Home » Archived » BIRT » Use HTML document in hyperlink
Use HTML document in hyperlink [message #1067861] Wed, 10 July 2013 18:52 Go to next message
I want to display a word help document saved in .htm format from a report. The document is resident in the report folder. It has text and images.
What is the syntax to link to such a file?
I have tried "file:help.htm" "file:/help.htm" "file://help.htm"
Is it possible? What syntax should I try?
Or is there another way to display a html document from within BIRT?
I've successfully used hyperlink to link to web resources, and drill through into reports.
I am using 3.7.2
Re: Use HTML document in hyperlink [message #1068053 is a reply to message #1067861] Thu, 11 July 2013 16:26 Go to previous messageGo to next message
You could use an iFrame in a text item
<iframe src="C:\Users\kclark\Desktop\test.html">
  <p>Your browser does not support iframes.</p>
</iframe>
</body>
</html>
Re: Use HTML document in hyperlink [message #1068147 is a reply to message #1068053] Fri, 12 July 2013 08:22 Go to previous message
Thank you Kristopher! That worked.
Previous Topic:birt internationalization
Next Topic:How to upgrade birt server engine to 4.3
Current Time: Sun Jul 20 02:53:19 EDT 2025
Powered by FUDForum. Page generated in 0.04353 seconds
