Problem exporting Eclipse product [message #1067047] |
Fri, 05 July 2013 11:15  |
I want to export a standalone product with my DSL editor. I followed the tutorial from http://kthoms.wordpress.com/2010/11/12/setting-up-a-rcp-product-for-a-dsl/, but I'm having problems to get it to work.
When I click "Launch an Eclipse application", I get the following error:
!SESSION Fri Jul 05 12:08:13 BRT 2013 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2013-07-05 12:08:13.553
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Maybe there is a plugin missing in my DSL feature? If so, I have no idea of which.
When I go to the Run Configurations menu, choose my product configuration, click "Add Required Plug-ins" and then run, it works. So, I must have got most of the configuration right, but can't export the product.
Re: Problem exporting Eclipse product [message #1067836 is a reply to message #1067089] |
Wed, 10 July 2013 15:25   |
I set the product configuration to be based on plug-ins instead of features, and it seemed easier to find the dependencies.
Now, I have a problem which apparently is specific to Xtext. When I try to open any file in the exported Eclipse product, I get this message in the editor:
Could not open the editor: The editor class could not be instantiated. This usually indicates a missing no-arg constructor or that the editor's class name was mistyped in plugin.xml.
And the stack trace:
Toggle Spoiler
java.lang.RuntimeException: Failed to create injector for org.example.F
at org.example.ui.internal.FActivator.createInjector(FActivator.java:71)
at org.example.ui.internal.FActivator.getInjector(FActivator.java:55)
at org.example.ui.FExecutableExtensionFactory.getInjector(FExecutableExtensionFactory.java:26)
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:49)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:260)
at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:235)
at org.eclipse.ui.internal.EditorManager.createPart(EditorManager.java:875)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:609)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2764)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:355)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:164)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:228)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
at org.eclipse.jdt.internal.ui.navigator.OpenAndExpand.run(OpenAndExpand.java:50)
at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:221)
at org.eclipse.ui.navigator.CommonNavigatorManager$3.open(CommonNavigatorManager.java:185)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:462)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
Caused by: com.google.inject.CreationException: Guice creation errors:
1) No implementation for org.eclipse.jface.viewers.ILabelProvider was bound.
at org.eclipse.xtext.ui.DefaultUiModule.configureContentProposalLabelProvider(DefaultUiModule.java:288)
2) No implementation for org.eclipse.jface.viewers.ILabelProvider was bound.
at org.eclipse.xtext.ui.DefaultUiModule.configureHyperlinkLabelProvider(DefaultUiModule.java:259)
3) No implementation for org.eclipse.jface.viewers.ILabelProvider was bound.
while locating org.eclipse.jface.viewers.ILabelProvider
for field at org.eclipse.xtext.ui.editor.hover.html.DefaultEObjectHoverProvider.labelProvider(Unknown Source)
at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:55)
4) No implementation for org.eclipse.jface.viewers.ILabelProvider was bound.
for field at org.eclipse.xtext.ui.editor.hover.html.XtextElementLinks.labelProvider(Unknown Source)
while locating org.eclipse.xtext.ui.editor.hover.html.XtextElementLinks
for field at org.eclipse.xtext.ui.editor.hover.html.DefaultEObjectHoverProvider.elementLinks(Unknown Source)
5) No implementation for org.eclipse.jface.viewers.ILabelProvider was bound.
for field at org.eclipse.xtext.ui.editor.outline.impl.DefaultOutlineTreeProvider.labelProvider(Unknown Source)
while locating org.eclipse.xtext.ui.editor.outline.IOutlineTreeProvider
for field at org.eclipse.xtext.ui.editor.outline.impl.OutlinePage.treeProvider(Unknown Source)
6) No implementation for org.eclipse.xtext.ui.editor.quickfix.IssueResolutionProvider was bound.
while locating org.eclipse.xtext.ui.editor.quickfix.IssueResolutionProvider
for field at org.eclipse.xtext.ui.editor.quickfix.AbstractIssueResolutionProviderAdapter.resolutionProvider(Unknown Source)
while locating org.eclipse.xtext.ui.editor.quickfix.XtextQuickAssistProcessor
for field at org.eclipse.xtext.ui.editor.hover.AnnotationWithQuickFixesHover.quickAssistProcessor(Unknown Source)
while locating org.eclipse.xtext.ui.editor.hover.AnnotationWithQuickFixesHover
for field at org.eclipse.xtext.ui.editor.hover.DefaultCompositeHover.annotationHover(Unknown Source)
6 errors
at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:435)
at com.google.inject.internal.InternalInjectorCreator.initializeStatically(InternalInjectorCreator.java:154)
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:106)
at com.google.inject.Guice.createInjector(Guice.java:95)
at com.google.inject.Guice.createInjector(Guice.java:72)
at com.google.inject.Guice.createInjector(Guice.java:62)
at org.example.ui.internal.FActivator.createInjector(FActivator.java:67)
... 85 more
This only happens with the exported Eclipse. When I click "Launch an Eclipse application", everything works fine.
Re: Problem exporting Eclipse product [message #1067845 is a reply to message #1067840] |
Wed, 10 July 2013 16:14  |
They didn't, but the error was there! My UI project didn't have the xtend-gen folder set as a source folder. I also changed the runtime environment from Java 1.5 to 1.7 after finding some errors in the log concerning the usage of the @Override annotation. Now it works. Thank you!
FUDForum. Page generated in 0.03924 seconds
