Home » Eclipse Projects » Remote Application Platform (RAP) » Mnemonic on top level menu item(does not fire selection event)
Mnemonic on top level menu item [message #1068172] Fri, 12 July 2013 10:12 Go to next message
Hi all,
since fix of this bug [1] firing selection events on top level menu items is supported. However, the selection event is still not fired when using mnemonics on the top level menu item.
In SWT, the following snippet fires the selection event for both menu items ("&Submenu" and "&Top Level Menu Item") when using the mnemonics. In RWT only "&Submenu" is selected:
	protected void createContents(final Composite parent) {
		// define mnemonic activator and create menu bar
		getShell().getDisplay().setData(RWT.MNEMONIC_ACTIVATOR, "CTRL+ALT");
		final Menu menuBar = new Menu(getShell(), SWT.BAR);
		// create cascading menu item
		final MenuItem cascadeMenuItem = createMenuItem(menuBar, SWT.CASCADE, "&Cascade Menu Item");
		// create sub menu item of cascading menu item
		final Menu submenu = new Menu(getShell(), SWT.DROP_DOWN);
		cascadeMenuItem.setMenu(submenu);
		createMenuItem(submenu, SWT.PUSH, "&Submenu");
		// create top level menu item
		createMenuItem(menuBar, SWT.PUSH, "&Top Level Menu Item");
		// set menu bar to shell
		getShell().setMenuBar(menuBar);
	private static MenuItem createMenuItem(final Menu parent, final int style, final String text) {
		final MenuItem menuItem = new MenuItem(parent, style);
		menuItem.setText(text);
		menuItem.addSelectionListener(new SelectionAdapter() {
			public void widgetSelected(final SelectionEvent e) {
				System.out.println("Selected item: " + text);
		return menuItem;
I would like to have the same behaviour with mnemonics as with mouse selection. Does anyone know of another way to do it?
I would suggest to implement the same behaviour in RWT, if possible.
Sebastian
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=397094
[Updated on: Fri, 12 July 2013 10:16] by Moderator
Re: Mnemonic on top level menu item [message #1069091 is a reply to message #1068172] Mon, 15 July 2013 02:39 Go to previous messageGo to next message
Hi Sebastian,
I can reproduce it with our Controls Demo + small changes. Please file a
bugzilla to track the progress on the issue.
Ivan
On 7/12/2013 5:12 PM, Sebastian Habenicht wrote:
> Hi all,
> mnemonics. In RWT only "&Submenu" gets selected:
> @Override
> "CTRL+ALT");
> @Override
> System.out.println("Selected item: " + text + " " +
> e.item);
> return menuItem;
> Regards,
> Sebastian
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Mnemonic on top level menu item [message #1070351 is a reply to message #1068172] Wed, 17 July 2013 15:50 Go to previous message
Thank you, Ivan, bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=413203
Sebastian
Previous Topic:How to change the alignment image/text in a ToolItem?
Next Topic:branding body background
Current Time: Sun Jul 20 11:47:32 EDT 2025
Powered by FUDForum. Page generated in 0.04108 seconds
