Andreas, I'll give it a go.
Re: Colour picker [message #1072724 is a reply to message #1070659] Tue, 23 July 2013 07:34 Go to previous messageGo to next message
Ok, I've managed to put together a custom control with support for SWT, Swing and RAP. It returns a String, containing the chosen colour as a 6-digit hex number. It displays the chosen colour as a rectangular, coloured field (if a colour is defined) or as a white field with black border (if no colour is defined).
It comes with the following properties:
getConfiguredColor() -> the default colour to use
getConfiguredDefaultMenus() -> if set to true, will show pre-defined context menus when right clicking the colour-rectangle with support to clear the chosen colour (all renderers) and the possibility to clear the custom colours (SWT only)
It also comes with a callback method:
execChanged() -> called when a colour is chosen on the UI
index.php/fa/15668/0/
Andreas Hoegger wrote on Thu, 18 July 2013 14:07
I'm happy to provide the code to be integrated into Scout by you, but at the moment I'm unable to create a patch/gerrit change. I am posting the code in my next post (and will attach it as a ZIP file).
Here are some previews of a form containing four ColorPickerFields:
index.php/fa/15669/0/
index.php/fa/15670/0/
index.php/fa/15671/0/
Re: Colour picker [message #1072732 is a reply to message #1072724] Tue, 23 July 2013 07:48 Go to previous messageGo to next message
Attached you will find a ZIP file with all the necessary java files:
Client
IColorPickerField
import org.eclipse.scout.rt.client.ui.action.menu.IMenu;
import org.eclipse.scout.rt.client.ui.form.fields.IFormField;
public interface IColorPickerField extends IFormField {
  public static final String PROP_COLOR = "Color";
  public static final String PROP_CLEAR_CUSTOM_COLORS = "ClearCustomColors";
  String getColor();
  void setColor(String c);
  boolean hasMenus();
  IMenu[] getMenus();
  IColorPickerUiFacade getUiFacade();
public interface IColorPickerUiFacade {
  void setColorFromUI(String color);
  IMenu[] firePopupFromUI();
AbstractColorPickerField
import java.io.IOException;
import java.util.ArrayList;
import java.util.List;
import org.eclipse.minicrm.shared.services.process.AbstractColorPickerFieldData;
import org.eclipse.scout.commons.ConfigurationUtility;
import org.eclipse.scout.commons.TypeCastUtility;
import org.eclipse.scout.commons.annotations.ConfigOperation;
import org.eclipse.scout.commons.annotations.ConfigProperty;
import org.eclipse.scout.commons.annotations.ConfigPropertyValue;
import org.eclipse.scout.commons.annotations.FormData;
import org.eclipse.scout.commons.annotations.FormData.DefaultSubtypeSdkCommand;
import org.eclipse.scout.commons.annotations.FormData.SdkCommand;
import org.eclipse.scout.commons.annotations.Order;
import org.eclipse.scout.commons.exception.ProcessingException;
import org.eclipse.scout.commons.logger.IScoutLogger;
import org.eclipse.scout.commons.logger.ScoutLogManager;
import org.eclipse.scout.commons.xmlparser.SimpleXmlElement;
import org.eclipse.scout.rt.client.ui.action.menu.AbstractMenu;
import org.eclipse.scout.rt.client.ui.form.fields.customfield.AbstractCustomField;
import org.eclipse.scout.rt.shared.TEXTS;
import org.eclipse.scout.rt.shared.services.common.exceptionhandler.IExceptionHandlerService;
import org.eclipse.scout.rt.shared.ui.UserAgentUtility;
import org.eclipse.scout.service.SERVICES;
@FormData(value = AbstractColorPickerFieldData.class, sdkCommand = SdkCommand.CREATE, defaultSubtypeSdkCommand = DefaultSubtypeSdkCommand.CREATE)
public abstract class AbstractColorPickerField extends AbstractCustomField implements IColorPickerField {
  private static final IScoutLogger LOG = ScoutLogManager.getLogger(AbstractColorPickerField.class);
  private IColorPickerUiFacade m_uiFacade;
  private IMenu[] m_menus;
  private String m_color;
  @FormData
  public String getColor() {
    return m_color;
  @FormData
  public void setColor(String color) {
    m_color = color;
