Home » Modeling » TMF (Xtext) » Xtext - Recursive grammar
Xtext - Recursive grammar [message #1066988] Fri, 05 July 2013 07:00 Go to next message
How can I use a recursive grammar?
I have the following code:
model:
defs += CFG_objects
CFG_objects:
statement=ID name=ID '{'
(par+=CFG_pars)*
'}' (':' comment=STRING)? ';'
CFG_pars:
condition=ID val=ID
('{' (pars+=CFG_pars) '}')?
It throws me an error with this:
switch answer
case good : do_nothing ;
}: store answer;
What is wrong with my grammar? How can I implement a recursive grammar rule? I was expecting the above example to work.
[Updated on: Fri, 05 July 2013 07:01] by Moderator
Re: Xtext - Recursive grammar [message #1066991 is a reply to message #1066988] Fri, 05 July 2013 07:13 Go to previous messageGo to next message
you define your comments as String, but in your sample they are not. STRING requires single or double quotes.
Also, you are probably missing "+" or "*" in your list definitions (model feature defs, CFG_pars feature pars).
Alex
Re: Xtext - Recursive grammar [message #1067246 is a reply to message #1066991] Sun, 07 July 2013 23:39 Go to previous messageGo to next message
I have changed the code and my configuration. But I am still getting an error.
model:
defs += CFG_objects
CFG_objects:
(pars+=CFG_pars)*
'}' (':' comment=STRING1)? ';'
CFG_pars:
condition=ID val=ID
('{' (pars+=CFG_pars)* '}')?
terminal STRING1: '"' -> '"';
switch answer
case good : "do nothing" ;
TYPE bad;
}: "store answer";
The error I am getting is:
ERROR:mismatched input 'TYPE' expecting '}'
ERROR:extraneous input ';' expecting RULE_ID
[Updated on: Sun, 07 July 2013 23:40] by Moderator
Re: Xtext - Recursive grammar [message #1067254 is a reply to message #1067246] Mon, 08 July 2013 02:31 Go to previous messageGo to next message
this is not the complete grammar. It does not rise the problem you claim.
Alex
Re: Xtext - Recursive grammar [message #1067327 is a reply to message #1066988] Mon, 08 July 2013 06:15 Go to previous messageGo to next message
I have modified the grammar a bit.
Model:
defs += CFG_objects*
CFG_objects:
	(pars+=CFG_pars)*
	'}'  comment=CFG_comment ';'
CFG_pars:
	name=ID value=SPECIAL
CFG_comment: {CFG_comment}
SPECIAL hidden():
	STRING1 | ID | INT| HEX | DOUBLE
terminal DOUBLE:  INT '.' INT;
terminal HEX: '0' ('x' | 'X')(('0'..'9') | ('a'..'f') | ('A'..'F'))+;
I noticed that the error only occur in some scenarios.
switch answer
TYPE BAD; <--Problem line-->
PRIO HIGH;
}: "store answer";
If I change the problem line to "type", parsing still will not work. But other keywords works fine (e.g.STATUS, Size, size).
Re: Xtext - Recursive grammar [message #1067330 is a reply to message #1067327] Mon, 08 July 2013 06:24 Go to previous messageGo to next message
this is still not the complete grammar, the example is processed without errors. My guess is that you use "TYPE" as a keyword somewhere in your real grammar. That way TYPE will not be read as ID (as your rule reqires) but as keyword token.
Alex
Re: Xtext - Recursive grammar [message #1067481 is a reply to message #1067330] Mon, 08 July 2013 21:48 Go to previous messageGo to next message
OH! You are right! [Banging head on the monitor screen]
Been staring at this for a week now.
Is there a way to fix this? I do not want to specify each possible keyword. But other rules do require for the "TYPE" keyword to be there.
[Updated on: Mon, 08 July 2013 21:57] by Moderator
Re: Xtext - Recursive grammar [message #1067499 is a reply to message #1067481] Tue, 09 July 2013 02:25 Go to previous message
See e.g. here. I'd recommend simple escaping if possible.
Alex
Previous Topic:XText rejects user defined hidden terminal rules
Next Topic:Factoring out rules with no wrapper return types
Current Time: Sat Jul 19 14:45:08 EDT 2025
Powered by FUDForum. Page generated in 0.28781 seconds
