Home » Language IDEs » C / C++ IDE (CDT) » CDT loses contact with gdb after a few commands
CDT loses contact with gdb after a few commands [message #629642] |
Wed, 29 September 2010 01:27  |
When I bring up my local C++ application in the debugger, the first few debugger commands work. Then, after 5 to 10 commands (step, next, or whatever), the debugger ceases to accept commands. All I can do is stop the debugger and start again.
Initially with Eclipse 3.4.2 (Galileo) I was getting the error message, "Target is not responding (timed out)".
I upgraded to Helios, and the behavior did not really change, except that the error message, "Target is not responding (timed out)" no longer appears.
It seems as if Eclipse and gdb are losing contact with each other after a timeout.
I have been using Eclipse CDT for years, and only in the last few weeks have I encountered this problem. A difference is that the application I am debugging now is larger than the applications I have debugged in the past.
I am using:
Eclipse Helios
Fedora 11
GNU gdb (GDB) Fedora (6.8.50.20090302-40.fc11)
And here are Eclipse Installation Details:
*** Date: Tuesday, September 28, 2010 10:12:01 PM Pacific Daylight Time
*** Platform Details:
*** System properties:
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20100909-0800
eclipse.commands=-os
linux
-ws
gtk
-arch
x86_64
-showsplash
-launcher
/usr/local/eclipse/eclipse
-name
Eclipse
--launcher.library
/usr/local/eclipse//plugins/org.eclipse.equinox.launcher.gtk .linux.x86_64_1.1.1.R36x_v20100810/eclipse_1309.so
-startup
/usr/local/eclipse//plugins/org.eclipse.equinox.launcher_1.1 .0.v20100507.jar
-exitdata
e4001e
-product
org.eclipse.epp.package.cpp.product
-vm
/usr/bin/java
eclipse.home.location=file:/usr/local/eclipse/
eclipse.launcher=/usr/local/eclipse/eclipse
eclipse.launcher.name=Eclipse
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=epp.package.cpp
eclipse.product=org.eclipse.epp.package.cpp.product
eclipse.startTime=1285712836298
eclipse.vm=/usr/bin/java
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-XX:MaxPermSize=256m
-Xms40m
-Xmx384m
-jar
equinox.use.ds=true
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/usr/local/eclipse//plugins/org.eclipse.equi nox.launcher_1.1.0.v20100507.jar
java.class.version=50.0
java.endorsed.dirs=/usr/lib/jvm/java-1.6.0-openjdk-1.6.0.0.x 86_64/jre/lib/endorsed
java.ext.dirs=/usr/lib/jvm/java-1.6.0-openjdk-1.6.0.0.x86_64 /jre/lib/ext:/usr/java/packages/lib/ext
java.home=/usr/lib/jvm/java-1.6.0-openjdk-1.6.0.0.x86_64/jre
java.io.tmpdir=/tmp
java.library.path=/usr/lib/jvm/java-1.6.0-openjdk-1.6.0.0.x8 6_64/jre/lib/amd64/server:/usr/lib/jvm/java-1.6.0-openjdk-1. 6.0.0.x86_64/jre/lib/amd64:/usr/lib/jvm/java-1.6.0-openjdk-1 .6.0.0.x86_64/jre/../lib/amd64:/usr/lib64/xulrunner-1.9.1:/u sr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
java.runtime.name=OpenJDK Runtime Environment
java.runtime.version=1.6.0_18-b18
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_18
java.vm.info=mixed mode
java.vm.name=OpenJDK 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=14.0-b16
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.NoOpLog
org.eclipse.cdt.debug.ui.debuggerActive=false
org.eclipse.debug.ui.breakpoints.toggleFactoriesUsed=true
org.eclipse.equinox.launcher.splash.location=/usr/local/ecli pse/plugins/org.eclipse.platform_3.6.1.v201009090800/splash. bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2S E-1.4,J2SE-1.5,JavaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.30.10-105
org.osgi.framework.processor=x86-64
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.ws.wsaddressing,javax.xml.xpath,org.i etf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.p ortable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage ,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.om g.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.om g.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.Dyn amicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.Dyna micAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPac kage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.Port ableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPacka ge,org.omg.PortableServer,org.omg.PortableServer.CurrentPack age,org.omg.PortableServer.POAManagerPackage,org.omg.Portabl eServer.POAPackage,org.omg.PortableServer.portable,org.omg.P ortableServer.ServantLocatorPackage,org.omg.SendingContext,o rg.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w 3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.l s,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.tra versal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.x ml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.5.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=amd64
os.name=Linux
os.version=2.6.30.10-105.2.23.fc11.x86_64
osgi.arch=x86_64
osgi.bundles=reference:file: org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503.jar @1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=/home/johnm/.eclipse/org.eclipse.platform_3 .6.1_185596441/configuration/org.eclipse.osgi/bundles
osgi.configuration.area=file:/home/johnm/.eclipse/org.eclips e.platform_3.6.1_185596441/configuration/
osgi.framework=file:/usr/local/eclipse/plugins/org.eclipse.o sgi_3.6.1.R36x_v20100806.jar
osgi.framework.extensions=
osgi.framework.shape=jar
osgi.framework.version=3.6.1.R36x_v20100806
osgi.install.area=file:/usr/local/eclipse/
osgi.instance.area=file:/home/johnm/src/
osgi.instance.area.default=file:/home/johnm/workspace/
osgi.logfile=/home/johnm/src/.metadata/.log
osgi.manifest.cache=/home/johnm/.eclipse/org.eclipse.platfor m_3.6.1_185596441/configuration/org.eclipse.osgi/manifests
osgi.nl=en_US
osgi.os=linux
osgi.sharedConfiguration.area=file:/usr/local/eclipse/config uration/
osgi.splashLocation=/usr/local/eclipse/plugins/org.eclipse.p latform_3.6.1.v201009090800/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/usr/local/eclipse/plugins
osgi.tracefile=/home/johnm/src/.metadata/trace.log
osgi.ws=gtk
path.separator=:
sun.arch.data.model=64
sun.boot.class.path=/usr/lib/jvm/java-1.6.0-openjdk-1.6.0.0. x86_64/jre/lib/resources.jar:/usr/lib/jvm/java-1.6.0-openjdk -1.6.0.0.x86_64/jre/lib/rt.jar:/usr/lib/jvm/java-1.6.0-openj dk-1.6.0.0.x86_64/jre/lib/sunrsasign.jar:/usr/lib/jvm/java-1 .6.0-openjdk-1.6.0.0.x86_64/jre/lib/jsse.jar:/usr/lib/jvm/ja va-1.6.0-openjdk-1.6.0.0.x86_64/jre/lib/jce.jar:/usr/lib/jvm /java-1.6.0-openjdk-1.6.0.0.x86_64/jre/lib/charsets.jar:/usr /lib/jvm/java-1.6.0-openjdk-1.6.0.0.x86_64/jre/lib/rhino.jar :/usr/lib/jvm/java-1.6.0-openjdk-1.6.0.0.x86_64/jre/classes
sun.boot.library.path=/usr/lib/jvm/java-1.6.0-openjdk-1.6.0. 0.x86_64/jre/lib/amd64
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=gnome
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=UTF-8
sun.management.compiler=HotSpot 64-Bit Server Compiler
sun.os.patch.level=unknown
user.country=US
user.dir=/home/johnm
user.home=/home/johnm
user.language=en
user.name=johnm
