Home » Archived » Jubula » How to wait for expanding a tree?
How to wait for expanding a tree? [message #1070640] Thu, 18 July 2013 07:19 Go to next message
I expand my tree of a RCP application with the jubula module "ub_tre_expandNode_byIndexpath". My application has to load the trees nodes from a database so it takes a few seconds (2-5s) to expand the nodes of a tree. If i want to go to the next step in my test case, which needs the expanded node, the error occurs: "Node not found" because it is not loaded yet. I am using a work around by using the jubula module "ub_app_wait". By waiting 8000 milliseconds, my application has enough time to load the node of the tree.
Is there a possibilty in jubula to go on with the test case right now if the node is loaded similar to the jubula module "up_app_waitForWindow"?
I hope you can help me Smile
Kind regards,
Philipp Wueller
Re: How to wait for expanding a tree? [message #1070669 is a reply to message #1070640] Thu, 18 July 2013 08:34 Go to previous messageGo to next message
You can simulate a "waitForNode" by using a retry event handler with a wait in it.
Re: How to wait for expanding a tree? [message #1070724 is a reply to message #1070669] Thu, 18 July 2013 10:39 Go to previous messageGo to next message
Thats sounds good, but I think it is not possible to implement loops with jubula? Which modules should I use to implement the retry event handler?
Re: How to wait for expanding a tree? [message #1070874 is a reply to message #1070724] Thu, 18 July 2013 17:21 Go to previous messageGo to next message
You can use ub_tre_checkExistenceOfNode_byIndexpath, and to the test case in which you're calling it, add ub_app_wait as an event handler with event type = "Check Failed" and reentry type = "RETRY". For example, if you wanted to check for the node once each second for 8 seconds, you could specify 8 as the number of retries, and 1000 ms as the duration of the ub_app_wait.
Re: How to wait for expanding a tree? [message #1071022 is a reply to message #1070874] Fri, 19 July 2013 03:15 Go to previous message
It is working pretty well Smile.
Thank you very much for your help!
Previous Topic:How to properly integrate Jubula with Jenkins
Next Topic:My Jubula Toolkit plug-in for custom GUI-Components doesn't work
Current Time: Sat Jul 19 14:36:50 EDT 2025
Powered by FUDForum. Page generated in 0.24739 seconds
