Home » Newcomers » Newcomers » Can't add a new Tomcat 7 Server(After deleting a previous version and installing a new version...)
icon1.gif  Can't add a new Tomcat 7 Server [message #1067138] Sat, 06 July 2013 05:09 Go to next message
Technical Information
IDE: Eclipse Kepler
Server: Tomcat 7.0.42 | Previous version: 1.0;
Issue, can't properly add a new version of Tomcat Server V7.0
Greetings,
For some unknown reason, after deleting the tomcat server from both the server fast tab and the window > Preference > Servers, and then adding it back to from the windows menu, whenever I start a new Dynamic web project and try to pick a Tomcat Server V7.0, I can't; neither is possible from the link in the fast tab menu.
I attached a screenshot of how it looks to me.
Hoping anyone could give me a hand with this issue,
Thanks for reading.
  • Attachment: Capture.JPG
    (Size: 48.61KB, Downloaded 6444 times)
Re: Can't add a new Tomcat 7 Server [message #1067168 is a reply to message #1067138] Sat, 06 July 2013 23:55 Go to previous messageGo to next message
> IDE: Eclipse Kepler
> Greetings,
> Thanks for reading.
I don't follow: what happens when you click on Tomcat v7.0 in the list?
Re: Can't add a new Tomcat 7 Server [message #1067611 is a reply to message #1067168] Tue, 09 July 2013 10:52 Go to previous messageGo to next message
I have also experienced this problem with Eclipse Kepler running on Fedora 18. I executed these steps to create new Server in Eclipse:
1. Click Server tab
2. Click link to create new server
3. Highlight Tomcat v7.0 Server
Server host name is set to localhost
Server name is blank
Next> button is not active. Only Cancel button is available.
If I selected Tomcat v6.0 Server, the server host name is localhost and server name is populated. Next> button is active.
I have attempted to remove the runtime and add it again with no success. I found a Juno fix by removing some config files, but it did not work either. Is there another fix for Kepler?
Kevin Schulke
Re: Can't add a new Tomcat 7 Server [message #1067627 is a reply to message #1067611] Tue, 09 July 2013 12:38 Go to previous messageGo to next message
> 1. Click Server tab
> Kevin Schulke
This may be a bug. I don't use 7 (just saying, not making a point of
it), but I had no trouble creating a Tomcat 6 server in Kepler. Perhaps
you should go to the trouble of submitting a bug report. If you bring
this issue up in the Eclipse web tools forum, which is really where this
should have been asked in the first place, someone there might want to
do it for you since it's pretty important. (I'm not a moderator and
can't move this thread.)
Re: Can't add a new Tomcat 7 Server [message #1067670 is a reply to message #1067627] Tue, 09 July 2013 20:07 Go to previous messageGo to next message
hi guys,
Just to let you know, I've just got the same issue here with Kepler EE (Build id: 20130614-0229).
After deleting a Tomcat server, I can't create another instance for 7.0 version.
falico
Re: Can't add a new Tomcat 7 Server [message #1067671 is a reply to message #1067627] Tue, 09 July 2013 20:11 Go to previous messageGo to next message
I've just posted and found the solution in stackoverflow (stackoverflow.com/questions/14791843/eclipse-add-tomcat-7-blank-server-name):
1. Close Eclipse
2. In {workspace-directory}/.metadata/.plugins/org.eclipse.core.runtime/.settings delete the following two files:
org.eclipse.wst.server.core.prefs
org.eclipse.jst.server.tomcat.core.prefs
3. Restart Eclipse
regards
falico
Re: Can't add a new Tomcat 7 Server [message #1180220 is a reply to message #1067671] Sun, 10 November 2013 16:31 Go to previous messageGo to next message
Thanks!
Worked for me (Juno under ubuntu 12.04) Smile
Re: Can't add a new Tomcat 7 Server [message #1181206 is a reply to message #1180220] Mon, 11 November 2013 07:51 Go to previous messageGo to next message
Hello!
Ive had the same problem with Kepler and Tomcat7. I searched google and found that it's simply a bug.
Re: Can't add a new Tomcat 7 Server [message #1221078 is a reply to message #1067138] Mon, 16 December 2013 16:00 Go to previous messageGo to next message
Hi! I know that somebody fix the problem deleting this two links
But for me is impossible, I have Ubuntu 12.04, Tomcat7 and Eclipse Indigo.
If delete this 2 links when add the server again, the links pop-up again and I'm in the same situation.
Could someone help me? I'm very frustated...
Thanks in advance.
Re: Can't add a new Tomcat 7 Server [message #1221117 is a reply to message #1221078] Mon, 16 December 2013 18:31 Go to previous messageGo to next message
> Thanks in advance.
Just what is the "same situation"?
I just downloaded Tomcat 7 and add it to my workbench. I'm running Mint
13 (Ubuntu 12.04) and Indigo.
icon12.gif  Re: Can't add a new Tomcat 7 Server [message #1233018 is a reply to message #1067138] Sat, 18 January 2014 05:52 Go to previous messageGo to next message
hi i have same problem
but i get solution
just follow the following steps
step 1: go to Help Menu
step 2: select Install New Software
step 3: in the opeing window there is 1 drop down "work with" select your eclipse verstion like "kepler"
step 4: then are displayed many groups in down box expand "Web, XML, Java EE and OSGi Enterprise Development" this group
step 5: then select "JST Server Adapters Extensions"
step 6: next
step 7: next
setp 8: select accept
step 9: install
step 10: restart eclipse
step 11: go to File -> New -> Other -> Server -> Server -> there are tomcat 7 is available and select
step 12: Enjoy Smile
icon14.gif  Re: Can't add a new Tomcat 7 Server [message #1288159 is a reply to message #1067671] Tue, 08 April 2014 06:27 Go to previous messageGo to next message
Mir:
Nothing happened when I tried to do what Chintan Popat had suggested below i.e. to uninstall "JST Server Adapters Extensions".
