Object mappings accross AUTs/configurations [message #1066849] |
Thu, 04 July 2013 14:39  |
I am using Jubula 7.1 to drive tests on different Eclipse versions which run different versions of the same plugins as rcp.
If I design the test on say Kepler, it plays back the test fine.
The problem occurs when I use a different configuration, which drives Eclipse 3.8.2 (could be a different one).
The test stops with Component Not found Error. That specific component I defined to be called NewReviewGroup and mapped to a technical name which is identical between the 2 configurations.
But somehow, Jubula doesn`t see them as being the same.
How can I workaround this without having to redo the mapping for every configuration ?
The intention is to run the same tests when new eclipse and/or plugins are released. With this current problem, I don`t see how that can be.
[Updated on: Fri, 05 July 2013 10:57] by Moderator
FUDForum. Page generated in 0.26896 seconds