user.timezone=America/Los_Angeles
*** Features:
org.eclipse.cdt (7.0.1.201009141542) "Eclipse C/C++ Development Tools"
org.eclipse.cdt.gdb (7.0.0.201009141542) "GDB Common"
org.eclipse.cdt.mylyn (5.2.101.v20100916-0100-e3x-2027w31211A1A012110) "Mylyn"
org.eclipse.cdt.p2 (1.0.0.201009141542) "CDT P2 customizations for SDKs"
org.eclipse.cvs (1.2.0.v20100427-7B77FKt90GE5h0SBT5FV9A01911) "Eclipse CVS Client"
org.eclipse.epp.mpc (1.0.1.v20100826-2143) "EPP Marketplace Client"
org.eclipse.epp.package.cpp.feature (1.3.1.20100916-1202) "EPP CPP Bundle"
org.eclipse.help (1.2.0.v20100427-7e7jEQFEp4jsWcboLU9l93) "Help System Base"
org.eclipse.mylyn_feature (3.4.2.v20100916-0100-e3x-7Z7f77FBBoPbPQeUoFeZXJ8) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.4.2.v20100916-0100-e3x-7D773BgJ9DH9fCc4CICE1) "Mylyn"
org.eclipse.mylyn.context_feature (3.4.2.v20100916-0100-e3x-777718s73533L3L135331) "Mylyn"
org.eclipse.mylyn.ide_feature (3.4.2.v20100916-0100-e3x-7G7J2BgJ9E99jDd49E994) "Mylyn"
org.eclipse.mylyn.team_feature (3.4.2.v20100916-0100-e3x-4317w31211A1A012110) "Mylyn"
org.eclipse.mylyn.wikitext_feature (1.3.2.v20100916-0100-e3x-7F7e1FC7sReRSnX-DReRRD) "Mylyn"
org.eclipse.platform (3.6.1.r361_v20100909-9gF78GrkFqw7GrsZnvz0JWNTeb6fue6896L) "Eclipse Platform"
org.eclipse.rcp (3.6.1.r361_v20100827-9OArFLdFjY-ThSQXmKvKz0_T) "Eclipse RCP"
*** Plug-in Registry:
com.cthing.cmakeed.core (1.1.5) "CMakeEd Core Plug-in" [Starting]
com.cthing.cmakeed.ui (1.1.5) "CMakeEd UI Plug-in" [Starting]
com.ibm.icu (4.2.1.v20100412) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.41.v200903070017) "JSch" [Resolved]
com.objfac.xmleditor (2.0.72) "XMLBuddy" [Starting]
javax.servlet (2.5.0.v200910301333) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle" [Resolved]
javax.xml.bind (2.0.0.v20080604-1500) "JAXB" [Resolved]
org.apache.ant (1.7.1.v20100518-1145) "Apache Ant" [Resolved]
org.apache.commons.codec (1.3.0.v20100106-1700) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.codec (1.3.0.v20100518-1140) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.el (1.0.0.v201004212143) "Apache Commons JSP 2.0 Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons Httpclient" [Resolved]
org.apache.commons.httpclient (3.1.0.v201005080502) "Apache Commons Httpclient" [Resolved]
org.apache.commons.lang (2.3.0.v201005080501) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.logging (1.0.4.v200904062259) "Apache Commons Logging Plug-in" [Resolved]
org.apache.commons.logging (1.0.4.v201005080501) "Apache Commons Logging Plug-in" [Resolved]
org.apache.jasper (5.5.17.v201004212143) "Apache Jasper 2 Plug-in" [Resolved]
org.apache.lucene (1.9.1.v20100518-1140) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20100518-1140) "Apache Lucene Analysis" [Resolved]
org.apache.ws.commons.util (1.0.0.v20100518-1135) "WS Commons Util Plug-in" [Resolved]
org.apache.xmlrpc (3.0.0.v20100427-1100) "Apache XML-RPC Plug-in" [Resolved]
org.eclipse.ant.core (3.2.200.v20100427) "Ant Build Tool Core" [Starting]
org.eclipse.cdt (7.0.1.201009141542) "Eclipse C/C++ Development Tools" [Starting]
org.eclipse.cdt.core (5.2.1.201009141542) "C/C++ Development Tools Core" [Active]
org.eclipse.cdt.core.linux (5.2.0.201009141542) "C/C++ Development Tools Core for Linux" [Resolved]
org.eclipse.cdt.core.linux.x86_64 (5.2.0.201009141542) "C/C++ Development Tools Core for Linux (x86_64)" [Resolved]
org.eclipse.cdt.debug.core (7.0.0.201009141542) "C/C++ Development Tools Debug Model" [Active]
org.eclipse.cdt.debug.mi.core (7.0.1.201009141542) "C/C++ Development Tools GDB/MI CDI Debugger Core" [Active]
org.eclipse.cdt.debug.mi.ui (6.1.0.201009141542) "C/C++ Development Tools GDB/MI CDI Debugger UI" [Active]
org.eclipse.cdt.debug.ui (7.0.0.201009141542) "C/C++ Development Tools Debugger UI" [Active]
org.eclipse.cdt.debug.ui.memory.memorybrowser (1.2.0.201009141542) "Memory Browser" [Starting]
org.eclipse.cdt.debug.ui.memory.search (1.2.0.201009141542) "Memory Search" [Starting]
org.eclipse.cdt.debug.ui.memory.traditional (1.2.0.201009141542) "Traditional Memory Rendering" [Starting]
org.eclipse.cdt.debug.ui.memory.transport (2.1.0.201009141542) "Memory Transport Plug-in" [Starting]
org.eclipse.cdt.doc.user (5.1.0.201009141542) "C/C++ Development User Guide" [Starting]
org.eclipse.cdt.dsf (2.1.0.201009141542) "Debug Services Framework Core" [Active]
org.eclipse.cdt.dsf.gdb (3.0.0.201009141542) "GDB DSF Debugger Integration Core" [Active]
org.eclipse.cdt.dsf.gdb.ui (2.1.0.201009141542) "GDB DSF Debugger Integration UI" [Active]
org.eclipse.cdt.dsf.ui (2.1.1.201009141542) "Debugger Services Framework UI" [Active]
org.eclipse.cdt.gdb (7.0.0.201009141542) "GDB Common" [Starting]
org.eclipse.cdt.gdb.ui (7.0.0.201009141542) "GDB UI Common" [Starting]
org.eclipse.cdt.launch (6.1.0.201009141542) "C/C++ Development Tools Launching Support" [Active]
org.eclipse.cdt.make.core (7.0.0.201009141542) "C/C++ Standard make Build Core" [Active]
org.eclipse.cdt.make.ui (7.0.0.201009141542) "C/C++ Standard make Build UI" [Active]
org.eclipse.cdt.managedbuilder.core (7.0.1.201009141542) "CDT Build System Core" [Active]
org.eclipse.cdt.managedbuilder.gnu.ui (7.0.0.201009141542) "GNU Managed Build Definitions" [Starting]
org.eclipse.cdt.managedbuilder.ui (7.0.0.201009141542) "C/C++ Managed Builder UI" [Starting]
org.eclipse.cdt.mylyn.ui (1.1.3.v20100909-0100-e3x) "bundleName" [Active]
org.eclipse.cdt.p2 (1.0.0.201009141542) "CDT P2 customizations for SDKs" [Starting]
org.eclipse.cdt.ui (5.2.1.201009141542) "C/C++ Development Tools UI" [Active]
org.eclipse.compare (3.5.100.I20100526-0800) "Compare Support" [Starting]
org.eclipse.compare.core (3.5.100.I20100526-0800) "Core Compare Support" [Active]
org.eclipse.core.boot (3.1.200.v20100505) "Core Boot" [Starting]
org.eclipse.core.commands (3.6.0.I20100512-1500) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.100.v20100505-1235) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.3.100.I20100601-0800) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.100.I20100601-0800) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.3.0.I20100601-0800) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.3.0.I20100601-0800) "JFace Data Binding" [Starting]
org.eclipse.core.expressions (3.4.200.v20100505) "Expression Language" [Active]
org.eclipse.core.externaltools (1.0.1.v20100831_r361) "External Tools Headless Support" [Active]
org.eclipse.core.filebuffers (3.5.100.v20100520-0800) "File Buffers" [Active]
org.eclipse.core.filesystem (1.3.1.R36x_v20100727-0745) "Core File Systems" [Active]
org.eclipse.core.filesystem.linux.x86_64 (1.2.0.v20100505-1235) "Core File System for Linux" [Resolved]
org.eclipse.core.jobs (3.5.1.R36x_v20100824) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.2.100.I20100511-0800) "Internet Connection Management" [Active]
org.eclipse.core.net.linux.x86_64 (1.1.0.I20100505-1245) "Proxy for Linux x86_64" [Resolved]
org.eclipse.core.resources (3.6.0.R36x_v20100825-0600) "Core Resource Management" [Active]
