Home » Eclipse Projects » Eclipse 4 » Toolbar items disappears when no parts opened (compatibilty mode)
Toolbar items disappears when no parts opened (compatibilty mode) [message #1065933] Fri, 28 June 2013 07:43 Go to next message
Hi all,
I have 3.x RCP application which I tried to run in Kepler (compatibility
mode), everything went smooth except one thing - by default (when open first
time) workbench has no opened views and/or editors, in this case all toolbar
items are invisible, then if I open any view and restart application toolbar
items are visible (process can be repeated).
I've tried this with well known Mail Application (from RCP project wizard) -
same effect, easy to repeat. Does anybody knows workaround?
Sergey.
Re: Toolbar items disappears when no parts opened (compatibilty mode) [message #1066182 is a reply to message #1065933] Mon, 01 July 2013 08:50 Go to previous messageGo to next message
Should I considered it as bug?
"Sergey Kuznetsov" wrote in message news:kqjss7$l1t$1@xxxxxxxxe.org...
Hi all,
Sergey.
Re: Toolbar items disappears when no parts opened (compatibilty mode) [message #1067680 is a reply to message #1066182] Wed, 10 July 2013 01:45 Go to previous messageGo to next message
I'm able to replicate the same issue while running a 3.x RCP application in compatibility mode using Kepler.
The top toolbar is initially visible for a few moments, but then disappears.
Re: Toolbar items disappears when no parts opened (compatibilty mode) [message #1067998 is a reply to message #1067680] Thu, 11 July 2013 11:31 Go to previous message
I just tried the RCP mail app and it shows the toolbar on its initial startup.
Do I understand correctly that in your case the presentation is initially
empty (i.e. no open views...) ?
Is there a way you could attach a cut down version of your rcp app ?
Previous Topic:ElementListSelectionDialog on Eclipse 4
Next Topic:Fragments and model elements merging
Current Time: Sun Jul 20 10:18:00 EDT 2025
Powered by FUDForum. Page generated in 0.04170 seconds
