Home » Archived » Hudson » Job Import Plugin(Unable to get jobs to import from another Hudson install)
Job Import Plugin [message #1064750] Thu, 20 June 2013 15:36 Go to next message
I am trying to use the Job Import Plugin to pull jobs from a 2.2.1 instance into a 3.0.1 instance.
I specify the url to my other instance and click "Query" and nothing happens.
I've tried all three options shown on the plugin home page:
http://$HUDSON - get all jobs on remote instance
http://$HUDSON/job/$JOBNAME - get a single job
http://$HUDSON/view/$VIEWNAME - get all jobs in a particular view
I am using version 1.0-h-1 of the plugin.
Re: Job Import Plugin [message #1064886 is a reply to message #1064750] Fri, 21 June 2013 10:09 Go to previous messageGo to next message
The job variant worked for me. I found it helpful to select the job in 2.2.1 and copy/paste the URL into the Job Import Plugin textbox, e.g., http://localhost:8089/job/Test-hmtlpublisher/
Neither the $HUDSON nor the $HUDSON/view/$VIEWNAME variants worked for me trying to pull from 2.2.1 into 3.0.1, even when I copy/paste the URLs, but both worked fine pulling from another 3.01.
Re: Job Import Plugin [message #1065374 is a reply to message #1064750] Tue, 25 June 2013 09:31 Go to previous messageGo to next message
I tried that without any success.
I'm using version 1.0-h-1 of the job import plugin.
Re: Job Import Plugin [message #1065430 is a reply to message #1065374] Tue, 25 June 2013 12:32 Go to previous messageGo to next message
I also wanted to point out that I'm going from Hudson 2.2.1 to Hudson 3.0.1 and they're on two different machines.
Re: Job Import Plugin [message #1065465 is a reply to message #1065430] Tue, 25 June 2013 15:44 Go to previous message
I also tried this with version 1.0 going from 2.2.1 to 2.2.1 with the same results.
Previous Topic:svn update with revert not working
Next Topic:Build Triggers Updated by Hudson/Maven Integration?
Current Time: Sun Jul 20 14:56:24 EDT 2025
Powered by FUDForum. Page generated in 0.09427 seconds
