Home » Modeling » TMF (Xtext) » How to install my xtext dsl as a plug in to Eclipse?
How to install my xtext dsl as a plug in to Eclipse? [message #1066419] Tue, 02 July 2013 11:07 Go to next message
Hi guys,
I have created a dsl using xtext. Now i want to export it as a plug-in to eclipse so that my dsl appears in the wizard when choosing "crate new project"
I followed the very simple tutorial in the following link
http://www.openarchitectureware.org/pub/documentation/4.2/html/contents/xtext_tutorial.html#d0e1817
that simple says : File -> Export -> Export Deployable plug-ins and fragments. However when I do this I get the following errors:
1. ERROR in B:\PhD\Eclipse_Modelling_Workspace\org.xtext.example.mydsl.ui\src-gen\org\xtext\example\mydsl\ui\AbstractMyDslUiModule.java (at line 68)
return org.xtext.example.mydsl.ui.labeling.MyDslLabelProvider.class;
org.xtext.example.mydsl.ui.labeling.MyDslLabelProvider cannot be resolved to a type
Anybody has an idea how to resolve this issue? Alternatively do you know another way to create the plug-in ? I ve also looked the following post but seems quite complex to me:
http://stackoverflow.com/questions/11968326/when-deploying-xtext-how-to-integrate-with-eclipse-via-plugin
thank you
Re: How to install my xtext dsl as a plug in to Eclipse? [message #1066420 is a reply to message #1066419] Tue, 02 July 2013 11:11 Go to previous messageGo to next message
Hi please check the build.properties in the projects for warnings
(maybe xtend-gen missing)
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: How to install my xtext dsl as a plug in to Eclipse? [message #1066441 is a reply to message #1066420] Tue, 02 July 2013 12:43 Go to previous messageGo to next message
Hi Christian,
you were right , I was missing the xtend-gen. Problem solved.
So I created a new project and added a file with my dsl extension .the usual message popped up saying whether i want to add the Xtext nature to my project. So I filled in a model in my Mymodel.mydsl file. Now I want to generate the code out of the Mymodel.mydsl file. Do you know how can I do that?
Previously I was running the generator "MyDslGeneratorMWE.mwe2" in order to generate code out of my model.
Re: How to install my xtext dsl as a plug in to Eclipse? [message #1066445 is a reply to message #1066441] Tue, 02 July 2013 12:58 Go to previous messageGo to next message
Hi if you use default setup and change the pregenerated generator and
you have build automatically on the generator will be called if you
save the mydsl file
Re: How to install my xtext dsl as a plug in to Eclipse? [message #1066457 is a reply to message #1066445] Tue, 02 July 2013 13:38 Go to previous messageGo to next message
Christian I m sorry but I cannot understand what you mean. I have attached a snapshot of my project structure to explain you what I mean.
The org.xtext.example.mydsl.xxx projects are the xtext projects which I used to create my dsl and run my xtend generator.
The Test project is the one I create to test my dsl. I have added a new file Test.hello with my model( .hello is the extension of my dsl). And now I want to generate the code for the Test.hello file
1) what do you mean by "default setup"?
2) Which one is the "pregenerated generator"? Is it the one in my intial xtext project (org.xtext.example.mydsl.mydsl? The MyDslGeneratorMWE.mwe2 ?
3) What do you mean by "build automatically on the generator"? Which generator are you referring to ?
Thank you for your for your support
  • Attachment: Capture.PNG
    (Size: 28.94KB, Downloaded 280 times)
Re: How to install my xtext dsl as a plug in to Eclipse? [message #1066459 is a reply to message #1066457] Tue, 02 July 2013 13:43 Go to previous messageGo to next message
i recommend you to do the tutorials. it contains this usecase.
of course you have to start a runtime eclipse for the builder doing the work.
in the mwe case simply run the workflow after setting properties appropriate (modeldir or something like that)
Re: How to install my xtext dsl as a plug in to Eclipse? [message #1066462 is a reply to message #1066459] Tue, 02 July 2013 13:58 Go to previous messageGo to next message
Ok , I see what you mean.
Yes I am able to do that. I run the project as eclipse application and then when I save my dsl file, the generator is invoked automatically .That works perfectly
However I was wondering how can I distribute my dsl so that other users can create my dsl files and then generate the code automatically.
Re: How to install my xtext dsl as a plug in to Eclipse? [message #1066463 is a reply to message #1066462] Tue, 02 July 2013 14:13 Go to previous messageGo to next message
as i said: depends on how you want to trigger that (standalone/mwe/in eclipse)
Re: How to install my xtext dsl as a plug in to Eclipse? [message #1066464 is a reply to message #1066463] Tue, 02 July 2013 14:18 Go to previous messageGo to next message
alright so as far as i understand I was able to run it as mwe and in Eclipse.
However I would like to run it as standalone. Any clue for that?
Btw could you please point me to that tutorial that you mentioned above? does it contain a usecase for the standalone mode?
Thank you
Re: How to install my xtext dsl as a plug in to Eclipse? [message #1066466 is a reply to message #1066464] Tue, 02 July 2013 14:21 Go to previous messageGo to next message
no it was targeting the eclipse usecase.
standalone depends on your usecase
1 file or multiple etc
(for one file you can let the generatorfragment generate a javamain you may manipulate to handle multiple files as well)
Re: How to install my xtext dsl as a plug in to Eclipse? [message #1066472 is a reply to message #1066466] Tue, 02 July 2013 15:08 Go to previous messageGo to next message
Suppose that a user ( who does not have the xtext project) creates a new java project and wants to use my dsl in order to generate some java code. So he creates a file test.mydsl adds a model inside and then wants to generate the java code out of the test.mydsl file. How could this scenario be realised?
Thank you
Re: How to install my xtext dsl as a plug in to Eclipse? [message #1066473 is a reply to message #1066472] Tue, 02 July 2013 15:16 Go to previous messageGo to next message
the user saves the .mydsl file. the code is generated automatically. (try the tutorial from the docs)
Re: How to install my xtext dsl as a plug in to Eclipse? [message #1066475 is a reply to message #1066473] Tue, 02 July 2013 15:22 Go to previous messageGo to next message
Thank you . I ll have a look.
could you please tell me which tutorial and docs are you referring to?
I would be grateful if you could send me the link.
Re: How to install my xtext dsl as a plug in to Eclipse? [message #1066477 is a reply to message #1066475] Tue, 02 July 2013 15:27 Go to previous message
(1) http://www.eclipse.org/Xtext/documentation.html#FirstFiveMinutes
(2) http://www.eclipse.org/Xtext/documentation.html#DomainModelWalkThrough
(3) http://www.eclipse.org/Xtext/documentation.html#DomainmodelNextSteps
Previous Topic:[XBase] Model inferer: Problem with manually building AST
Next Topic:Referencing global scope items with prefixed names
Current Time: Sun Jul 20 10:27:19 EDT 2025
Powered by FUDForum. Page generated in 1.05711 seconds