    propertySupport.setProperty(PROP_COLOR, color);
    execChanged();
  public IColorPickerUiFacade getUiFacade() {
    return m_uiFacade;
  @ConfigOperation
  @Order(190)
  // override if needed
  public void execChanged() {
  public void clearCustomColors() {
    String toggle = "Clear";
    if (propertySupport.getProperty(PROP_CLEAR_CUSTOM_COLORS) != null) {
      toggle = null;
    propertySupport.setProperty(PROP_CLEAR_CUSTOM_COLORS, toggle);
   * Configuration
  @ConfigProperty(ConfigProperty.STRING)
  @Order(500)
  @ConfigPropertyValue("0")
  protected String getConfiguredColor() {
    return null;
  @ConfigProperty(ConfigProperty.BOOLEAN)
  @Order(501)
  @ConfigPropertyValue("FALSE")
  protected boolean getConfiguredDefaultMenus() {
    return false;
  @SuppressWarnings("unchecked")
  private Class<? extends IMenu>[] getConfiguredMenus() {
    Class[] dca = ConfigurationUtility.getDeclaredPublicClasses(getClass());
    Class<IMenu>[] foca = ConfigurationUtility.sortFilteredClassesByOrderAnnotation(dca, IMenu.class);
    if (!getConfiguredDefaultMenus()) {
      List<Class<IMenu>> menus = new ArrayList<Class<IMenu>>();
      for (int i=0; i<foca.length; ++i) {
        boolean local = false;
        for (Class iface : foca[i].getInterfaces()) {
          if (iface.getName().equals(IDefaultColorPickerMenu.class.getName())) {
            local = true;
        if (!local) {
          menus.add(foca[i]);
      foca = menus.toArray(new Class[menus.size()]);
    return ConfigurationUtility.removeReplacedClasses(foca);
  protected void initConfig() {
    m_uiFacade = new P_UiFacade();
    super.initConfig();
    setColor(getConfiguredColor());
    // menus
    ArrayList<IMenu> menuList = new ArrayList<IMenu>();
    Class<? extends IMenu>[] menuArray = getConfiguredMenus();
    for (int i = 0; i < menuArray.length; i++) {
      IMenu menu;
      try {
        menu = ConfigurationUtility.newInnerInstance(this, menuArray[i]);
        menuList.add(menu);
      } catch (Throwable t) {
        SERVICES.getService(IExceptionHandlerService.class).handleException(new ProcessingException("menu: " + menuArray[i].getName(), t));
    try {
      injectMenusInternal(menuList);
    } catch (Exception e) {
      LOG.error("error occured while dynamically contributing menus.", e);
    m_menus = menuList.toArray(new IMenu[0]);
   * Override this internal method only in order to make use of dynamic menus<br>
   * Used to manage menu list and add/remove menus
   * @param menuList
   *          live and mutable list of configured menus
  protected void injectMenusInternal(List<IMenu> menuList) {
  public boolean hasMenus() {
    return m_menus.length > 0;
  public IMenu[] getMenus() {
    return m_menus;
  private IMenu[] firePopup() {
    List<IMenu> result = new ArrayList<IMenu>();
    // single observer add our menus
    IMenu[] a = getMenus();
    for (int i = 0; i < a.length; i++) {
      IMenu m = a[i];
      m.prepareAction();
      if (m.isVisible()) {
        result.add(m);
    return result.toArray(new IMenu[result.size()]);
  private class P_UiFacade implements IColorPickerUiFacade {
    public void setColorFromUI(String color) {
      setColor(color);
    public IMenu[] firePopupFromUI() {
      return firePopup();
  private String m_initColor;
  public AbstractColorPickerField() {
    this(true);
  public AbstractColorPickerField(boolean callInitializer) {
    super(callInitializer);
   * XML i/o
  public void storeXML(SimpleXmlElement x) throws ProcessingException {
    super.storeXML(x);
    try {
      x.setObjectAttribute(IColorPickerField.PROP_COLOR, getColor());
    } catch (IOException e) {
      if (LOG.isInfoEnabled()) {
        LOG.info("not serializable value in field " + getClass().getName() + "/" + getLabel() + ": " + e);
  public void loadXML(SimpleXmlElement x) throws ProcessingException {
    super.loadXML(x);
    try {
      String color = TypeCastUtility.castValue(x.getObjectAttribute(IColorPickerField.PROP_COLOR, null), String.class);
