Home » Modeling » TMF (Xtext) » Xtext project from ECore with abstract types
Xtext project from ECore with abstract types [message #1067004] Fri, 05 July 2013 08:00 Go to next message
I have created an XTEXT project from an ECore.
This ECore has been generated from a XSD containing this partial specification, based on abstract types and groups:
  <xsd:complexType name="CT_operation" abstract="true">
    <xsd:sequence>
      <xsd:element ref="doc" minOccurs="0" />
    </xsd:sequence>
    <xsd:attribute name="name" type="OperationName" use="required"/>
  </xsd:complexType>
  <xsd:complexType name="CT_event" abstract="true">
    <xsd:complexContent>
      <xsd:extension base="CT_operation">
        <xsd:sequence>
          <xsd:element name="parameter" type="CT_qualified_field" minOccurs="0" maxOccurs="unbounded"/>
        </xsd:sequence>
      </xsd:extension>
    </xsd:complexContent>
  </xsd:complexType>
  <xsd:complexType name="CT_sent_event">
      <xsd:extension base="CT_event">
        <xsd:attribute name="period" type="xsd:decimal" use="optional"/>
      </xsd:extension>
  </xsd:complexType>
  <xsd:complexType name="CT_received_event">
      <xsd:extension base="CT_event"/>
  </xsd:complexType>
  <xsd:group name="operations_not_in_transaction">
    <xsd:choice>
      <xsd:element name="event_received" type="CT_received_event" minOccurs="0">
        <xsd:unique name="param_event_received">
          <xsd:selector xpath="parameter"/>
          <xsd:field xpath="@name"/>
        </xsd:unique>
      </xsd:element>
    </xsd:choice>
  </xsd:group>
  <xsd:group name="operations_in_transaction">
    <xsd:choice>
       <xsd:element name="event_sent" type="CT_sent_event" minOccurs="0">
        <xsd:unique name="param_event_sent">
        </xsd:unique>
      </xsd:element>
    </xsd:choice>
  </xsd:group>
  <xsd:group name="all_operations">
    <xsd:choice>
      <xsd:group ref="operations_in_transaction"/>
      <xsd:group ref="operations_not_in_transaction"/>
    </xsd:choice>
  </xsd:group>
  <xsd:complexType name="CT_operations">
    <xsd:group ref="all_operations" maxOccurs="unbounded"/>
  </xsd:complexType>
I have an issue with the generated Xtext project:
The Rule generated for CT_operations only looks like:
CTOperations returns ComponentType::CTOperations:
	{ComponentType::CTOperations}
	'CTOperations';
=> no rule generated for CT_received_event nor CT_sent_event
If I am trying to define the rules manually, like:
	(eventSent+=CTSentEvent)?
	(eventReceived+=CTReceivedEvent)?
Decimal returns ecore::EBigDecimal:
	INT;
CTSentEvent returns ComponentType::CTSentEvent:
	'eventSent' period=Decimal;
CTReceivedEvent returns ComponentType::CTReceivedEvent:
	{ComponentType::CTReceivedEvent}
	'eventReceived';
I am facing 2 problems with using the generated editor:
1/ I don't have access to inherited attibutes of the abstract types CT_event (parameter) and CT_operation (doc and name)
2/ It appears the the ECore has been generated with a EFeatureMapEntry for the group/choice and I am getting the following exception when I am entering the keyword 'eventSent':
An internal error occurred during: "Xtext validation".
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$ContainmentUpdatingFeatureMapEntry cannot be cast to org.eclipse.emf.ecore.EObject
=> I don't know how to manage the FeaturingMapEntry. Do I have to add sometinh in the Xtext grammar ?
Could someone please help me with thesebig troubles that totally stoppe me ?
Sorry for the length of my post.
Re: Xtext project from ECore with abstract types [message #1067011 is a reply to message #1067004] Fri, 05 July 2013 08:33 Go to previous messageGo to next message
Vincent,
Is the schema itself within your control such that you could perhaps
change it in a way that allows you to suppress the generation of feature
maps? I.e., if it could be expressed using substitution groups it would
potentially be possible to suppress the feature maps entirely:
http://ed-merks.blogspot.de/2007/12/winters-icy-grip.html
In particular I think the use of <xsd:group ref="all_operations"
maxOccurs="unbounded"/> could refer instead to an abstract element
that's the head of a substitution group where the things in here (don't
know what's in your ...) would be in that substitution group.
