Home » Modeling » ATL » Full name reference - Classifiers seem not to be equal
Full name reference - Classifiers seem not to be equal [message #1066585] Wed, 03 July 2013 06:05 Go to next message
I have to rules here for you.
rule CompareUse {
	from input: IN!InstructionDef(input.instruction.oclIsTypeOf(IN!Compare))
	to
		outI :OUT!LocalComputation(
			expression <-  lexpr,
			instructionResult <- intReg
		intReg: OUT!Variable (
			name <- input.register
		lexpr : OUT!"expressions::Equal"(
			left <- left,
			right <- right
		left : OUT!"expressions::StringValue"(
			strValue <- input.instruction.value1
		right : OUT!"expressions::StringValue"(
			strValue <- input.instruction.value2
rule BranchCompare {
        from input: MM!LocalComputation(input.expression.oclIsTypeOf(MM!"expressions::Equal"))
The rule CompareUse is from a Model-2-Model Transformation and the snippet of the rule BranchCompare is from a refining transformation.
Short Overview:
M2M: Transform every Compare Instruction from IN to a OUT!LocalComputation with an expression(Equal here).
Ref: Select all LocalComputations that have an equal expression.
After the M2M Transformation the new Model contains LocalComputations like this:
<instructions xsi:type="LocalComputation">
      <instructionResult name="cmp2"/>
      <expression xsi:type="expressions:Equal">
        <left xsi:type="expressions:StringValue" strValue="1"/>
        <right xsi:type="expressions:StringValue" strValue="1"/>
      </expression>
    </instructions>
Thats ok so far.
The refining on the other hand doesn't work.
If i debug the snippet like this:
from
input: MM!LocalComputation (
	input.expression.oclIsTypeOf(MM!"expressions::Equal").debug(input.expression.oclType())
I get:
org.eclipse.emf.ecore.impl.EClassImpl@71f68c1b (name: Equal) (instanceClassName: null) (abstract: false, interface: false): false
But if I'm wrong that should be true... not false.
Thanks for reading and your time,
Thomas
Re: Full name reference - Classifiers seem not to be equal [message #1066645 is a reply to message #1066585] Wed, 03 July 2013 10:32 Go to previous messageGo to next message
Small update.
I tried to change the header of the transformations.
In the version above I used
--@path IN=...
I changed it. So the transformation is now using the URI.
--@nsURI IN=...
But now also the first transformation isn't working any more.
with the Error:
org.eclipse.m2m.atl.engine.emfvm.VMException: Cannot find class IN::expressions::Equal in reference model IN
Is there a problem with using the nsURI and the full name reference?
Thomas
*EDIT*
fixed it. Just switching to Runtime Workbench.
By switching from @path to @nsURI also the first error disappeard.
Sorry for all that confusing stuff :/
Thomas
[Updated on: Wed, 03 July 2013 11:45] by Moderator
Re: Full name reference - Classifiers seem not to be equal [message #1066660 is a reply to message #1066645] Wed, 03 July 2013 11:21 Go to previous messageGo to next message
Have you tried to do something like:
from
	input.expression.oclIsTypeOf(MM!Equal).debug(input.expression.oclType())
Do you obtain a similar result/error?
Re: Full name reference - Classifiers seem not to be equal [message #1067278 is a reply to message #1066660] Mon, 08 July 2013 04:00 Go to previous message
Hello, I restored the version and yes. Same Error.
But its working now. As I mentioned in my edit before.
Thanks Smile
Previous Topic:transforming an XML to text file
Next Topic:ifExp in ATL textual syntax.
Current Time: Sun Jul 20 07:47:19 EDT 2025
Powered by FUDForum. Page generated in 0.14188 seconds