      setColor(color);
      // be lenient, maybe the field was changed
      LOG.warn(null, e);
  public void setInitValue(String initColor) {
    m_initColor = initColor;
  public String getInitColor() {
    return m_initColor;
  protected boolean execIsSaveNeeded() throws ProcessingException {
    String color = getColor();
    String initColor = getInitColor();
    if (color == null && initColor == null) {
      return false;
    } else if (color == null || initColor == null) {
      return true;
    } else {
      return !color.equals(initColor);
  protected void execMarkSaved() throws ProcessingException {
    super.execMarkSaved();
    setInitValue(getColor());
  private interface IDefaultColorPickerMenu extends IMenu {
  @Order(1.0)
  public class ClearColorContextMenu extends AbstractMenu implements IDefaultColorPickerMenu {
    protected String getConfiguredText() {
      return TEXTS.get("ClearColor");
    protected void execPrepareAction() throws ProcessingException {
      setEnabled(getColor() != null);
    protected void execAction() throws ProcessingException {
      setColor(null);
  @Order(2.0)
  public class ClearCustomColorsContextMenu extends AbstractMenu implements IDefaultColorPickerMenu {
      return TEXTS.get("ClearCustomColors");
      clearCustomColors();
      // when "recent color" support has been added to Swing, isSwtUi() can be replaced with isRichClient()
      setVisible(UserAgentUtility.isSwtUi());
      // setVisible(UserAgentUtility.isRichClient());
  @Order(3.0)
  public class DefaultSeparatorContextMenu extends AbstractMenu implements IDefaultColorPickerMenu {
    protected boolean getConfiguredSeparator() {
      return true;
SWT
SwtScoutColorPickerField
import java.util.concurrent.atomic.AtomicReference;
import org.eclipse.minicrm.client.ui.form.fields.ext.IColorPickerField;
import org.eclipse.scout.commons.RunnableWithData;
import org.eclipse.scout.commons.StringUtility;
import org.eclipse.scout.commons.job.JobEx;
import org.eclipse.scout.rt.ui.swt.LogicalGridLayout;
import org.eclipse.scout.rt.ui.swt.SwtMenuUtility;
import org.eclipse.scout.rt.ui.swt.ext.StatusLabelEx;
import org.eclipse.scout.rt.ui.swt.form.fields.SwtScoutFieldComposite;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.MenuAdapter;
import org.eclipse.swt.events.MenuEvent;
import org.eclipse.swt.events.MouseListener;
import org.eclipse.swt.events.MouseMoveListener;
import org.eclipse.swt.events.PaintEvent;
import org.eclipse.swt.events.PaintListener;
import org.eclipse.swt.graphics.RGB;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.widgets.Canvas;
import org.eclipse.swt.widgets.ColorDialog;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Menu;
import org.eclipse.swt.widgets.MenuItem;
import org.eclipse.swt.widgets.Shell;
public class SwtScoutColorPickerField extends SwtScoutFieldComposite<IColorPickerField> {
  private P_MouseListener m_mouseListener;
  private static RGB[] rgbs;
  private Menu m_contextMenu;
  private final static RGB WHITE = new RGB(255, 255, 255);
  protected void initializeSwt(Composite parent) {
    m_mouseListener = new P_MouseListener();
    Composite container = getEnvironment().getFormToolkit().createComposite(parent);
    StatusLabelEx label = getEnvironment().getFormToolkit().createStatusLabel(container, getEnvironment(), getScoutObject());
    Canvas canvas = getEnvironment().getFormToolkit().createCanvas(container);
    canvas.addPaintListener(new P_PaintListener());
    canvas.addMouseListener(m_mouseListener);
    // context menu
    m_contextMenu = new Menu(canvas.getShell(), SWT.POP_UP);
    m_contextMenu.addMenuListener(new P_ContextMenuListener());
    canvas.setMenu(m_contextMenu);
    setSwtContainer(container);
    setSwtLabel(label);
    setSwtField(canvas);
    // layout
    getSwtContainer().setLayout(new LogicalGridLayout(1, 0));
  protected void attachScout() {
    super.attachScout();
    updateColorFromScout();
  protected void updateColorFromScout() {
    getSwtField().redraw();
