Home » Archived » Jubula » Reusable project and object mapping
Reusable project and object mapping [message #1067917] Thu, 11 July 2013 04:51 Go to next message
I need to create a reusable project with test cases which are used for different component in the same AUT or in defferents AUT.
My problem is when I reuse my test cases I can't change the component.
How can I change my object mapping to be able to reused my test case ?
Thanks per advance
Re: Reusable project and object mapping [message #1069110 is a reply to message #1067917] Mon, 15 July 2013 03:21 Go to previous messageGo to next message
Have a look at the section in the documentation on reassigning component names:
http://help.eclipse.org/kepler/topic/org.eclipse.jubula.client.ua.help/html/manual/node155.html?cp=26_2_12_1
HTH!
Alex
Re: Reusable project and object mapping [message #1069611 is a reply to message #1069110] Tue, 16 July 2013 04:34 Go to previous message
Thanks for you reply!
All works fine now.
Previous Topic:Code Coverage (JaCoCo) Problem
Next Topic:extend jubula
Current Time: Sat Jul 19 20:09:31 EDT 2025
Powered by FUDForum. Page generated in 0.31835 seconds
