Home » Modeling » Graphiti » "Click through" an unfilled RoundedRectangle
"Click through" an unfilled RoundedRectangle [message #1070795] Thu, 18 July 2013 13:35 Go to next message
Hi all,
I have a ContainerShape for which I create an unfilled RoundedRectangle. This is used to group other shapes together visually such that when the group shape is moved, any shapes that are completely contained by the group shape are moved along with it. I've also arranged to always keep the group shape at the top of the Z-order so that it can't be obscured by any other shapes (a requirement).
The move feature works, but now I'm unable to "click through" the group shape to any of the contained shapes. Also, the mouse hit test does not find any of the contained shapes because the group shape is the first one it finds, thus none of the context buttons appear for the contained shapes. Is there a way to do this without having to create a PolyLine instead of a RoundedRectangle? Ideally what I'd like is to have the group shape pass all mouse hits down to contained shapes, but not down to the Diagram.
Thanks in advance,
Bob
Re: "Click through" an unfilled RoundedRectangle [message #1070810 is a reply to message #1070795] Thu, 18 July 2013 14:16 Go to previous messageGo to next message
Uhh...never mind, I think I've found the answer:
I just need to implement my own getSelection() in my Tool Behavior Provider - duh Embarrassed
[Updated on: Thu, 18 July 2013 14:21] by Moderator
Re: "Click through" an unfilled RoundedRectangle [message #1070840 is a reply to message #1070810] Thu, 18 July 2013 16:01 Go to previous messageGo to next message
OK, this is working Smile but there's one little problem remaining:
The ContextButtonManagerForPad does not do the same translation as the ShapeEditPart does in its getTargetEditPart() method, so the context button pad being displayed is always the one for the group shape, not the contained shapes.
Is it possible to add a call to DefaultToolBehaviorProvider.getSelection() in ContextButtonManagerForPad.showContextButtonsInstantly() (or somewhere in that "mouse entered" listener call chain)?
Please let me know if I should create an enhancement request BZ.
Bob
Re: "Click through" an unfilled RoundedRectangle [message #1073275 is a reply to message #1070840] Wed, 24 July 2013 08:53 Go to previous messageGo to next message
Bob,
you chose a rather unusual way to solve the click-through-issue. I would
recommend to not do it by placing the container shape on top of the inner
shapes, but by making the inner shapes not movable (by disabling the move
feature for them). Then you should not run into the other issues...
Michael
Re: "Click through" an unfilled RoundedRectangle [message #1073710 is a reply to message #1073275] Thu, 25 July 2013 06:46 Go to previous message
Hi Michael,
Thanks for the hint, but I need to be able to move the inner shapes into and out of the Group shape so disabling their Move Feature is not an option. I've also run into a couple of other problems with this solution, unrelated to Graphiti.
I finally decided to use a Polyline GA for the Group shape and changed its Move Feature to adjust the locations of the contained shapes in postMove() by invoking their Move Features.
Bob
Previous Topic:Code Generation for Graphiti
Next Topic:How to gracefully cancel a transaction?
Current Time: Sat Jul 19 17:42:29 EDT 2025
Powered by FUDForum. Page generated in 0.03932 seconds