  protected void handleSwtPickColor() {
    Shell shell = new Shell(getEnvironment().getDisplay());
    ColorDialog colorDialog = new ColorDialog(shell);
    colorDialog.setText(TEXTS.get("SelectColor"));
    RGB rgb = getRgb(getScoutObject().getColor());
    if (rgb != null) {
      colorDialog.setRGB(rgb);
      if (rgbs == null) {
        rgbs = colorDialog.getRGBs();
      if (rgbs != null) {
        boolean found = false;
        for(int i=0; i<rgbs.length; ++i) {
          if (rgbs[i] != null && rgbs[i].equals(rgb)) {
            found = true;
            break;
        if (!found) {
          for (int i = 0; i < rgbs.length; ++i) {
            if (WHITE.equals(rgbs[i])) {
              rgbs[i] = rgb;
              found = true;
              break;
        if (!found) {
          rgbs[rgbs.length-1] = rgb;
      } else {
        rgbs = new RGB[] { rgb };
    colorDialog.setRGBs(rgbs);
    RGB selectedColor = colorDialog.open();
    if (selectedColor != null) {
      final String color = getColorString(selectedColor.red, selectedColor.green, selectedColor.blue).toUpperCase();
      RunnableWithData t = new RunnableWithData() {
        public void run() {
          getScoutObject().getUiFacade().setColorFromUI(color);
      getEnvironment().invokeScoutLater(t, 2345);
    shell.dispose();
  public String getColorString(int red, int green, int blue) {
    int iRgb = ((red & 0xFF) << 16) | ((green & 0xFF) << 8) | ((blue & 0xFF) << 0);
    String hexString = Integer.toHexString(iRgb);
    while (hexString.length() < 6) {
      hexString = "0" + hexString;
    return hexString;
  public RGB getRgb(String color) {
    if (!StringUtility.isNullOrEmpty(color) && color.length() >= 6) {
      int red = Integer.parseInt(color.substring(0, 2), 16);
      int green = Integer.parseInt(color.substring(2, 4), 16);
      int blue = Integer.parseInt(color.substring(4, 6), 16);
      return new RGB(red, green, blue);
    return null;
  protected void handleScoutPropertyChange(String name, Object newValue) {
    if (name.equals(IColorPickerField.PROP_COLOR)) {
    } else if (name.equals(IColorPickerField.PROP_CLEAR_CUSTOM_COLORS)) {
      rgbs = new RGB[] { WHITE };
    super.handleScoutPropertyChange(name, newValue);
  private class P_PaintListener implements PaintListener {
    private static final long serialVersionUID = 1L;
    public void paintControl(PaintEvent e) {
      if (getScoutObject().getColor() != null) {
        e.gc.setBackground(getEnvironment().getColor(getScoutObject().getColor()));
        e.gc.setForeground(getEnvironment().getColor("000000"));
      } else {
        e.gc.setBackground(getEnvironment().getColor("FFFFFF"));
      Rectangle bounds = getSwtField().getBounds();
      e.gc.fillRectangle(bounds);
      e.gc.drawRectangle(bounds.x, bounds.y, bounds.width - bounds.x - 1, bounds.height - 1);
  private class P_MouseListener implements MouseListener, MouseMoveListener {
    public void mouseDoubleClick(org.eclipse.swt.events.MouseEvent e) {
    public void mouseDown(org.eclipse.swt.events.MouseEvent e) {
      if (e != null && e.button == 1) {
        handleSwtPickColor();
    public void mouseUp(org.eclipse.swt.events.MouseEvent e) {
    public void mouseMove(org.eclipse.swt.events.MouseEvent e) {
  private class P_ContextMenuListener extends MenuAdapter {
    public void menuShown(MenuEvent e) {
      for (MenuItem item : m_contextMenu.getItems()) {
        disposeMenuItem(item);
      final AtomicReference<IMenu[]> scoutMenusRef = new AtomicReference<IMenu[]>();
      Runnable t = new Runnable() {
        public void run() {
          IMenu[] scoutMenus = getScoutObject().getUiFacade().firePopupFromUI();
          scoutMenusRef.set(scoutMenus);
      JobEx job = getEnvironment().invokeScoutLater(t, 1200);
      try {
        job.join(1200);
      } catch (InterruptedException ex) {
        // nop
      // grab the actions out of the job, when the actions are providden within
      // the scheduled time the popup will be handled.
