Home » Modeling » TMF (Xtext) » An error has occured See the log file ... .log
An error has occured See the log file ... .log [message #1069219] Mon, 15 July 2013 08:45 Go to next message
Hi All,
I recently rebuilt my project against xtext 2.4.2 and since then my workspaces keep getting corrupted.
It happens when I launch eclipse, select a workspace and then quickly close it (whilst it is building), when I reopen I get the dialog: An error has occured see the log file ... .log
Not sure why this is happening but the only thing that fixes it is to delete the .snap file:
rm .plugins/org.eclipse.core.resources/.snap
Has anyone else experienced this?
Here is my log file below, I cannot figure out what is happening here Sad
!SESSION 2013-07-15 13:38:59.893 -----------------------------------------------
eclipse.buildId=4.3.0.I20130605-2000
java.version=1.6.0_51
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments:  -product org.eclipse.epp.package.standard.product -keyring /Users/fluxtah/.eclipse_keyring -showlocation
Command-line arguments:  -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.standard.product -keyring /Users/fluxtah/.eclipse_keyring -showlocation
!ENTRY org.eclipse.core.resources 2 10035 2013-07-15 13:39:03.237
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.equinox.preferences 4 2 2013-07-15 13:39:04.887
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.equinox.preferences".
!STACK 0
java.lang.ExceptionInInitializerError
	at org.eclipse.jdt.ui.PreferenceConstants.initializeDefaultValues(PreferenceConstants.java:3739)
	at org.eclipse.jdt.internal.ui.JavaUIPreferenceInitializer.initializeDefaultPreferences(JavaUIPreferenceInitializer.java:38)
	at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper$1.run(PreferenceServiceRegistryHelper.java:300)
	at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.runInitializer(PreferenceServiceRegistryHelper.java:303)
	at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.applyRuntimeDefaults(PreferenceServiceRegistryHelper.java:131)
	at org.eclipse.core.internal.preferences.PreferencesService.applyRuntimeDefaults(PreferencesService.java:368)
	at org.eclipse.core.internal.preferences.DefaultPreferences.applyRuntimeDefaults(DefaultPreferences.java:221)
	at org.eclipse.core.internal.preferences.DefaultPreferences.load(DefaultPreferences.java:274)
	at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:409)
	at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences.java:670)
	at org.eclipse.core.internal.preferences.EclipsePreferences.node(EclipsePreferences.java:812)
	at org.eclipse.core.internal.preferences.AbstractScope.getNode(AbstractScope.java:38)
	at org.eclipse.core.runtime.preferences.DefaultScope.getNode(DefaultScope.java:76)
	at org.eclipse.ui.preferences.ScopedPreferenceStore.getDefaultPreferences(ScopedPreferenceStore.java:250)
	at org.eclipse.ui.preferences.ScopedPreferenceStore.getPreferenceNodes(ScopedPreferenceStore.java:285)
	at org.eclipse.ui.preferences.ScopedPreferenceStore.internalGet(ScopedPreferenceStore.java:475)
	at org.eclipse.ui.preferences.ScopedPreferenceStore.getBoolean(ScopedPreferenceStore.java:387)
	at org.eclipse.jdt.internal.ui.preferences.MembersOrderPreferenceCache.install(MembersOrderPreferenceCache.java:61)
	at org.eclipse.jdt.internal.ui.JavaPlugin.ensurePreferenceStoreBackwardsCompatibility(JavaPlugin.java:426)
	at org.eclipse.jdt.internal.ui.JavaPlugin.start(JavaPlugin.java:373)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:478)
	at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
	at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:109)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
	at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
	at org.eclipse.xtext.ui.shared.internal.Activator.isJavaEnabled(Activator.java:87)
	at org.eclipse.xtext.ui.shared.internal.Activator.initializeInjector(Activator.java:57)
	at org.eclipse.xtext.ui.shared.internal.Activator.start(Activator.java:102)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
	at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
	at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.jdt.internal.core.JavaModelManager$4.run(JavaModelManager.java:332)
	at org.eclipse.jdt.internal.core.JavaModelManager$CompilationParticipants.getCompilationParticipants(JavaModelManager.java:327)
	at org.eclipse.jdt.internal.core.builder.JavaBuilder.initializeBuilder(JavaBuilder.java:587)
	at org.eclipse.jdt.internal.core.builder.JavaBuilder.build(JavaBuilder.java:167)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:726)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
