Home » Language IDEs » Java Development Tools (JDT) » Compiler options
Compiler options [message #106065] Thu, 16 October 2003 07:21 Go to next message
Originally posted by: yonatan.nlayers.com
Is there a possibility to see the command line arguments passed to the
Java compiler in Eclipse (like in JBuilder or IntelliJ)?
This is a critical problem to me as compiling from Eclipse and from ant
via the command line causes classes serial version problems.
I tried setting all compile flags and options to be identical by I'm
missing something. If I could see how Eclipse compiles the class files,
I may remedy this problem.
Re: Compiler options [message #106078 is a reply to message #106065] Thu, 16 October 2003 07:25 Go to previous messageGo to next message
You can see the compiler options used to compile your .java files in
Window->Preferences->Java->Compiler.
Note these can also be set on a per-project basis: Project->Properties->Java
Compiler.
Jerome
"Yonatan Taub" <yonatan@nlayers.com> wrote in message
news:bmluv5$bol$1@eclipse.org...
Re: Compiler options [message #106216 is a reply to message #106065] Thu, 16 October 2003 09:35 Go to previous messageGo to next message
Originally posted by: bob.news.gmx.net
"Yonatan Taub" <yonatan@nlayers.com> schrieb im Newsbeitrag
There is no such thing as a command line in this case because the compiler
is part of eclipse.
That's the usual phenomenon when using different compilers. AFAIK there
are some issues in the language spec that make serial version generation
underspecified, i.e., different compilers may generate different version
ids for the same souce.
The great law of serialization: You must not mix classes compiled by
different compilers!
This is especially true if you use applets in conjuction with
serialization and compilation of server and client with different
compilers.
see above.
Cheers
robert
Re: Compiler options [message #106652 is a reply to message #106216] Thu, 16 October 2003 15:07 Go to previous messageGo to next message
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Thu, 16 Oct 2003 15:35:25 +0200, "Robert Klemme" <bob.news@gmx.net>
Different compilers also means different versions of the same compiler
(javac 1.3 compare to javac 1.4 for example.
However the Eclipse compiler could be used in batch mode.
About serialization, there is no portable solutions between compilers
than setting the SerialUID inside each class for which you want to
serialize instances.
Olivier
Re: Compiler options [message #107449 is a reply to message #106652] Sat, 18 October 2003 10:32 Go to previous message
Originally posted by: derisor.arcor.de
Setting SerialUID is that best option at any rate.
-- Robert
"Olivier Thomann" <olivier_thomann@ca.ibm.comNOSPAM> wrote in message
news:nuqtovgu3fqk8o3foio879a9j0hp082h0n@4ax.com...
> a
Previous Topic:Free UML plugin
Next Topic:binary build available for org.eclipse.jdt.ui.examples.javafamily?
Current Time: Sat Jul 19 22:58:35 EDT 2025
Powered by FUDForum. Page generated in 0.24105 seconds
