Home » Modeling » QVT-OML » Shortcut for subpackages?
Shortcut for subpackages? [message #1064905] Fri, 21 June 2013 11:10 Go to next message
Hello, I have a very basic question: is it possible, in a QVTO script, to define 'shortcut' names for subpackages? I'm writing a transformation but I end up with very long names, like
CIM::IEC61968::AssetInfo::PowerTransformerInfo
CIM::IEC61970::Topology::TopologicalNode
This produces some very bad-looking code.
Thanks a lot!
Daniele Pala
Re: Shortcut for subpackages? [message #1066722 is a reply to message #1064905] Thu, 04 July 2013 01:45 Go to previous messageGo to next message
Suddenly had an idea. The basic ModelType syntax is
modeltype UML uses SimpleUml ("http://omg.qvt-examples.SimpleUml");
Have you tried using a fragment URI such as
modeltype AssetInfo uses AssetInfo ("...CIM#/IEC61968/AssetInfo");
EMF should share the multiple loads of ...CIM
so QVTo should recognize that
CIM::IEC61968::AssetInfo::PowerTransformerInfo and
AssetInfo::PowerTransformerInfo are the same type. But it might be safer
to use a different spelling for the alias.
(You can find the correct spelling of the fragment in any serialized XMI
reference to the target).
Ed Willink
> Thanks a lot!
> Daniele Pala
Re: Shortcut for subpackages? [message #1067422 is a reply to message #1064905] Mon, 08 July 2013 10:57 Go to previous messageGo to next message
Hi, thanks for your reply!
It works, with this syntax:
modeltype AssetInfo uses "http: //iec.ch/TC57/2010/CIM-schema-cim15#AssetInfo";
I then have to define a new metamodel mapping in the project settings:
Source model URI:
Target model URI:
platform:/resource/atlantide2cim.bundle/models/cim15.ecore#//IEC61968/AssetInfo
I don't know if there is another syntax avoiding the metamodel mapping stuff...
Thanks again,
Daniele Pala
Re: Shortcut for subpackages? [message #1067425 is a reply to message #1067422] Mon, 08 July 2013 11:19 Go to previous message
It looks as if fragment URIs are not well supported by the modelType
syntax. Please raise a Bugzilla.
Since your http: //iec.ch/TC57/2010/CIM-schema-cim15#AssetInfo is a
fudge rather actually a fragment identifier, I recommend using some
other character such as ~ to avoid confusing some unfortunate maintainer
later.
Ed Willink
On 08/07/2013 15:57, Daniele Pala wrote:
> Hi, thanks for your reply! It works, with this syntax:
> Source model URI:
> Target model URI:
> stuff...
> Thanks again,
> Daniele Pala
Previous Topic:Applying Stereotype to model element
Next Topic:Object type issues
Current Time: Sun Jul 20 10:33:09 EDT 2025
Powered by FUDForum. Page generated in 0.25166 seconds
