Home » Modeling » TMF (Xtext) » Cannot remove org.eclipse.xtext.common.Terminals from gramma
Cannot remove org.eclipse.xtext.common.Terminals from gramma [message #1066809] Thu, 04 July 2013 09:25 Go to next message
Hey,
I would like to remove the org.eclipse.xtext.common.Terminals import from my grammar to avoid the following error message:
The following token definitions can never be matched because prior tokens match the same input: RULE_INT
It is caused by my terminal rule:
terminal VALUE:
	('a'..'z' | 'A'..'Z' | '_' | '\\' | '\\(' | '\\)' | '\\ ' | '\\@' | '0'..'9')+;
If I remove the grammar "with org.eclipse.xtext.common.Terminals" from the header of the file, the terminal rule is marked with an error: Cannot create datatype VALUE.
Is there a way to completely remove org.eclipse.xtext.common.Terminals?
Thank you.
Kon
Re: Cannot remove org.eclipse.xtext.common.Terminals from gramma [message #1066815 is a reply to message #1066809] Thu, 04 July 2013 09:48 Go to previous messageGo to next message
Hi simply remove The with clause and copy what you need
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Cannot remove org.eclipse.xtext.common.Terminals from gramma [message #1066827 is a reply to message #1066815] Thu, 04 July 2013 10:16 Go to previous messageGo to next message
Hey Christian,
I have tried this:
grammar com.project.test.properties.MyDsl /*with org.eclipse.xtext.common.Terminals*/
But it results in:
index.php/fa/15477/0/
with the error message: Cannot create datatype VALUE
Is this a bug? I'm using 2.4.2.
Thank you.
Kon
[Updated on: Thu, 04 July 2013 10:18] by Moderator
Re: Cannot remove org.eclipse.xtext.common.Terminals from gramma [message #1066829 is a reply to message #1066827] Thu, 04 July 2013 10:25 Go to previous messageGo to next message
you have to import ecore (as it is done in terminals gramamr)
Re: Cannot remove org.eclipse.xtext.common.Terminals from gramma [message #1066831 is a reply to message #1066809] Thu, 04 July 2013 10:44 Go to previous message
Thank you Christian Smile
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
This works now Smile
Thank you!
Kon
Previous Topic:hints for a grammar
Next Topic:Deploying xtext parser to standalone jar
Current Time: Sun Jul 20 13:10:29 EDT 2025
Powered by FUDForum. Page generated in 0.08048 seconds
