Home » Archived » Visual Editor (VE) » VE only shows ContentPane
VE only shows ContentPane [message #106853] |
Fri, 16 September 2005 20:28  |
The visual editor appears to be functional, but it is only showing the
JFrame. All the components that are assigned to the JFrame's contentPane do
not appear. This occured after I reverted back to a previous eclipse
configuration because the JBoss Workflow IDE doesn't get along with
MyEclipse. That is a long story.
When I put the mouse over the displayed JFrame, I get a message (I wish it
would stay up). The message is:
contentPane:java.lang.IllegalArgumentException(IWAV0167E access by method
name(getContentPane) (not by Proxy) requires a receiver.)
I don't think I ever saw this message before, so I assume it is telling what
the problem is. The GUI compiles and runs. I just can't get the VE editor
back. Can someone suggest how I might get the visual editor of this JFrame
back?
Bud Curtis
Colorado Springs, CO
Re: VE only shows ContentPane [message #106953 is a reply to message #106928] |
Sat, 17 September 2005 10:54   |
Is there a way to have multiple configurations for Eclipse, or do I need
separate (eclipse root) folders for each configuration?
Bud Curtis
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:dgh9qc$fpu$1@news.eclipse.org...
> Try it in a config with only Eclipse SDK 3.1, VE 1.1.0.1, EMF 2.1, and
> GEF 3.1. MyEclipse is often different levels of these projects and
> causes conflicts.
contentPane do
it
method
what
editor
JFrame
> > back?
> Rich Kulp
Re: VE only shows ContentPane [message #107288 is a reply to message #107147] |
Mon, 19 September 2005 23:32   |
I reinstalled with just Eclipse 3.1 SDK, GEF 3.1, and EMF 2.1. The same
problem persists.
Bud Curtis
news:dgmgdb$bq1$2@news.eclipse.org...
> What is Maven? Could you try just Eclipse 3.1 SDK, GEF 3.1, and EMF 2.1?
> Bud Curtis wrote:
> > I created an eclipse with just the Visual Editor and the Maven IDE.
This
> > was working fine. I tried the same project and got the exact same
error.
> > Is there anyway to interpret the error. The Initialize code is
elementary:
> > private void initialize() {
> > this.setSize(516, 395);
> > this.setName("jarSearchFrame");
> > this.setDefaultCloseOperation(javax.swing.JFrame.EXIT_ON_CLO SE);
> > this.setContentPane(getJContentPane());
> > this.setTitle("Archive Searcher");
> > this.addWindowListener(new java.awt.event.WindowAdapter()
> > public void windowClosing(java.awt.event.WindowEvent
> > evt)
> > exitForm(evt);
> > * This method initializes jContentPane
> > * @return javax.swing.JPanel
> > private JPanel getJContentPane() {
> > if (jContentPane == null) {
> > jContentPane = new JPanel();
> > jContentPane.setLayout(new BorderLayout());
> > jContentPane.add(getStatusPanel(), java.awt.BorderLayout.SOUTH);
> > jContentPane.add(getSplitPane(), java.awt.BorderLayout.CENTER);
> > return jContentPane;
> > When I run the program I get the expected JFrame with all the components
> > showing.
> Rich Kulp
Re: VE only shows ContentPane [message #107551 is a reply to message #107410] |
Tue, 20 September 2005 10:38  |
Sorry, no ideas.
Bud Curtis wrote:
> I got it to work by deleting the project from Eclipse, and then importing
> the project back into Eclipse. There must be something in the workspace
> that needed to be reset before it would interpret the code. Any ideas?
Rich Kulp
Re: VE only shows ContentPane [message #610788 is a reply to message #106853] |
Sat, 17 September 2005 10:39  |
causes conflicts.
> back?
Rich Kulp
Re: VE only shows ContentPane [message #610790 is a reply to message #106928] |
Bud Curtis
> causes conflicts.
contentPane do
it
method
what
editor
JFrame
> > back?
> Rich Kulp
Re: VE only shows ContentPane [message #610791 is a reply to message #106953] |
Sat, 17 September 2005 12:21  |
AS far as I know you need separate roots. There are probably some
complex way of doing it, but I myself have at least five different
configurations for my work.
Rich Kulp
Re: VE only shows ContentPane [message #610799 is a reply to message #106967] |
Sun, 18 September 2005 16:10  |
I created an eclipse with just the Visual Editor and the Maven IDE. This
was working fine. I tried the same project and got the exact same error.
Is there anyway to interpret the error. The Initialize code is elementary:
evt)
exitForm(evt);
showing.
Bud Curtis
news:dghfqb$lg3$1@news.eclipse.org...
> Rich Kulp
Re: VE only shows ContentPane [message #610804 is a reply to message #107076] |
Mon, 19 September 2005 10:02  |
> evt)
> exitForm(evt);
> showing.
Rich Kulp
Re: VE only shows ContentPane [message #610815 is a reply to message #107147] |
problem persists.
Bud Curtis
This
error.
elementary:
> > evt)
> > exitForm(evt);
> > showing.
> Rich Kulp
Re: VE only shows ContentPane [message #610816 is a reply to message #107147] |
Mon, 19 September 2005 23:42  |
Bud Curtis
This
error.
elementary:
> > evt)
> > exitForm(evt);
> > showing.
> Rich Kulp
Re: VE only shows ContentPane [message #610826 is a reply to message #107410] |
Sorry, no ideas.
Rich Kulp
Current Time: Sat Jul 19 16:40:06 EDT 2025
Powered by FUDForum. Page generated in 0.18222 seconds