org.eclipse.core.runtime (3.6.0.v20100505) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.100.v20100505) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.200.v20100517) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.3.0.v20100520) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.400.v20100505) "Core Variables" [Active]
org.eclipse.cvs (1.0.500.v201009090800) "Eclipse CVS Client" [Starting]
org.eclipse.debug.core (3.6.0.v20100519) "Debug Core" [Active]
org.eclipse.debug.ui (3.6.1.v20100901_r361) "Debug UI" [Active]
org.eclipse.ecf (3.1.0.v20100529-0735) "ECF Core API" [Starting]
org.eclipse.ecf.filetransfer (4.0.0.v20100529-0735) "ECF Filetransfer API" [Starting]
org.eclipse.ecf.identity (3.1.0.v20100529-0735) "ECF Identity API" [Starting]
org.eclipse.ecf.provider.filetransfer (3.1.0.v20100529-0735) "ECF Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient (4.0.0.v20100529-0735) "ECF HttpClient Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient.ssl (1.0.0.v20100529-0735) "ECF HttpClient Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20100529-0735) "ECF Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.0.0.v20100529-0735) "ECF Core API" [Resolved]
org.eclipse.epp.mpc.core (1.0.0.v20100826-2143) "Marketplace Client" [Resolved]
org.eclipse.epp.mpc.help.ui (1.0.0.v20100826-2143) "Marketplace Client Help" [Resolved]
org.eclipse.epp.mpc.ui (1.0.1.v20100826-2143) "EPP Marketplace Client" [Starting]
org.eclipse.epp.package.common (1.3.1.20100913-1228) "EPP Common Bundle" [Resolved]
org.eclipse.epp.package.cpp (1.3.1.20100913-1228) "EPP CPP Bundle" [Resolved]
org.eclipse.epp.usagedata.gathering (1.3.0.R201005261100) "Usage Data Gathering Plug-in" [Active]
org.eclipse.epp.usagedata.recording (1.3.0.R201005261100) "Usage Data Recording Plug-in" [Active]
org.eclipse.epp.usagedata.ui (1.3.0.R201005261100) "Usage Data UI Plug-in" [Starting]
org.eclipse.equinox.app (1.3.1.R36x_v20100803) "Equinox Application Container" [Active]
org.eclipse.equinox.common (3.6.0.v20100503) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.concurrent (1.0.100.v20100503) "Equinox Concurrent API" [Starting]
org.eclipse.equinox.ds (1.2.1.R36x_v20100803) "Declarative Services" [Active]
org.eclipse.equinox.event (1.2.0.v20100503) "Event Admin" [Active]
org.eclipse.equinox.frameworkadmin (2.0.0.v20100503) "Equinox Framework Admin" [Starting]
org.eclipse.equinox.frameworkadmin.equinox (1.0.200.v20100505) "Equinox Framework Admin for Equinox" [Starting]
org.eclipse.equinox.http.jetty (2.0.0.v20100503) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.1.0.v20100503) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.1.0.v20100503) "Http Services Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.200.v20100421) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.200.v20100503) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.1.0.v20100507) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.gtk.linux.x86_64 (1.1.1.R36x_v20100810) "Equinox Launcher Linux X86_64 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.1.1.R36x_v20100901) "Equinox Provisioning Artifact Repository Support" [Starting]
org.eclipse.equinox.p2.console (1.0.200.v20100601) "Equinox Provisioning Console" [Starting]
org.eclipse.equinox.p2.core (2.0.2.R36x_v20100804) "Equinox Provisioning Core" [Active]
org.eclipse.equinox.p2.director (2.0.2.R36x_v20100823) "Equinox Provisioning Director" [Starting]
org.eclipse.equinox.p2.director.app (1.0.201.R36x_v20100823) "Equinox Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.0.202.R36x_v20100727) "Equinox Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.discovery (1.0.0.v20100503) "Equinox Provisioning Discovery" [Resolved]
org.eclipse.equinox.p2.discovery.compatibility (1.0.0.v20100518) "Equinox Provisioning Discovery" [Resolved]
org.eclipse.equinox.p2.engine (2.0.0.v20100606) "Equinox Provisioning Engine" [Active]
org.eclipse.equinox.p2.extensionlocation (1.2.0.v20100518) "Extension Location Repository Support" [Starting]
org.eclipse.equinox.p2.garbagecollector (1.0.100.v20100503) "Provisioning Garbage Collector" [Starting]
org.eclipse.equinox.p2.jarprocessor (1.0.200.v20100503a) "Equinox Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (2.0.0.v20100601) "Equinox Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.generator (1.0.200.v20100503a) "Equinox Provisioning Metadata Generator" [Starting]
org.eclipse.equinox.p2.metadata.repository (1.1.0.v20100513) "Equinox Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.operations (2.0.0.v20100510) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.publisher (1.1.2.v20100824-2220) "Equinox Provisioning Publisher" [Starting]
org.eclipse.equinox.p2.ql (2.0.0.v20100503a) "p2 query language" [Starting]
org.eclipse.equinox.p2.reconciler.dropins (1.1.0.v20100525) "Dropin Reconciler Plug-in" [Active]
org.eclipse.equinox.p2.repository (2.0.1.R36x_v20100823) "Equinox Provisioning Repository" [Active]
org.eclipse.equinox.p2.repository.tools (2.0.1.R36x_v20100823) "Equinox p2 repository tools." [Starting]
org.eclipse.equinox.p2.touchpoint.eclipse (2.0.2.R36x_v20100823) "Equinox Provisioning Eclipse Touchpoint" [Starting]
org.eclipse.equinox.p2.touchpoint.natives (1.0.200.v20100503a) "Equinox Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.ui (2.0.0.v20100518) "Equinox Provisioning UI Support" [Active]
org.eclipse.equinox.p2.ui.discovery (1.0.0.v20100519) "Equinox Provisioning Discovery UI" [Resolved]
org.eclipse.equinox.p2.ui.sdk (1.0.100.v20100513) "Equinox Provisioning Platform Update Support" [Active]
org.eclipse.equinox.p2.ui.sdk.scheduler (1.0.0.v20100507-1815) "Equinox Provisioning Platform Automatic Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.1.101.R36x_v20100823) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.0.201.R36x_v20100823) "Update site repository adapter bundle (Incubation)" [Starting]
org.eclipse.equinox.preferences (3.3.0.v20100503) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.5.0.v20100503) "Extension Registry Support" [Active]
org.eclipse.equinox.security (1.0.200.v20100503) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.0.200.v20100503) "Equinox Security Default UI" [Starting]
org.eclipse.equinox.simpleconfigurator (1.0.200.v20100503) "Simple Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (2.0.0.v20100503) "Simple Configurator Manipulator" [Starting]
org.eclipse.equinox.util (1.0.200.v20100503) "Equinox Util Bundle" [Active]
org.eclipse.help (3.5.0.v20100524) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.400.v20100427) "Help Application Server" [Starting]
org.eclipse.help.base (3.5.2.v201009090800) "Help System Base" [Starting]
org.eclipse.help.ui (3.5.2.r36_v20100702) "Help System UI" [Starting]
org.eclipse.help.webapp (3.5.2.r36_r20100816) "Help System Webapp" [Starting]
org.eclipse.jface (3.6.1.M20100825-0800) "JFace" [Active]
org.eclipse.jface.databinding (1.4.0.I20100601-0800) "JFace Data Binding for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.6.1.r361_v20100825-0800) "JFace Text" [Resolved]