      if (scoutMenusRef.get() != null) {
        SwtMenuUtility.fillContextMenu(scoutMenusRef.get(), m_contextMenu, getEnvironment());
    private void disposeMenuItem(MenuItem item) {
      Menu menu = item.getMenu();
      if (menu != null) {
        for (MenuItem childItem : menu.getItems()) {
          disposeMenuItem(childItem);
        menu.dispose();
      item.dispose();
  } // end class P_ContextMenuListener
plugin.xml
   <extension
         point="org.eclipse.scout.rt.ui.swt.formfields">
     <formField
           active="true"
           modelClass="org.eclipse.minicrm.client.ui.form.fields.ext.IColorPickerField"
           name="Color Picker Field"
           scope="default">
        <uiClass
              class="org.eclipse.minicrm.ui.swt.form.fields.ext.SwtScoutColorPickerField">
        </uiClass>
     </formField>
   </extension>
Swing
SwingScoutColorPickerField
import java.awt.Color;
import java.awt.Graphics;
import java.awt.Rectangle;
import java.awt.event.MouseAdapter;
import java.awt.event.MouseEvent;
import javax.swing.JColorChooser;
import javax.swing.JComponent;
import org.eclipse.scout.rt.ui.swing.LogicalGridLayout;
import org.eclipse.scout.rt.ui.swing.SwingPopupWorker;
import org.eclipse.scout.rt.ui.swing.SwingUtility;
import org.eclipse.scout.rt.ui.swing.ext.BorderLayoutEx;
import org.eclipse.scout.rt.ui.swing.ext.JPanelEx;
import org.eclipse.scout.rt.ui.swing.ext.JStatusLabelEx;
import org.eclipse.scout.rt.ui.swing.form.fields.SwingScoutFieldComposite;
public class SwingScoutColorPickerField extends SwingScoutFieldComposite<IColorPickerField> {
  protected void initializeSwing() {
    JPanelEx container = new JPanelEx(new BorderLayoutEx());
    container.setOpaque(false);
    JStatusLabelEx label = new JStatusLabelEx();
    container.add(label, BorderLayoutEx.CENTER);
    MyComponent field = new MyComponent();
    SwingUtility.installDefaultFocusHandling(field);
    container.add(field);
    field.addMouseListener(m_mouseListener);
    setSwingContainer(container);
    setSwingLabel(label);
    setSwingField(field);
    getSwingContainer().setLayout(new LogicalGridLayout(getSwingEnvironment(), 1, 0));
    getSwingField().repaint();
    Color color = getColor(getScoutObject().getColor());
    // TODO: add recent colour handling : see http://stackoverflow.com/questions/10793916/jcolorchooser-save-restore-recent-colors-in-swatches-panel
    Color selectedColor = JColorChooser.showDialog(getSwingField(), TEXTS.get("SelectColor"), color);
      final String colorString = getColorString(selectedColor.getRed(), selectedColor.getGreen(), selectedColor.getBlue()).toUpperCase();
        public void run() {
          getScoutObject().getUiFacade().setColorFromUI(colorString);
      getSwingEnvironment().invokeScoutLater(t, 2345);
    return hexString;
  public Color getColor(String color) {
      return new Color(red, green, blue);
    return null;
      // TODO: clear recent
  private class MyComponent extends JComponent {
    public void paint(Graphics g) {
      super.paint(g);
      Rectangle bounds = getSwingField().getBounds();
        g.setColor(getColor(getScoutObject().getColor()));
      } else {
        g.setColor(getColor("FFFFFF"));
      g.fillRect(bounds.x, bounds.y, bounds.width - bounds.x - 1, bounds.height - 1);
      } else {
        g.setColor(getColor("000000"));
