2.6.2 report failures with BIRT 4.3 [message #1066156] |
Mon, 01 July 2013 05:55  |
I installed the 4.3 all-in-one release on windows xp and windows 7, and
have the same problem on both with reports developed using BIRT 2.6.2: they
work Ok via the 'run' action when run directly, but when called from a
hyperlink in another report, or when run via the 'preview' action, the
parameters, which are used to filter tables, seem to be corrupted.
No errors are shown, but the report tables are showing content that should
be filtered.
The same report files work perfectly ok with v2.6.2 - the rptdesign is not
changed after opening it with 4.3 and saving.
Is there any documentation on the changes in v4.3 that might help?
Colin Sutton
FUDForum. Page generated in 0.04999 seconds