	at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
	at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
	at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
	at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
	at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: org.eclipse.swt.SWTException: Invalid thread access
	at org.eclipse.swt.SWT.error(SWT.java:4397)
	at org.eclipse.swt.SWT.error(SWT.java:4312)
	at org.eclipse.swt.SWT.error(SWT.java:4283)
	at org.eclipse.swt.widgets.Display.error(Display.java:1076)
	at org.eclipse.swt.widgets.Display.checkDevice(Display.java:624)
	at org.eclipse.swt.graphics.Device.getSystemFont(Device.java:481)
	at org.eclipse.jface.preference.PreferenceConverter.<clinit>(PreferenceConverter.java:84)
	... 83 more
!ENTRY org.eclipse.osgi 4 0 2013-07-15 13:39:04.893
!MESSAGE An error occurred while automatically activating bundle org.eclipse.jdt.ui (169).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.jdt.internal.ui.JavaPlugin.start() of bundle org.eclipse.jdt.ui.
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.jface.preference.PreferenceConverter
	at org.eclipse.jdt.internal.ui.JavaPlugin.ensurePreferenceStoreBackwardsCompatibility(JavaPlugin.java:448)
	... 59 more
Root exception:
!ENTRY org.apache.log4j 2 0 2013-07-15 13:39:04.897
!MESSAGE org.eclipse.xtext.ui.shared.internal.Activator  - Disabling JDT use. : org/eclipse/jdt/ui/JavaUI
!ENTRY org.apache.log4j 2 0 2013-07-15 13:39:05.106
!ENTRY org.eclipse.osgi 4 0 2013-07-15 13:39:06.478
!MESSAGE Application error
!STACK 1
	at org.eclipse.ui.internal.themes.ThemeElementHelper.installFont(ThemeElementHelper.java:104)
	at org.eclipse.ui.internal.themes.ThemeElementHelper.populateRegistry(ThemeElementHelper.java:59)
	at org.eclipse.ui.internal.Workbench$29.runWithException(Workbench.java:1699)
	at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3976)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3653)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2683)
	at org.eclipse.ui.internal.Workbench.access$7(Workbench.java:2591)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:608)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.737
!MESSAGE Job found still running after platform shutdown.  Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.activities.MutableActivityManager$3$1
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.738
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.744
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.745
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.746
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.747
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.748
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.749
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.750
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.751
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.752
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.753
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.754
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.755
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.756
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.757
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.758
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.759
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.760
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.761
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.762
!ENTRY org.eclipse.core.jobs 2 2 2013-07-15 13:39:07.763
Re: An error has occured See the log file ... .log [message #1231947 is a reply to message #1069219] Wed, 15 January 2014 15:58 Go to previous messageGo to next message
Please start eclipse with -clean option.
c:\eclipse\eclipse.exe -clean
If you have a shortcut for eclipse - change the property of the Target to C:\eclipse\eclipse.exe -clean
Re: An error has occured See the log file ... .log [message #1232759 is a reply to message #1231947] Fri, 17 January 2014 12:00 Go to previous message
I had the same problem. After spending many hours trying to figure out the problem, launching eclipse with the -clean option solved the issue.
Thanks a lot.
Previous Topic:Warning 'The imported package is not on the classpath...' after update
Next Topic:Instantiating instance of Java Class corresponding to JvmDeclaredType
Current Time: Sat Jul 19 10:02:38 EDT 2025
Powered by FUDForum. Page generated in 0.03953 seconds
