Re: Turn off auto-insert? [message #1067580 is a reply to message #1067502] |
Tue, 09 July 2013 08:34  |
Konner,
I don't see anything like the behavior you describe. Is there something
odd about the settings you have grouped under Enable auto activation,
like maybe you put a space character in there as an enabler?
On 09/07/2013 1:05 PM, Konner Rasmussen wrote:
> Why in the world would you guys make auto-insert something that cant
> be disabled?
> take for example...
> i will be writing code like so:
> public myClass(int arg1)
> this.arg1 = arg1
> then i will realize that i want to add an argument, like so:
> public myClass(int arg1, int // i DO NOT want it to automatically
> insert "Integer" // when i put a space
> after the "t" in "int"
> now... i like the code -SUGGESTIONS- i do not however like the fact
> that hitting spacebar (which i cannot avoid doing) will automagically
> insert what is at the top of the list when i in no way was trying to
> use what it suggested.
> now i HEARD that disabling "insert single proposals automatically"
> should fix this... for some reason it does not
> am i missing something or is this just something that has been
> overlooked...
> again i love the code suggestions with the ability to insert something
> if i want to... but i am REQUIRED to hit spacebar in the process of
> coding... if i might be so bold as to say: what is the point in having
> cake if you cant eat it too?
FUDForum. Page generated in 0.03070 seconds