<xsd:choice>
minOccurs="0">
</xsd:unique>
</xsd:element>
</xsd:choice>
</xsd:group>
<xsd:choice>
</xsd:unique>
</xsd:element>
</xsd:choice>
</xsd:group>
So potentially you could specify the same valid XML because a
substitution group is essentially like a choice of the members of the
group (though unfortunately they need to be global elements). Whether
that works depends on what else you have in your "..." and in particular
on each of them having a unique type such that the appropriate element
can be deduced from just the type.
Otherwise, I think Xtext has no support for feature maps...
On 05/07/2013 2:00 PM, Vincent De Bry wrote:
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:extension>
> </xsd:complexType>
> </xsd:complexType>
> <xsd:choice>
> minOccurs="0">
> </xsd:unique>
> </xsd:element>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:unique>
> </xsd:element>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> </xsd:complexType>
> 'CTOperations';
> INT;
> 'eventReceived';
> stoppe me ?
> Thanks
Re: Xtext project from ECore with abstract types [message #1067042 is a reply to message #1067011] Fri, 05 July 2013 10:56 Go to previous messageGo to next message
Thanks Ed,
I don't have really the hand on the Schema, but I may try to write my own schema based on your advise and hope the resulting ecores will be compatible.
That said, has anybody an answer for my first point: how to be able to access to the inherited attributes while in Xtext generated editor ? I still freeze on that point Sad
Re: Xtext project from ECore with abstract types [message #1067058 is a reply to message #1067042] Fri, 05 July 2013 11:43 Go to previous messageGo to next message
Vincent,
I'm not sure what problem you have in terms of "access inherited
attributes". How are you trying to access them? What specifically
isn't accessible?
On 05/07/2013 4:56 PM, Vincent De Bry wrote:
> Thanks Ed,
> compatible.
> still freeze on that point :(
Re: Xtext project from ECore with abstract types [message #1067077 is a reply to message #1067058] Fri, 05 July 2013 13:20 Go to previous messageGo to next message
Ed, thanks to try helping me.
Actually, I was first surprised that the XText project creation from the Ecore does not generate a rule for CTSensEvent, for example.
So I defined it (and the type 'Decimal') by myself like this
	INT;
I am first wondering if it is normal that I have to define it manually, as everything is in the Ecore.
Then, as CTSentEvent inherits from CTEvent, I would expect that the attribute 'parameter' from CTEvent would be immediatly proposed during file edition, by the content assist. As it does not work like that, I ment I should define a rule for CTEvent like:
CTEvent returns ComponentType::CTEvent:
	parameter=CTQualifiedField;
and do so that rule CTSentEvent inherits from CTEvent (but how ? I don't know !)
The only solution I have found seems to duplicate the inherited attribtes in each rule associated to a super type, like:
	INT;
But doing so, I am loosing the interest of having a super type, I mean ... Sad
What do you mean ?
Thank you very much.
Re: Xtext project from ECore with abstract types [message #1067104 is a reply to message #1067077] Fri, 05 July 2013 17:10 Go to previous messageGo to next message
Ok, I have replace the use of groups in my XSD:
    <xsd:choice>
       <xsd:element name="event_sent" type="CT_sent_event" minOccurs="0" maxOccurs="unbounded">
        </xsd:unique>
      </xsd:element>
      <xsd:element name="event_received" type="CT_received_event" minOccurs="0" maxOccurs="unbounded">
        </xsd:unique>
      </xsd:element>
    </xsd:choice>
  </xsd:complexType>
I think the resulting schema would be equivalent for writting XML files...
This seems to solve all my issues: Xtext rules are generated and their are no more Validation exception.
Finally, it seems that the use of XSD Groups are totally not supported by XTEXT. This is a very big constraint Sad
Thanks Ed for your support.
Re: Xtext project from ECore with abstract types [message #1067132 is a reply to message #1067104] Sat, 06 July 2013 03:59 Go to previous messageGo to next message
Vincent,
One thing to note is that this expression allows either a bunch of sent
events or a bunch of received events but not both. Your EMF model won't
check for that constraint (there's no concept of choice or mutually
exclusive features in Ecore) so you will be able to have both. But note
that while they can even appear in any mixed order (EMF doesn't check
that either) that mixed order won't be recorded properly (because there
is no feature map), and you'll always end up with all the sents before
the receiveds. If you expressed this as a substitution group with some
global abstract element "x" and have the global CT_sent_event and
CT_received_event declare they are in substitution group "x" (x must
have a type that is a base type of each of these) then if you used the
options I mentioned in the blog, you'd end up with a feature "x" in your
model of type base event that stores the mixed order of the two types of
events. That should probably be your goal.