org.eclipse.jsch.core (1.1.200.I20100505-1245) "JSch Core" [Active]
org.eclipse.jsch.ui (1.1.300.I20100505-1245) "JSch UI" [Starting]
org.eclipse.ltk.core.refactoring (3.5.100.v20100526-0800) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.5.0.v20100526-0800) "Refactoring UI" [Active]
org.eclipse.mylyn (3.4.0.v20100608-0100-e3x) "Mylyn" [Resolved]
org.eclipse.mylyn.bugzilla.core (3.4.2.v20100902-0100-e3x) "Mylyn Bugzilla Connector Core" [Active]
org.eclipse.mylyn.bugzilla.ide (3.4.0.v20100608-0100-e3x) "Mylyn Bugzilla IDE Extensions" [Resolved]
org.eclipse.mylyn.bugzilla.ui (3.4.2.v20100909-0100-e3x) "Mylyn Bugzilla Connector UI" [Active]
org.eclipse.mylyn.commons.core (3.4.0.v20100608-0100-e3x) "Mylyn Commons Core" [Resolved]
org.eclipse.mylyn.commons.net (3.4.1.v20100625-2100-e3x) "Mylyn Commons Net" [Active]
org.eclipse.mylyn.commons.ui (3.4.0.v20100608-0100-e3x) "Mylyn Commons UI" [Active]
org.eclipse.mylyn.commons.xmlrpc (3.4.0.v20100608-0100-e3x) "Mylyn XML-RPC Support" [Starting]
org.eclipse.mylyn.context.core (3.4.1.v20100909-0100-e3x) "Mylyn Context Core" [Active]
org.eclipse.mylyn.context.ui (3.4.1.v20100909-0100-e3x) "Mylyn Context UI" [Active]
org.eclipse.mylyn.discovery.core (3.4.0.v20100608-0100-e3x) "Mylyn Connector Discovery Core" [Resolved]
org.eclipse.mylyn.discovery.ui (3.4.0.v20100608-0100-e3x) "Mylyn Connector Discovery UI" [Resolved]
org.eclipse.mylyn.help.ui (3.4.1.v20100823-0100-e3x) "Mylyn Help" [Starting]
org.eclipse.mylyn.ide.ui (3.4.0.v20100608-0100-e3x) "Mylyn IDE UI" [Starting]
org.eclipse.mylyn.monitor.core (3.4.0.v20100608-0100-e3x) "Mylyn Monitor Core" [Resolved]
org.eclipse.mylyn.monitor.ui (3.4.0.v20100608-0100-e3x) "Mylyn Monitor UI" [Active]
org.eclipse.mylyn.resources.ui (3.4.1.v20100909-0100-e3x) "Mylyn Resources UI" [Starting]
org.eclipse.mylyn.tasks.bugs (3.4.1.v20100823-0100-e3x) "Mylyn Bug Reporting" [Starting]
org.eclipse.mylyn.tasks.core (3.4.1.v20100730-0100-e3x) "Mylyn Tasks Core" [Resolved]
org.eclipse.mylyn.tasks.search (3.4.0.v20100608-0100-e3x) "Mylyn Tasks UI" [Resolved]
org.eclipse.mylyn.tasks.ui (3.4.2.v20100902-0100-e3x) "Mylyn Tasks UI" [Active]
org.eclipse.mylyn.team.cvs (3.4.1.v20100909-0100-e3x) "Mylyn CVS Extensions" [Resolved]
org.eclipse.mylyn.team.ui (3.4.2.v20100909-0100-e3x) "Mylyn Team UI" [Active]
org.eclipse.mylyn.wikitext.confluence.core (1.3.0.v20100608-0100-e3x) "Mylyn WikiText Confluence" [Resolved]
org.eclipse.mylyn.wikitext.confluence.ui (1.3.0.v20100608-0100-e3x) "Mylyn WikiText Confluence UI" [Resolved]
org.eclipse.mylyn.wikitext.core (1.3.1.v20100823-0100-e3x) "Mylyn WikiText" [Starting]
org.eclipse.mylyn.wikitext.help.ui (1.3.0.v20100608-0100-e3x) "Mylyn WikiText Help UI" [Resolved]
org.eclipse.mylyn.wikitext.mediawiki.core (1.3.0.v20100608-0100-e3x) "Mylyn WikiText MediaWiki" [Resolved]
org.eclipse.mylyn.wikitext.mediawiki.ui (1.3.0.v20100608-0100-e3x) "Mylyn WikiText MediaWiki UI" [Resolved]
org.eclipse.mylyn.wikitext.tasks.ui (1.3.1.v20100823-0100-e3x) "Mylyn WikiText Tasks UI" [Starting]
org.eclipse.mylyn.wikitext.textile.core (1.3.0.v20100608-0100-e3x) "Mylyn WikiText Textile" [Resolved]
org.eclipse.mylyn.wikitext.textile.ui (1.3.0.v20100608-0100-e3x) "Mylyn WikiText Textile UI" [Resolved]
org.eclipse.mylyn.wikitext.tracwiki.core (1.3.0.v20100608-0100-e3x) "Mylyn WikiText TracWiki" [Resolved]
org.eclipse.mylyn.wikitext.tracwiki.ui (1.3.0.v20100608-0100-e3x) "Mylyn WikiText TracWiki UI" [Resolved]
org.eclipse.mylyn.wikitext.twiki.core (1.3.0.v20100608-0100-e3x) "Mylyn WikiText Twiki" [Resolved]
org.eclipse.mylyn.wikitext.twiki.ui (1.3.0.v20100608-0100-e3x) "Mylyn WikiText Twiki UI" [Resolved]
org.eclipse.mylyn.wikitext.ui (1.3.0.v20100608-0100-e3x) "Mylyn WikiText UI" [Starting]
org.eclipse.osgi (3.6.1.R36x_v20100806) "OSGi System Bundle" [Active]
org.eclipse.osgi.services (3.2.100.v20100503) "OSGi Release 4.2.0 Services" [Resolved]
org.eclipse.osgi.util (3.2.100.v20100503) "OSGi Release 4.2.0 Utility Classes" [Resolved]
org.eclipse.platform (3.6.1.v201009090800) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.user (3.6.1.r361_v20100825-0800) "Eclipse Workbench User Guide" [Resolved]
org.eclipse.rcp (3.6.0.v201009090800) "Eclipse RCP" [Starting]
org.eclipse.search (3.6.0.v20100520-0800) "Search Support" [Active]
org.eclipse.swt (3.6.1.v3655c) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.gtk.linux.x86_64 (3.6.1.v3655c) "Standard Widget Toolkit for GTK 2.0" [Resolved]
org.eclipse.team.core (3.5.100.R36x_v20100825-0800) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.3.300.I20100526-0800) "CVS Team Provider Core" [Active]
org.eclipse.team.cvs.ssh2 (3.2.300.I20100526-0800) "CVS SSH2" [Active]
org.eclipse.team.cvs.ui (3.3.301.R36x_v20100825-0800) "CVS Team Provider UI" [Active]
org.eclipse.team.ui (3.5.101.R36x_v20100825-0800) "Team Support UI" [Active]
org.eclipse.text (3.5.0.v20100601-1300) "Text" [Resolved]
org.eclipse.ui (3.6.1.M20100826-1330) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.3.0.v20100517) "Browser Support" [Starting]
org.eclipse.ui.cheatsheets (3.4.0.v20100427) "Cheat Sheets" [Starting]
org.eclipse.ui.console (3.5.0.v20100526) "Console" [Active]
org.eclipse.ui.editors (3.6.1.r361_v20100825-0800) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.2.0.v20100427) "External Tools" [Active]
org.eclipse.ui.forms (3.5.2.r36_v20100702) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.6.1.M20100825-0800) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.201.M20100707-0800) "Eclipse IDE UI Application" [Resolved]
org.eclipse.ui.intro (3.4.0.v20100427) "Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.2.402.r36_v20100702) "Universal Welcome" [Starting]
org.eclipse.ui.navigator (3.5.0.I20100601-0800) "Common Navigator View" [Active]
org.eclipse.ui.navigator.resources (3.4.201.M20100707-0800) "Navigator Workbench Components" [Starting]
org.eclipse.ui.net (1.2.100.I20100505-1245) "Internet Connection Management UI" [Active]
org.eclipse.ui.presentations.r21 (3.2.200.I20100517-1500) "R21 Presentation Plug-in" [Starting]
org.eclipse.ui.views (3.5.0.I20100527-0800) "Views" [Active]
org.eclipse.ui.views.log (1.0.100.v20100423) "Log View" [Starting]
org.eclipse.ui.views.properties.tabbed (3.5.100.I20100509-0800) "Tabbed Properties View" [Starting]
org.eclipse.ui.workbench (3.6.1.M20100826-1330) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.100.I20100511-0800) "Workbench Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.6.1.r361_v20100714-0800) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.3.100.v20100512) "Install/Update Configurator" [Active]
org.eclipse.update.core (3.2.402.R36x_v20100629) "Install/Update Core" [Active]
org.eclipse.update.scheduler (3.2.300.v20100512) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.2.300.v20100512) "Install/Update UI" [Starting]
org.mortbay.jetty.server (6.1.23.v201004211559) "Jetty Server" [Resolved]
org.mortbay.jetty.util (6.1.23.v201004211559) "Jetty Utilities" [Resolved]