      g.drawRect(bounds.x, bounds.y, bounds.width - bounds.x - 1, bounds.height - 1);
  private class P_MouseListener extends MouseAdapter {
    public void mousePressed(MouseEvent e) {
      if (e != null) {
        if (e.getButton() == MouseEvent.BUTTON1) {
        if (e.isPopupTrigger() && e.getComponent().isEnabled()) {
          handleSwingPopup(e);
    public void mouseReleased(MouseEvent e) {
      if (e != null && e.isPopupTrigger() && e.getComponent().isEnabled()) {
    public void mouseDragged(MouseEvent e) {
  protected void handleSwingPopup(final MouseEvent e) {
    // notify Scout
      public void run() {
        IMenu[] a = getScoutObject().getUiFacade().firePopupFromUI();
        // call swing menu
        new SwingPopupWorker(getSwingEnvironment(), e.getComponent(), e.getPoint(), a).enqueue();
    getSwingEnvironment().invokeScoutLater(t, 5678);
    // end notify
plugin.xml
  <extension
        point="org.eclipse.scout.rt.ui.swing.formfields">
     <formField
           active="true"
           scope="default">
        <uiClass
              class="org.eclipse.minicrm.ui.swing.form.fields.ext.SwingScoutColorPickerField">
        </uiClass>
  </extension>
RAP
RwtScoutColorPickerField
import org.eclipse.scout.rt.ui.rap.LogicalGridLayout;
import org.eclipse.scout.rt.ui.rap.RwtMenuUtility;
import org.eclipse.scout.rt.ui.rap.ext.StatusLabelEx;
import org.eclipse.scout.rt.ui.rap.form.fields.RwtScoutFieldComposite;
public class RwtScoutColorPickerField extends RwtScoutFieldComposite<IColorPickerField> {
  protected void initializeUi(Composite parent) {
    Composite container = getUiEnvironment().getFormToolkit().createComposite(parent);
    StatusLabelEx label = getUiEnvironment().getFormToolkit().createStatusLabel(container, getScoutObject());
    Canvas canvas = getUiEnvironment().getFormToolkit().createCanvas(container);
    // context menu
    setUiContainer(container);
    setUiLabel(label);
    setUiField(canvas);
    // layout
    getUiContainer().setLayout(new LogicalGridLayout(1, 0));
    getUiField().redraw();
    Shell shell = new Shell(getUiEnvironment().getDisplay());
    if (rgb != null) {
        public void run() {
      getUiEnvironment().invokeScoutLater(t, 2345);
    shell.dispose();
    return hexString;
    return null;
        e.gc.setBackground(getUiEnvironment().getColor(getScoutObject().getColor()));
        e.gc.setForeground(getUiEnvironment().getColor("000000"));
      } else {
        e.gc.setBackground(getUiEnvironment().getColor("FFFFFF"));
      Rectangle bounds = getUiField().getBounds();
    private boolean m_mouseDown = false;
        m_mouseDown = true;
        public void run() {
      JobEx job = getUiEnvironment().invokeScoutLater(t, 1200);
      try {
        job.join(1200);
        // nop
        RwtMenuUtility.fillContextMenu(scoutMenusRef.get(), getUiEnvironment(), m_contextMenu);
      if (menu != null) {
        menu.dispose();
      item.dispose();
plugin.xml
   <extension
         point="org.eclipse.scout.rt.ui.rap.formfields">
     <formField
           active="true"
           scope="default">
        <uiClass
              class="org.eclipse.minicrm.ui.rap.form.fields.ext.RwtScoutColorPickerField">
        </uiClass>
     </formField>
   </extension>
Re: Colour picker [message #1072759 is a reply to message #1072732] Tue, 23 July 2013 08:43 Go to previous messageGo to next message
Wow - thank you Urs great work.
