Home » Eclipse Projects » Equinox » CNFE: Could not initialise class... (one for Simon K?)
CNFE: Could not initialise class... (one for Simon K?) [message #107058] Fri, 28 March 2008 20:25 Go to next message
There's something within the classloading in Equinox that isn't being
too helpful.
I get the following stack trace output when I start my bundle manually,
having found that it didn't start with the OSGi framework.
If I debug and catch ClassNotFoundException, I find that the failure to
initialise seems to have been caused by the super class of
FuzzAbderaServlet contains a reference to a class that cannot be
resolved, which in this case is: org.apache.commons.logging.Log
There are two things that I want to see in my exception trace that I'm
not seeing:
1) That it is org.apache.commons.logging.Log that is the class that
cannot be found
2) That the context in which it cannot be found is the bundle containing
the base class, AbderaServlet.
(Lastly: It's after midnight on Friday night, here, and I've had 3
Hoegarden, so I'm quite surprised I've tracked this down at all...)
Neale
org.osgi.framework.BundleException: Exception in
com.wwm.atom.impl.Activator.start() of bundle AtomServlet.
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1018)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:257)
at
org.eclipse.osgi.framework.internal.core.FrameworkCommandPro vider._start(FrameworkCommandProvider.java:257)
at
at
at
org.eclipse.osgi.framework.internal.core.FrameworkCommandInt erpreter.execute(FrameworkCommandInterpreter.java:150)
at
org.eclipse.osgi.framework.internal.core.FrameworkConsole.do command(FrameworkConsole.java:298)
at
org.eclipse.osgi.framework.internal.core.FrameworkConsole.co nsole(FrameworkConsole.java:283)
at
org.eclipse.osgi.framework.internal.core.FrameworkConsole.ru n(FrameworkConsole.java:219)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class
com.wwm.atom.impl.FuzzAbderaServlet
at com.wwm.atom.impl.Activator.start(Activator.java:22)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
... 14 more
Nested Exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
Nested Exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
osgi>
Re: CNFE: Could not initialise class... (one for Simon K?) [message #107073 is a reply to message #107058] Sat, 29 March 2008 12:50 Go to previous messageGo to next message
I can answer this one myself now, although I still think that the "Could
not initialise case could be more useful".
I've discovered (source code is useful to send you looking) that on the
OSGi Launch Config, we can set Tracing for org.eclipse.osgi, and that
ticking just "debug" gives about the right amount of information to go
hunting down the library dependencies to put in.
I'm now starting to think that any Java project worth it's salt should
be packaging their Jar as an OSGi bundle. It just makes sense!
Neale wrote:
> too helpful.
> not seeing:
> cannot be found
> Cheers,
> Neale
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 14 more
> Nested Exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Nested Exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> osgi>
Re: CNFE: Could not initialise class... (one for Simon K?) [message #107180 is a reply to message #107073] Mon, 31 March 2008 14:30 Go to previous message
Sounds like you've found your way out of this mess. CNFEs can be a real pain
to track down.
For dependencies in 3rd party jars when you don't necessarily have the
source I like use a tool called DependencyFinder.
> I'm now starting to think that any Java project worth it's salt should be
Couldn't agree more.
I still do some development where the class-path is flat however I still use
bundles (and PDE) at dev time. Enforced modularity is a good thing.
-Simon
"Neale" <neale@nealeupstone.com> wrote in message
news:fslrvm$1ct$1@build.eclipse.org...
> Neale wrote:
>> Hi,
>> too helpful.
>> not seeing:
>> cannot be found
>> Cheers,
>> Neale
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 14 more
>> Nested Exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Nested Exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> osgi>
Previous Topic:Starting Eclipse from Java
Next Topic:p2 install to other directories
Current Time: Fri Nov 14 04:17:49 EST 2025
Powered by FUDForum. Page generated in 0.04277 seconds
