Home » Eclipse Projects » WindowBuilder » Which wizard to use by Google Windowbuilder to create a standard or tabbed Eclipse Properties View?
Which wizard to use by Google Windowbuilder to create a standard or tabbed Eclipse Properties View? [message #1067742] Wed, 10 July 2013 08:01 Go to next message
Hello there!
Does Google WindowBuilder Pro has a standard wizard for creating PropertySections, which can be used with Tabbed Properties View of Eclipse? When the answer is no, what would be the best way to integrate a with Google WindowBuilder created view into the tabbed properties?
I have created a view but it is a standalone one, but I want to have this view to be shown under the properties view within its own tab, when the corresponding workbench contributor is selected. Also, which would be the best WindowBuilder wizard for such an integration? A ViewPart, a Composite or -maybe even- an Application Window, which I can't be sure.
Every help will be appreciated. Thanks.
Re: Which wizard to use by Google Windowbuilder to create a standard or tabbed Eclipse Properties Vi [message #1067849 is a reply to message #1067742] Wed, 10 July 2013 16:56 Go to previous message
If you are using the Eclipse e4 framework, I suppose you could use an e4 ViewPart.
Otherwise, you can pretty much use a Composite for just about anything and then wrapper it in the bits you need for the framework.
Previous Topic:Design page show wrong frame
Next Topic:Hard-coded text fields versus an array of text fields
Current Time: Sat Jul 19 19:43:02 EDT 2025
Powered by FUDForum. Page generated in 0.03728 seconds