org.sat4j.core (2.2.0.v20100429) "SAT4J Core" [Resolved]
org.sat4j.pb (2.2.0.v20100429) "SAT4J Pseudo" [Resolved]
*** User Preferences:
#Tue Sep 28 22:12:04 PDT 2010
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.f ormatter.keep_imple_if_on_one_line=false
/project/tcldp/org.eclipse.cdt.core/org.eclipse.cdt.core.for matter.insert_space_before_closing_paren_in_method_invocatio n=do not insert
/bundle_defaults/org.eclipse.debug.ui/org.eclpise.debug.ui.m emory.dynamicLoad=false
/project/tcldp/org.eclipse.cdt.core/org.eclipse.cdt.core.for matter.insert_space_before_colon_in_base_clause=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatte r.insert_space_after_comma_in_template_parameters=insert
/bundle_defaults/org.eclipse.core.resources/refresh.enabled= false
/bundle_defaults/org.eclipse.ui.editors/revisionRulerShowRev ision=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatte r.insert_space_before_closing_paren_in_method_invocation=do not insert
/project/tcldp/org.eclipse.cdt.core/org.eclipse.cdt.core.for matter.insert_space_after_opening_paren_in_switch=do not insert
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.w ait_for_build=always
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.f ormatter.indent_empty_lines=false
/project/edalink/org.eclipse.cdt.core/org.eclipse.cdt.core.f ormatter.insert_space_before_opening_paren_in_method_invocat ion=do not insert
/project/oa-22.04p044/org.eclipse.cdt.core/org.eclipse.cdt.c ore.formatter.insert_new_line_before_else_in_if_statement=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatte r.brace_position_for_method_declaration=next_line
/project/tcldp/org.eclipse.cdt.core/org.eclipse.cdt.core.for matter.insert_space_after_comma_in_template_parameters=inser t
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enu m.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/c_numbers=0,0,0
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatte r.insert_space_after_closing_angle_bracket_in_template_argum ents=insert
/project/oa-22.04p044/org.eclipse.cdt.core/org.eclipse.cdt.c ore.formatter.insert_new_line_after_opening_brace_in_array_i nitializer=do not insert
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt. debug.corecDebug.default_variable_format=0
/bundle_defaults/org.eclipse.cdt.dsf.ui/linked.exit.navigati on.dropdown=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatte r.insert_space_after_opening_paren_in_parenthesized_expressi on=do not insert
/project/tcldp/org.eclipse.cdt.core/org.eclipse.cdt.core.for matter.insert_space_before_colon_in_case=do not insert
/bundle_defaults/org.eclipse.epp.usagedata.recording/org.ecl ipse.epp.usagedata.recording.filter-eclipse-only=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/showAdditionInNextPr evDropdownToolbarAction=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.f ormatter.insert_new_line_before_else_in_if_statement=do not insert
/bundle_defaults/org.eclipse.ui.editors/problemMarkerErrorIn dicationInVerticalRuler=true
/bundle_defaults/org.eclipse.team.ui/org.eclipse.team.ui.fir st_time=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.f ormatter.lineSplit=80
/bundle_defaults/org.eclipse.ui.editors/isproblemMarkerWarni ngGoToNextNavigationTarget=true
/project/edalink/org.eclipse.cdt.ui/formatter_settings_versi on=1
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.b uild_before_launch=true
/bundle_defaults/org.eclipse.cdt.core/indexer/indexAllFiles= true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatte r.brace_position_for_type_declaration=next_line
/bundle_defaults/org.eclipse.ui.editors/lineNumberRuler=fals e
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.ove rloadedOperator.enabled=false
/project/oa-22.04p044/org.eclipse.cdt.core/org.eclipse.cdt.c ore.formatter.insert_space_before_opening_paren_in_while=ins ert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatte r.insert_space_after_question_in_conditional=insert
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.d etail_pane_word_wrap=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.f ormatter.insert_space_after_closing_brace_in_block=insert
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.met hod.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enu merator.color=0,0,192
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoinser t=true
/bundle_defaults/org.eclipse.debug.ui/Console.wrap=false
/project/oa-22.04p044/org.eclipse.cdt.core/org.eclipse.cdt.c ore.formatter.insert_space_before_opening_paren_in_method_de claration=do not insert
/project/tcldp/org.eclipse.cdt.core/org.eclipse.cdt.core.for matter.alignment_for_expressions_in_array_initializer=16
/bundle_defaults/org.eclipse.ui.editors/changeIndicationInOv erviewRuler=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.f ormatter.alignment_for_conditional_expression=80
/instance/org.eclipse.help.ui/browser.y=6
/instance/org.eclipse.help.ui/browser.x=0
/bundle_defaults/org.eclipse.cdt.ui/scalability.semanticHigh light=false
/instance/org.eclipse.help.ui/browser.w=1024
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_i nactive=true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatte r.insert_space_before_closing_paren_in_switch=do not insert
/project/edalink/org.eclipse.cdt.core/org.eclipse.cdt.core.f ormatter.insert_space_before_colon_in_default=do not insert
@org.eclipse.cdt.ui=5.2.1.201009141542
/bundle_defaults/org.eclipse.cdt.dsf.ui/revisionAnnotationIn dicationHighlighting=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.ena bled=true
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.internal .ui.text.doctools.doxygen.recognizedTag=127,159,191
/bundle_defaults/org.eclipse.ui.ide/MARKER_LIMITS_VALUE=100
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS _TYPE=
/bundle_defaults/org.eclipse.ui.editors/spellingEngine=
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.f ormatter.insert_space_before_comma_in_method_declaration_par ameters=do not insert
/bundle_defaults/org.eclipse.ui.ide/CLOSE_UNRELATED_PROJECTS =false
/instance/org.eclipse.ui.editors/spellingEngine=org.eclipse. jdt.internal.ui.text.spelling.DefaultSpellingEngine
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enu merator.strikethrough=false
/bundle_defaults/org.eclipse.ui.editors/showErrorInNextPrevD ropdownToolbarAction=true
/instance/org.eclipse.help.ui/browser.h=768
/project/tcldp/org.eclipse.cdt.core/org.eclipse.cdt.core.for matter.insert_space_before_closing_paren_in_parenthesized_ex pression=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.f ormatter.insert_space_after_comma_in_method_invocation_argum ents=insert
/project/edalink/org.eclipse.cdt.core/org.eclipse.cdt.core.f ormatter.insert_space_before_closing_bracket=do not insert
/project/tcldp/org.eclipse.cdt.core/org.eclipse.cdt.core.for matter.insert_new_line_in_empty_block=insert
/project/tcldp/org.eclipse.cdt.core/org.eclipse.cdt.core.for matter.continuation_indentation=2