I opened a Bugzilla413517 to track the contribution. Furthermore I will run through your changes and come up with a gerrit change for review.
-andreas
Re: Colour picker [message #1073116 is a reply to message #1072759] Wed, 24 July 2013 03:06 Go to previous messageGo to next message
A small correction, it seems there is something funny about the values getBounds() returns in all of the renderers. In order to correctly draw the fields in the currently selected colour, some code must be adjusted:
SWT & RAP
In paintControl() replace
with
      e.gc.fillRectangle(0, 0, bounds.width - 1, bounds.height - 1);
      e.gc.drawRectangle(0, 0, bounds.width - 1, bounds.height - 1);
Swing
In MyComponent.paint() Replace
      } else {
with
      g.fillRect(0, 0, bounds.width - 1, bounds.height - 1);
      g.drawRect(0, 0, bounds.width - 1, bounds.height - 1);
[Updated on: Wed, 24 July 2013 03:06] by Moderator
Re: Colour picker [message #1073130 is a reply to message #1073116] Wed, 24 July 2013 03:35 Go to previous messageGo to next message
I really think we should open a Gerrit Change to discuss the code and to push the different version (it is much more easier than in the forum).
A question from my side:
Why isn't the ColorField a ValueField<T> where <T> is a String? I think also in your example, the color is stored in a String (Like in HTML RRGGBB)?
Re: Colour picker [message #1073227 is a reply to message #1073130] Wed, 24 July 2013 06:55 Go to previous messageGo to next message
Jeremie Bresson wrote on Wed, 24 July 2013 09:35
I just discussed this whole topic offline with Andy this morning. As I understood it, he will open a Gerrit Change and make a proposal for the colour picker based on my code, with some changes that he proposed.
Because that thought only occurred to me after I had posted my code Smile It's a good idea, I think.
Re: Colour picker [message #1074156 is a reply to message #1073227] Fri, 26 July 2013 03:51 Go to previous messageGo to next message
Urs Beeli wrote on Wed, 24 July 2013 12:55
I bet you can do this by yourself. It is not so complicated and you will learn a lot of interesting stuff. (To contribute code on the Eclipse WikiText project, I learned git and gerrit... I had only knowledge of SVN before that. If you are ready you can learn it too).
There is a guide: Contributions for Scout Committers (effort in progress). Everything also apply to contributors too (just the "submit" part is for commiters only).
If you are interested, do not hesitate to ask questions in the forum. I will be happy to guide you. We can also update and improve the guide if it gets challenged.
Re: Colour picker [message #1272685 is a reply to message #1074156] Tue, 18 March 2014 09:53 Go to previous messageGo to next message
Now contributed to Luna branch
Bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=430595
Gerrit Push: https://git.eclipse.org/r/23537
Re: Colour picker [message #1279369 is a reply to message #1272685] Fri, 28 March 2014 12:42 Go to previous messageGo to next message
Thank you Urs for this great contribution. I was able to apply the patch with few changes.
Will be available with M7.
-andreas
Re: Colour picker [message #1280998 is a reply to message #1067517] Mon, 31 March 2014 03:54 Go to previous message
Hi Urs, Andy,
thank you very much for this contribution. I think this is worth a "new and noteworthy" entry on our wiki.
https://wiki.eclipse.org/Scout/NewAndNoteworthy/4.0
Would you mind to create such an entry?
Matthias
Previous Topic:Table drag & drop
Next Topic:Label Position for AbstractBooleanField
Current Time: Sun Jul 20 04:39:42 EDT 2025
Powered by FUDForum. Page generated in 0.05346 seconds