> <xsd:choice>
> </xsd:unique>
> </xsd:element>
> </xsd:unique>
> </xsd:element> </xsd:choice>
> </xsd:complexType>
> files...
> by XTEXT. This is a very big constraint :(
Re: Xtext project from ECore with abstract types [message #1067511 is a reply to message #1067132] Tue, 09 July 2013 04:02 Go to previous messageGo to next message
Hi Ed,
You are right, my adaptation does not match my need. So I tried to use substitution groups but I probably did not caught something as with the following adapted XSD, I still get a EFeatureMapEntry in my Ecore and, moreover, no feature for "event_received" and "event_sent" but a single feature on "all_operations" instead Sad
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
            elementFormDefault="unqualified" attributeFormDefault="unqualified">
    <xsd:attribute name="name" type="xsd:string" use="required"/>
  </xsd:complexType>
        <xsd:sequence>
          <xsd:element name="parameter" type="xsd:string" minOccurs="0" maxOccurs="unbounded"/>
        </xsd:sequence>
      </xsd:extension>
  </xsd:complexType>
      </xsd:extension>
  </xsd:complexType>
  </xsd:complexType>
  <xsd:element name="all_operations" abstract="true"/>
  <xsd:element name="event_received" type="CT_received_event" substitutionGroup="all_operations">
    </xsd:unique>
  </xsd:element>
  <xsd:element name="event_sent" type="CT_sent_event" substitutionGroup="all_operations">
    </xsd:unique>
  </xsd:element>
    <xsd:sequence>
      <xsd:element ref="all_operations" maxOccurs="unbounded"/>
    </xsd:sequence>
  </xsd:complexType>
</xsd:schema>
could you please help me pointing what is wrong ?
note That I also did not succeed in defining intermediate subsitution groups for replacing "operations_in_transaction" and "operations_not_in_transaction" Sad
Re: Xtext project from ECore with abstract types [message #1067523 is a reply to message #1067511] Tue, 09 July 2013 04:30 Go to previous messageGo to next message
Vincent,
Here's a complete example of what I had in mind. Note the ecore
annotation to suppress the feature maps for substitution groups and the
type specifies for the "all_operations" element.
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
ecore:ignoreSubstitutionGroups="true">
</xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
</xsd:extension>
</xsd:complexType>
</xsd:complexType>
<xsd:element name="all_operations" abstract="true" type="CT_event"/>
</xsd:unique>
</xsd:element>
</xsd:unique>
</xsd:element>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
And yes, the result is that you end up with a single getAllOperations
feature that contains CTEvent instances, which can be either CTSentEvent
or CTReceivedEvent instances so processing will require iterating over
the whole list and doing instanceof checks. Given that Xtext doesn't
support feature maps (as far as I know) and given that you need to
preserve/represent the mixed order of these things, you need such an
overall feature.
If your real schema specifies elementFormDefault="unqualified" then this
new representation will result in the use of qualified element names
because you've made the element global rather than local, so I'm not
sure this solutions pans out for you.
On 09/07/2013 10:02 AM, Vincent De Bry wrote:
> Hi Ed,
> single feature on "all_operations" instead :(
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:extension>
> </xsd:complexType>
> </xsd:complexType>
> </xsd:unique>
> </xsd:element>
> </xsd:unique>
> </xsd:element>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> "operations_not_in_transaction" :(
> Thanks
Re: Xtext project from ECore with abstract types [message #1067537 is a reply to message #1067523] Tue, 09 July 2013 05:14 Go to previous message
Thank you very much Ed !
Based on your last post, I have generated a Ecore and the corresponding Xtext project. So far, I think I should go ahead with them.
Thanks again !
Previous Topic:Factoring out rules with no wrapper return types
Next Topic:grammar problem (probably scoping)
Current Time: Sun Jul 20 02:50:41 EDT 2025
Powered by FUDForum. Page generated in 0.04849 seconds