/bundle_defaults/org.eclipse.ui.editors/checkMarkerWarningIn dicationInOverviewRuler=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.f ormatter.insert_space_before_opening_bracket=do not insert
/project/oa-22.04p044/org.eclipse.cdt.core/org.eclipse.cdt.c ore.formatter.insert_space_before_opening_paren_in_catch=ins ert
/bundle_defaults/org.eclipse.ui.editors/isCheckMarkerWarning GoToPreviousNavigationTarget=true
/instance/org.eclipse.cdt.ui/useAnnotationsPrefPage=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.nam espace.italic=false
/bundle_defaults/org.eclipse.ui.editors/checkMarkerErrorHigh lighting=false
/bundle_defaults/org.eclipse.ui.editors/showTaskInNextPrevDr opdownToolbarAction=true
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.org.eclipse.jdt.debug.ui.show_null_entries=true
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_enabled=f alse
/project/tcldp/org.eclipse.cdt.core/org.eclipse.cdt.core.for matter.insert_space_after_opening_paren_in_while=do not insert
/project/edalink/org.eclipse.cdt.core/org.eclipse.cdt.core.f ormatter.insert_space_before_assignment_operator=insert
/instance/org.eclipse.jdt.ui/content_assist_number_of_comput ers=13
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.cla ss.underline=false
/project/edalink/org.eclipse.cdt.core/org.eclipse.cdt.core.f ormatter.indent_switchstatements_compare_to_cases=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enu m.bold=false
/bundle_defaults/org.eclipse.team.cvs.ui/pref_projecttext_de coration={outgoing_change_flag}{name} {tag} [{host}]
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_sentence =true
/bundle_defaults/org.eclipse.ui.editors/problemMarkerWarning Highlighting=false
/instance/org.eclipse.cdt.ui/org.eclipse.cdt.ui.formatterpro files= <?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\n<profiles version\="1">\n<profile kind\="CodeFormatterProfile" name\="Tcl-DP GNU" version\="1">\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_opening_p aren_in_method_declaration " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_opening_pa ren_in_for " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_new_line_in_empty_bloc k " value\="insert"/>\n<setting id\="org.eclipse.cdt.core.formatter.lineSplit" value\="80"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_comma_in_ base_types " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.keep_else_statement_on_same_l ine " value\="false"/>\n<setting id\=" org.eclipse.cdt.core.formatter.indent_switchstatements_compa re_to_switch " value\="false"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_opening_br ace_in_array_initializer " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_comma_in_ method_declaration_parameters " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_opening_pa ren_in_if " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_closing_p aren_in_parenthesized_expression " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_comma_in_b ase_types " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.indent_body_declarations_comp are_to_access_specifier " value\="true"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_comma_in_t emplate_arguments " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_opening_b race_in_block " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_closing_p aren_in_method_declaration " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.use_tabs_only_for_leading_ind entations " value\="false"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_colon_in_ labeled_statement " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_colon_in_c ase " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_comma_in_a rray_initializer " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_comma_in_e num_declarations " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.alignment_for_expressions_in_ array_initializer " value\="16"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_comma_in_d eclarator_list " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_opening_b racket " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_closing_p aren_in_for " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_prefix_op erator " value\="do not insert"/>\n<setting id\="org.eclipse.cdt.core.formatter.tabulation.size" value\="8"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_new_line_before_else_i n_if_statement " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.alignment_for_enumerator_list " value\="48"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_opening_pa ren_in_parenthesized_expression " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_between_empty_pa rens_in_method_declaration " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.alignment_for_declarator_list " value\="16"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_closing_p aren_in_switch " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_opening_p aren_in_parenthesized_expression " value\="do not insert"/>\n<setting id\="org.eclipse.cdt.core.formatter.indent_empty_lines" value\="false"/>\n<setting id\=" org.eclipse.cdt.core.formatter.indent_switchstatements_compa re_to_cases " value\="true"/>\n<setting id\=" org.eclipse.cdt.core.formatter.keep_empty_array_initializer_ on_one_line " value\="false"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_opening_b race_in_method_declaration " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.put_empty_statement_on_new_li ne " value\="true"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_opening_b race_in_switch " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_closing_p aren_in_cast " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_between_empty_br aces_in_array_initializer " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.brace_position_for_method_dec laration " value\="next_line"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_closing_p aren_in_while " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_question_i n_conditional " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_semicolon " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_closing_an gle_bracket_in_template_arguments " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_colon_in_ base_clause " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.indent_breaks_compare_to_case s " value\="true"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_unary_ope rator " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_comma_in_ declarator_list " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.alignment_for_arguments_in_me thod_invocation " value\="16"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_opening_p aren_in_while " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_between_empty_br ackets " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_opening_br acket " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.alignment_for_parameters_in_m ethod_declaration " value\="16"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_new_line_before_closin g_brace_in_array_initializer " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.number_of_empty_lines_to_pres erve " value\="1"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_opening_pa ren_in_method_invocation " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_closing_b race_in_array_initializer " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_semicolon _in_for " value\="do not insert"/>\n<setting id\="org.eclipse.cdt.core.formatter.brace_position_for_block " value\="next_line_shifted"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_colon_in_ conditional " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.brace_position_for_type_decla ration " value\="next_line"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_assignmen t_operator " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_opening_a ngle_bracket_in_template_arguments " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_comma_in_ expression_list " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_opening_an gle_bracket_in_template_parameters " value\="do not insert"/>\n<setting id\="org.eclipse.cdt.core.formatter.continuation_indentation " value\="2"/>\n<setting id\=" org.eclipse.cdt.core.formatter.alignment_for_expression_list " value\="0"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_opening_pa ren_in_method_declaration " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_comma_in_ template_parameters " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_binary_ope rator " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_colon_in_ default " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.alignment_for_conditional_exp ression " value\="80"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_between_empty_pa rens_in_method_invocation " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_comma_in_ array_initializer " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_closing_p aren_in_if " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.format_guardian_clause_on_one _line " value\="false"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_opening_pa ren_in_cast " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.indent_access_specifier_compa re_to_type_header " value\="false"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_opening_b race_in_type_declaration " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_colon_in_l abeled_statement " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.continuation_indentation_for_ array_initializer " value\="2"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_comma_in_m ethod_declaration_parameters " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_semicolon_ in_for " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_closing_p aren_in_method_invocation " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.indent_body_declarations_comp are_to_namespace_header " value\="true"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_closing_br ace_in_block " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_assignment _operator " value\="insert"/>\n<setting id\="org.eclipse.cdt.core.formatter.alignment_for_compact_if " value\="0"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_opening_b race_in_array_initializer " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_new_line_at_end_of_fil e_if_missing " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_comma_in_t emplate_parameters " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_comma_in_e xpression_list " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_question_ in_conditional " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_binary_op erator " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_new_line_before_identi fier_in_function_declaration " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.alignment_for_base_clause_in_ type_declaration " value\="80"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_comma_in_ method_declaration_throws " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_comma_in_ method_invocation_arguments " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.indent_declaration_compare_to _template_header " value\="true"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_unary_oper ator " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_opening_p aren_in_switch " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.indent_statements_compare_to_ body " value\="true"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_comma_in_m ethod_declaration_throws " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.indent_statements_compare_to_ block " value\="true"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_comma_in_ template_arguments " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_new_line_before_catch_ in_try_statement " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.alignment_for_throws_clause_i n_method_declaration " value\="16"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_opening_p aren_in_method_invocation " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_closing_pa ren_in_cast " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_closing_p aren_in_catch " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_opening_a ngle_bracket_in_template_parameters " value\="do not insert"/>\n<setting id\="org.eclipse.cdt.core.formatter.tabulation.char" value\="mixed"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_before_closing_a ngle_bracket_in_template_parameters " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_opening_pa ren_in_while " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_comma_in_m ethod_invocation_arguments " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.brace_position_for_block_in_c ase " value\="next_line_shifted"/>\n<setting id\="org.eclipse.cdt.core.formatter.compact_else_if" value\="true"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_postfix_op erator " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_colon_in_b ase_clause " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_new_line_after_templat e_declaration " value\="insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.insert_space_after_opening_pa ren_in_catch " value\="do not insert"/>\n<setting id\=" org.eclipse.cdt.core.formatter.keep_then_statement_on_same_l ine " value\="false"/>\n<setting id\="org.eclipse.cdt.core.formatter.brace_position_for_switch " value\="next_line_shifted"/>\n<setting id
Re: CDT loses contact with gdb after a few commands [message #629909 is a reply to message #629642] |
Wed, 29 September 2010 18:04   |
Originally posted by: bruce.ring.sbcglobal.net
I had a similar problem with both Helios and Galileo (on Windows XP with
Cygwin). After much digging around the Internet, I could find no solution. I
started using Ganymede and it works fine. (Well, there is this "discovery"
option I have to turn off, but otherwise, it is solid.)
"John McGehee" <eclipse@voom.net> wrote in message
news:i7uijm$9ec$1@news.eclipse.org...
> appears.
> timeout.
> past.