However, what Rodrigo Faria posted below worked for me.
>>Rodrigo Faria:
>>Quote:
>>1. Close Eclipse
>>3. Restart Eclipse
>>regards
>>falico
Mir
Re: Can't add a new Tomcat 7 Server [message #1312649 is a reply to message #1067611] Thu, 24 April 2014 08:20 Go to previous messageGo to next message
problem is go to preferences--->server runtime env-->add server-> select tomcat7 folder
then ur problem is solved.
Re: Can't add a new Tomcat 7 Server [message #1315249 is a reply to message #1067671] Fri, 25 April 2014 18:03 Go to previous messageGo to next message
worked perfectly for me. thanks....
Re: Can't add a new Tomcat 7 Server [message #1361348 is a reply to message #1233018] Sat, 17 May 2014 01:52 Go to previous messageGo to next message
This solved my problem. Thanks a lot. Smile
Re: Can't add a new Tomcat 7 Server [message #1384946 is a reply to message #1361348] Tue, 03 June 2014 05:10 Go to previous messageGo to next message
hi
im deleting a Tomcat server but i dont create again
i read all response and i did them but dont fix it
thanks...
Re: Can't add a new Tomcat 7 Server [message #1385202 is a reply to message #1384946] Wed, 04 June 2014 20:26 Go to previous messageGo to next message
On 06/03/2014 08:21 AM, kumral demircan wrote:
> hi
> thanks...
Your question is difficult to understand. I would suggest that you
consider couching it more carefully and in the Eclipse WTP forum.
Cheers
Re: Can't add a new Tomcat 7 Server [message #1404545 is a reply to message #1385202] Sun, 03 August 2014 23:59 Go to previous messageGo to next message
I just solved a similar problem (no existing Tomcat server despite having it defined, "Run as.." points to manual definition on localhost but does not allow to define a new server) on a clean install of Eclipse Luna on Centos 7 with Tomcat 7 and JDK 1.7. I also wrote about it on Stackoverflow (in reply to "Unable to run a jsp project in eclipse" -- unfortunately, I cannot yet post URIs in the Eclipse forum due to low post count) but since I used this thread during my troubleshooting, I thought I post some information here as well:
In my case, deleting the above mentioned files did not help. In the end (and after several re-installations of Eclipse and Tomcat), I stumbled across a permission problem that was only visible if I tried to define a new server when trying "Run as..." without first having a Tomcat server or runtime defined.
The underlying issue was that Tomcat was installed in /opt/some-tomcat and required root privileges to start but Eclipse ran with my user privileges -- which were not sufficient to start Tomcat. To circumvent the problem, I copied the Tomcat installation into my workspace directory and changed ownership to my user account:
cp -R /opt/whatever-your-Tomcat-version-is ~/workspace/
chown -R your-username:your-username ~/workspace/whatever-your-Tomcat-version-is
...and then used this Tomcat instance from within Eclipse -- which worked immediately.
However, it was also necessary to make sure that no other Tomcat was running on the system (else Tomcat does not start because of a port conflict).
[Updated on: Mon, 04 August 2014 00:10] by Moderator
Re: Can't add a new Tomcat 7 Server [message #1433962 is a reply to message #1404545] Mon, 29 September 2014 09:24 Go to previous messageGo to next message
Hi all, i'm new in the forum.
I'll post what work for me.
I know that is not the best practice, but for me, was the only way.
Ubuntu 14.04 - Tomcat7 - Eclipse Luna
I just switch the workspace for a new and after create the Tomcat7 server, i copied my projects.
[Updated on: Mon, 29 September 2014 09:41] by Moderator
Re: Can't add a new Tomcat 7 Server [message #1605490 is a reply to message #1067671] Sat, 07 February 2015 09:59 Go to previous messageGo to next message
[quote title=Rodrigo Faria wrote on Wed, 10 July 2013 00:11]I've just posted and found the solution in stackoverflow (stackoverflow.com/questions/14791843/eclipse-add-tomcat-7-blank-server-name):
1. Close Eclipse
3. Restart Eclipse
Worked for me to.
Luna, Tomcat 8.
Re: Can't add a new Tomcat 7 Server [message #1706731 is a reply to message #1067611] Sat, 29 August 2015 06:45 Go to previous messageGo to next message
I was getting same issue tomcat 8/jre 1.8/luna. As localhost is visible and Next button was not working except cancel.
Following steps worked for me
Delete those 2 files as explained above
Step 1
3. Restart Eclipse
Step2
Delete the tomcat:
Server > right click delete.
New server installation:
Server > right click > tom 8.0 > next > finish.
Start the server.
It will work!
icon14.gif  Re: Can't add a new Tomcat 7 Server [message #1728113 is a reply to message #1067671] Thu, 31 March 2016 04:09 Go to previous messageGo to next message
Works like a charm on Eclipse Mars 4.2.
Thanks was really frustrated.
Re: Can't add a new Tomcat 7 Server [message #1818219 is a reply to message #1233018] Tue, 10 December 2019 06:44 Go to previous message
Thanks it works
Previous Topic:JPA Project
Next Topic:Exporting project to runnable JAR
Current Time: Sun Jul 20 10:52:42 EDT 2025
Powered by FUDForum. Page generated in 0.11647 seconds
