Home » Eclipse Projects » P2 » Director randomly failing
Director randomly failing [message #1070404] Wed, 17 July 2013 18:42 Go to next message
I keep seeing this happen with the director application. It is trying to install bundles that are already there from the same location they were installed from. This seems to happen prior to the requested IU being installed. If the director is run again without changes, it usually works the second time without issues.
!SESSION 2013-07-17 17:24:04.369 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_13
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -repository repository_list_goes_here -flavor tooling -roaming -d eclipse -p EquinoxOSGiStarterKit -i com.openmethods.iserver.clients.rightnow.feature.group
Command-line arguments: -repository repository_list_goes_here -flavor tooling -roaming -d eclipse -p EquinoxOSGiStarterKit -i com.openmethods.iserver.clients.rightnow.feature.group
!ENTRY org.eclipse.update.configurator 4 0 2013-07-17 17:24:05.859
!MESSAGE Could not install bundle plugins/org.apache.ant_1.8.3.v20120321-1730/ Bundle "org.apache.ant" version "1.8.3.v20120321-1730" has already been installed from: reference:file:plugins/org.apache.ant_1.8.3.v20120321-1730/
!ENTRY org.eclipse.update.configurator 4 0 2013-07-17 17:24:05.860
!MESSAGE Could not install bundle plugins/org.apache.commons.codec_1.3.0.v201101211617/ Bundle "org.apache.commons.codec" version "1.3.0.v201101211617" has already been installed from: reference:file:plugins/org.apache.commons.codec_1.3.0.v201101211617/
!ENTRY org.eclipse.update.configurator 4 0 2013-07-17 17:24:05.862
!MESSAGE Could not install bundle plugins/org.apache.commons.httpclient_3.1.0.v201012070820/ Bundle "org.apache.commons.httpclient" version "3.1.0.v201012070820" has already been installed from: reference:file:plugins/org.apache.commons.httpclient_3.1.0.v201012070820/
!ENTRY org.eclipse.update.configurator 4 0 2013-07-17 17:24:05.863
!MESSAGE Could not install bundle plugins/org.apache.commons.logging_1.0.4.v201101211617.jar Bundle "org.apache.commons.logging" version "1.0.4.v201101211617" has already been installed from: reference:file:plugins/org.apache.commons.logging_1.0.4.v201101211617.jar
!ENTRY org.eclipse.update.configurator 4 0 2013-07-17 17:24:05.866
!MESSAGE Could not install bundle plugins/org.eclipse.core.contenttype_3.4.200.v20120523-2004.jar Bundle "org.eclipse.core.contenttype" version "3.4.200.v20120523-2004" has already been installed from: reference:file:plugins/org.eclipse.core.contenttype_3.4.200.v20120523-2004.jar
!ENTRY org.eclipse.update.configurator 4 0 2013-07-17 17:24:05.867
!MESSAGE Could not install bundle plugins/org.eclipse.core.jobs_3.5.300.v20120622-204750.jar Bundle "org.eclipse.core.jobs" version "3.5.300.v20120622-204750" has already been installed from: reference:file:plugins/org.eclipse.core.jobs_3.5.300.v20120622-204750.jar
!ENTRY org.eclipse.update.configurator 4 0 2013-07-17 17:24:05.874
!MESSAGE Could not install bundle plugins/org.eclipse.core.net.linux.x86_64_1.1.0.v20120522-1148.jar Bundle "org.eclipse.core.net.linux.x86_64" version "1.1.0.v20120522-1148" has already been installed from: reference:file:plugins/org.eclipse.core.net.linux.x86_64_1.1.0.v20120522-1148.jar
!ENTRY org.eclipse.update.configurator 4 0 2013-07-17 17:24:05.878
!MESSAGE Could not install bundle plugins/org.eclipse.core.net_1.2.200.v20120522-1148.jar Bundle "org.eclipse.core.net" version "1.2.200.v20120522-1148" has already been installed from: reference:file:plugins/org.eclipse.core.net_1.2.200.v20120522-1148.jar
!ENTRY org.eclipse.update.configurator 4 0 2013-07-17 17:24:05.880
!MESSAGE Could not install bundle plugins/org.eclipse.core.runtime_3.8.0.v20120521-2346.jar Bundle "org.eclipse.core.runtime" version "3.8.0.v20120521-2346" has already been installed from: reference:file:plugins/org.eclipse.core.runtime_3.8.0.v20120521-2346.jar
!ENTRY org.eclipse.update.configurator 4 0 2013-07-17 17:24:05.881
!MESSAGE Could not install bundle plugins/org.eclipse.ecf.filetransfer_5.0.0.v20120610-1946.jar Bundle "org.eclipse.ecf.filetransfer" version "5.0.0.v20120610-1946" has already been installed from: reference:file:plugins/org.eclipse.ecf.filetransfer_5.0.0.v20120610-1946.jar
!ENTRY org.eclipse.update.configurator 4 0 2013-07-17 17:24:05.883
!MESSAGE Could not install bundle plugins/org.eclipse.ecf.identity_3.1.200.v20120610-1946.jar Bundle "org.eclipse.ecf.identity" version "3.1.200.v20120610-1946" has already been installed from: reference:file:plugins/org.eclipse.ecf.identity_3.1.200.v20120610-1946.jar
Re: Director randomly failing [message #1070667 is a reply to message #1070404] Thu, 18 July 2013 08:30 Go to previous messageGo to next message
Remove org.eclipse.update.configurator from the product, or set org.eclipse.update.reconcile=false
Re: Director randomly failing [message #1070712 is a reply to message #1070667] Thu, 18 July 2013 10:20 Go to previous message
The target eclipse install doesn't have that bundle installed. It is however present in the standalone director package. Is that bundle required for the standalone director to function or can I just disable it via the org.eclipse.update.reconcile=false property?
Previous Topic:Plugins not installed properly?
Next Topic:No repository found at xyz (ProvisionException)
Current Time: Sat Jul 19 13:07:07 EDT 2025
Powered by FUDForum. Page generated in 0.04748 seconds