> I am using:
> Eclipse Helios
> Fedora 11
> linux
> -ws
> gtk
> -arch
> x86_64
> -showsplash
> -launcher
> -name
> Eclipse
> --launcher.library
> -startup
> .0.v20100507.jar
> -exitdata
> e4001e
> -product
> -vm
> /usr/bin/java
> -Xms40m
> -Xmx384m
> -jar
> .0.v20100507.jar
> equinox.use.ds=true
> file.encoding=UTF-8
> file.separator=/
> java.io.tmpdir=/tmp
> line.separator=
> os.arch=amd64
> os.name=Linux
> osgi.arch=x86_64
> osgi.bundles=reference:file:mailto: org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503.jar @1:start
> osgi.nl=en_US
> osgi.os=linux
> osgi.ws=gtk
> path.separator=:
> sun.cpu.isalist=
> sun.desktop=gnome
> user.country=US
> user.language=en
> user.name=johnm
> *** Features:
> "Mylyn"
> Client"
> Base"
> Platform"
> RCP"
> [Resolved]
> Plug-in" [Resolved]
> Plug-in" [Resolved]
> Lang" [Resolved]
> Plug-in" [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> [Starting]
> [Active]
> Browser" [Starting]
> Search" [Starting]
> Guide" [Starting]
> [Active]
> Core" [Active]
> UI" [Active]
> Core" [Active]
> UI" [Active]
> Core" [Active]
> [Starting]
> [Active]
> [Active]
> Mechanism" [Active]
> [Starting]
> Binding" [Starting]
> [Active]
> [Active]
> Systems" [Active]
> [Active]
> x86_64" [Resolved]
> [Starting]
> [Starting]
> [Resolved]
> Help" [Resolved]
> [Starting]
> [Resolved]
> [Resolved]
> [Starting]
> Container" [Active]
> [Active]
> API" [Starting]
> [Active]
> Admin" [Starting]
> [Starting]
> [Starting]
> Bundle" [Starting]
> [Resolved]
> Console" [Starting]
> Core" [Active]
> Engine" [Active]
> Metadata" [Active]
> [Starting]
> Support" [Active]
> Mechanism" [Active]
> Support" [Active]
> [Active]
> [Starting]
> [Starting]
> Core" [Active]
> [Active]
> Core" [Resolved]
> Net" [Active]
> [Active]
> Support" [Starting]
> Core" [Active]
> [Active]
> [Starting]
> [Starting]
> Core" [Resolved]
> [Active]
> UI" [Starting]
> [Resolved]
> [Resolved]
> [Active]
> [Active]
> UI" [Starting]
> Classes" [Resolved]
> [Active]
> Core" [Active]
> UI" [Active]
> [Active]
> [Active]
> [Starting]
> [Active]
> [Active]
> Scheduler" [Active]
> insert
> insert
> m.enabled=false
> not insert
> on.dropdown=false
> insert
> hod.underline=false
> not insert
> erviewRuler=false
> not insert
> not insert
> espace.italic=false
> lighting=false
> ss.underline=false
> Highlighting=false
> value\="1"/>\n<sett
Re: CDT loses contact with gdb after a few commands [message #629921 is a reply to message #629642] |
Wed, 29 September 2010 19:54   |
I tried completely recreating a new workspace as suggested by another user, but the symptom did not change.
Thanks for your answer, Bruce. I too had no problem with Ganymede, and like you, I do have this problem with Galileo and Helios. Time for a downgrade, I guess.
For the record, here is my .log file:
!SESSION 2010-09-29 15:43:46.256 -----------------------------------------------
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.cpp.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product
!ENTRY org.eclipse.cdt.core 1 0 2010-09-29 16:05:38.960
!MESSAGE Indexed 'oa-22.04p044' (1,534 sources, 2,865 headers) in 1,141.95 sec: 431,247 declarations; 2,036,786 references; 9 unres
olved inclusions; 0 syntax errors; 11,505 unresolved names (0.46%)
!ENTRY org.eclipse.debug.core 4 125 2010-09-29 16:23:57.241
!MESSAGE Error logged from Debug Core:
!STACK 0
java.io.IOException: close error
at org.eclipse.cdt.utils.pty.PTYInputStream.close(PTYInputStrea m.java:79)
at java.io.BufferedInputStream.close(BufferedInputStream.java:4 68)
at org.eclipse.debug.internal.core.OutputStreamMonitor.read(Out putStreamMonitor.java:183)
at org.eclipse.debug.internal.core.OutputStreamMonitor.access$1 (OutputStreamMonitor.java:134)
at org.eclipse.debug.internal.core.OutputStreamMonitor$1.run(Ou tputStreamMonitor.java:207)
at java.lang.Thread.run(Thread.java:636)
!ENTRY org.eclipse.cdt.dsf 4 10005 2010-09-29 16:27:18.060
!MESSAGE Unknown breakpoint
!SUBENTRY 1 org.eclipse.cdt.dsf.gdb 4 10005 2010-09-29 16:27:18.060
!ENTRY org.eclipse.cdt.dsf 4 10005 2010-09-29 16:33:01.652
!MESSAGE Request for monitor: 'RequestMonitor (org.eclipse.cdt.dsf.concurrent.RequestMonitor@2ffc6df5): Status ERROR: org.eclipse.c
dt.dsf.gdb code=10001 Given context: (gdb[4].proc[13855].threadGroup[13855],gdb[4].proc[13855].OS thread[1]).thread[1], is already r
unning. null' resulted in an error.
!SUBENTRY 1 org.eclipse.cdt.dsf.gdb 4 10001 2010-09-29 16:33:01.652
!MESSAGE Given context: (gdb[4].proc[13855].threadGroup[13855],gdb[4].proc[13855].OS thread[1]).thread[1], is already running.
Re: CDT loses contact with gdb after a few commands [message #631831 is a reply to message #630047] |
Fri, 08 October 2010 19:53   |
I too was running JRE 1.6. I switched to 1.5.0_22 and it works better, but
the debugger seems to get stdin/stdout mixed up with the gdb console at some
point which I guess is related to this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=231883 For example:
#include <stdio.h>
int main(void) {
char name[30];
setvbuf(stdout, NULL, _IONBF, 0);
printf("What's your name? ");
fgets(name, 30, stdin);
printf("Hello %s", name);
return 0;
After the printf, the application console displays:
What's your name?
*stopped,reason="end-stepping-range",frame={addr="0x0040140a ",func="main",args=[],file="..\main.c",fullname="C:/Eclipse_WS/Name/.settings/..\main.c ",line="17"},thread-id="1",stopped-threads="all"
If I then enter something into the application console (not the gdb
console), the following displays in the gdb console:
Bruce
Undefined command: "Bruce". Try "help".
At that point, I cannot resume execution. I can enter an si command in the
gdb console to resume, but at that point the program is reading the gdb
console as input ...
"Tom" <tom@zerovector.net> wrote in message
news:i824ri$q4t$1@news.eclipse.org...
> https://cds.sun.com/is-bin/INTERSHOP.enfinity/WFS/CDS-CDS_De
> veloper-Site/en_US/-/USD/ViewProductDetail-Start?ProductRef=
> jre-1.5.0_11-oth-JPR@CDS-CDS_Developer
> is the link for the recommended version, in case anyone needs it.
Current Time: Sat Jul 19 15:01:50 EDT 2025
Powered by FUDForum. Page generated in 0.26369 seconds
